PSMN013-30MLC,115
PSMN013-30MLC,115
    NEXPERIA(安世)
    SOT-1210
    MOSFETs 30V 38W SMT SOT1210 39A N-Channel
PSMN013-30MLC,115 数据手册
PSMN013-30MLC N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 23 February 2018 Product data sheet 1. General description Logic level enhancement mode N-channel MOSFET in LFPAK33 package. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 2. Features and benefits • • • Low parasitic inductance and resistance Optimised for 4.5V Gate drive utilising NextPower Superjunction technology Ultra low QG, QGD, & QOSS for high system efficiencies at low and high loads 3. Applications • • • DC-to-DC converters Load switching Synchronous buck regulator 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - 30 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 39 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 38 W Tj junction temperature -55 - 175 °C VGS = 4.5 V; ID = 10 A; Tj = 25 °C; Fig. 10 - 14.65 16.9 mΩ VGS = 10 V; ID = 10 A; Tj = 25 °C; Fig. 10 - 11.8 13.6 mΩ Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge ID = 10 A; VDS = 15 V; VGS = 4.5 V; Fig. 12; Fig. 13 - 1 - nC QG(tot) total gate charge ID = 10 A; VDS = 15 V; VGS = 10 V; Fig. 12; Fig. 13 - 8 - nC PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D G mbb076 1 2 3 S 4 LFPAK33 (SOT1210) 6. Ordering information Table 3. Ordering information Type number Package PSMN013-30MLC Name Description Version LFPAK33 Plastic single ended surface mounted package (LFPAK33); 8 leads SOT1210 7. Marking Table 4. Marking codes Type number Marking code PSMN013-30MLC M13C30 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - 30 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 38 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - 39 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 28 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 157 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 2 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology Symbol Parameter Conditions Min Max Unit VESD electrostatic discharge voltage MM (JEDEC) 100 - V Source-drain diode IS source current Tmb = 25 °C - 34 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 157 A ID = 39 A; Vsup ≤ 30 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped; Fig. 4 - 5.6 mJ Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy 03na19 120 003aaj396 40 ID (A) Pder (%) 30 80 20 40 10 0 0 50 100 150 Tmb (°C) 0 200 Fig. 2. Fig. 1. Normalized total power dissipation as a function of mounting base temperature 0 50 100 150 200 Tmb (° C) Continuous drain current as a function of mounting base temperature 003aaj398 103 ID (A) Limit R DSon = VDS / ID 102 tp =10 µ s 100 µ s 10 DC 1 ms 1 10 ms 100 ms 10-1 10-1 Fig. 3. 1 10 VDS (V) 102 Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 3 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 003aaj397 102 IAL (A) 10 (1) 1 (2) 10-1 10-3 Fig. 4. 10-2 10-1 tAL (ms) 1 10 Single pulse avalanche rating; avalanche current as a function of avalanche time 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 5 - 3.8 3.99 K/W 003aaj399 10 Z th(j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 P 0.02 10-1 δ= tp T single shot tp 10 Fig. 5. -2 10-6 10-5 10-4 10-3 10-2 t T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 4 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C 1.3 1.66 1.95 V ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature - -4 - mV/K IDSS drain leakage current VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 30 V; VGS = 0 V; Tj = 150 °C - - 100 µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 10 A; Tj = 25 °C; Fig. 10 - 14.65 16.9 mΩ VGS = 4.5 V; ID = 10 A; Tj = 150 °C; Fig. 10; Fig. 11 - - 28.75 mΩ VGS = 10 V; ID = 10 A; Tj = 25 °C; Fig. 10 - 11.8 13.6 mΩ VGS = 10 V; ID = 10 A; Tj = 150 °C; Fig. 10; Fig. 11 - - 22.95 mΩ f = 1 MHz 0.85 1.7 3.4 Ω ID = 10 A; VDS = 15 V; VGS = 10 V; Fig. 12; Fig. 13 - 8 - nC ID = 10 A; VDS = 15 V; VGS = 4.5 V; Fig. 12; Fig. 13 - 3.7 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 7.4 - nC ID = 10 A; VDS = 15 V; VGS = 4.5 V; Fig. 12; Fig. 13 - 1.2 - nC - 0.8 - nC Static characteristics V(BR)DSS IGSS RDSon RG gate leakage current drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gatesource charge QGS(th-pl) post-threshold gatesource charge - 0.4 - nC QGD gate-drain charge - 1 - nC VGS(pl) gate-source plateau voltage ID = 10 A; VDS = 15 V; Fig. 12; Fig. 13 - 2.6 - V Ciss input capacitance - 519 - pF Coss output capacitance VDS = 15 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 14 - 131 - pF Crss reverse transfer capacitance - 37 - pF PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 5 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology Symbol Parameter Conditions Min Typ Max Unit td(on) turn-on delay time - 7 - ns tr rise time VDS = 15 V; RL = 1.5 Ω; VGS = 4.5 V; RG(ext) = 5 Ω - 9.8 - ns td(off) turn-off delay time - 9.6 - ns tf fall time - 5.5 - ns Qoss output charge VGS = 0 V; VDS = 15 V; f = 1 MHz; Tj = 25 °C - 3.7 - nC Source-drain diode VSD source-drain voltage IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.86 1.1 V trr reverse recovery time - 13.4 - ns Qr recovered charge IS = 10 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 15 V - 6.6 - nC ta reverse recovery rise time IS = 10 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 15 V; Fig. 16 - 8.6 - ns tb reverse recovery fall time - 4.8 - ns 003aaj400 40 10 ID (A) 4.5 003aaj401 50 3.5 RDSon (mΩ ) 40 30 3 30 20 2.8 20 2.6 10 10 VGS (V) =2.4 0 Fig. 6. 2.2 0 1 2 3 VDS (V) 0 4 Output characteristics; drain current as a Fig. 7. function of drain-source voltage; typical values PSMN013-30MLC Product data sheet 0 8 12 VGS (V) 16 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 23 February 2018 4 © Nexperia B.V. 2018. All rights reserved 6 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 003aaj402 50 gfs (S) 003aaj403 40 ID (A) 40 30 30 20 20 10 10 Tj = 150 ° C 0 Fig. 8. 0 10 20 30 ID (A) 0 40 Forward transconductance as a function of drain current; typical values Fig. 9. 2.8 RDSon (mΩ ) 40 0 1 2 3 003aaj407 2 3 a 3.5 4 VGS (V) Transfer characteristics; drain current as a function of gate-source voltage; typical values 003aaj406 50 Tj = 25 ° C 10V 1.5 VGS=4.5V 30 1 20 4.5 10 0 0.5 VGS (V) = 10 5 15 25 35 0 -60 ID (A) 45 Fig. 10. Drain-source on-state resistance as a function of drain current; typical values PSMN013-30MLC Product data sheet 0 60 120 Tj (°C) 180 Fig. 11. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 7 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 003aaj408 10 VDS VGS (V) ID 8 VGS(pl) 6 6V 24 V VGS(th) VGS 4 QGS2 QGS1 QGS QGD QG(tot) VDS = 15 V 2 003aaa508 0 Fig. 12. Gate charge waveform definitions 0 2 4 6 8 QG 10 (nC) Fig. 13. Gate-source voltage as a function of gate charge; typical values 003aaj409 103 IS (A) Ciss C (pF) 30 Coss 102 20 Crss 10 10-1 003aaj410 40 1 10 VDS (V) 10 10 0 2 Tj = 150° C Tj = 25 ° C 0 0.3 0.6 0.9 VSD(V) 1.2 Fig. 14. Input, output and reverse transfer capacitances Fig. 15. Source current as a function of source-drain as a function of drain-source voltage; typical voltage; typical values values PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 8 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 003aaf444 ID (A) trr ta tb 0 0.25 IRM tb S= t a IRM t (s) Fig. 16. Reverse recovery timing definition PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 9 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 11. Package outline Plastic single ended surface mounted package (LFPAK33); 8 leads E A e1 A c1 b1 L1 SOT1210 D2 mounting base D1 (D) H E1 L 1 4 b e w A A1 C X c Lp y C detail X 0 2.5 5 mm scale Dimensions Unit(1) mm A A1 b(1) max 0.90 0.10 0.35 nom min 0.80 0.00 0.25 b1(1) c c1 2.4 0.20 0.30 2.2 0.10 0.20 D ref 2.60 D1 2.35 1.90 D2 0.50 E(1) E1 3.40 2.45 3.20 2.00 e e1 0.65 0.65 H L L1 Lp 3.40 0.65 0.25 0.50 3.20 0.45 0.13 0.30 w 0.20 0.10 Note 1. Plastic or metal protrusions of 0.15 mm per side are not included. Outline version sot1210_po References IEC JEDEC y JEITA European projection Issue date 14-04-25 16-08-09 SOT1210 Fig. 17. Package outline LFPAK33 (SOT1210) PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 10 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 12. Soldering Footprint information for reflow soldering of LFPAK33 package SOT1210 2.35 2.25 0.635 0.617 0.05 (all around) 0.75 0.62 1.05 1.91 2.47 0.51 3.9 0.51 0.6 0.83 0.4 (x8) solder land solder paste aperture occupied area solder resist 0.65 (x6) 0.3 (x8) 0.25 (x6) Notes : 1. Dimensions in mm sot1210_fr Fig. 18. Reflow soldering footprint for LFPAK33 (SOT1210) PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 11 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 13. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer PSMN013-30MLC Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’ warranty of the product for such automotive applications, use and specifications, and (b) whenever All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 12 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology customer uses the product for automotive applications beyond Nexperia’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’ standard warranty and Nexperia’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 13 / 14 PSMN013-30MLC Nexperia N-channel 30 V 13.6 mΩ logic level MOSFET in LFPAK33 using NextPower Technology 14. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Package outline........................................................ 10 12. Soldering................................................................... 11 13. Legal information..................................................... 12 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 February 2018 PSMN013-30MLC Product data sheet All information provided in this document is subject to legal disclaimers. 23 February 2018 © Nexperia B.V. 2018. All rights reserved 14 / 14
PSMN013-30MLC,115 价格&库存
很抱歉,暂时无法提供与“PSMN013-30MLC,115”相匹配的价格&库存,您可以联系我们找货
PSMN013-30MLC,115
  • 1+3.11300
  • 100+2.38700
  • 750+2.07900
  • 1500+1.98000
库存:1335
PSMN013-30MLC,115
  • 1+3.008851+0.38872
  • 10+2.7027210+0.34917
  • 25+2.5015525+0.32318
  • 100+2.39659100+0.30962
  • 250+2.22166250+0.28702
  • 500+2.11670500+0.27346
  • 1000+1.906781000+0.24634
  • 1500+1.775581500+0.22939
库存:1559
PSMN013-30MLC,115
  • 20+4.04690
  • 100+3.10310
  • 750+2.70270
库存:1335
PSMN013-30MLC,115
    PSMN013-30MLC,115
    • 1500+3.48480
    • 7500+3.45000
    库存:4500
    PSMN013-30MLC,115
    • 1+6.923301+0.89450
    • 10+4.2761010+0.55250
    • 100+2.75490100+0.35600
    • 500+2.09620500+0.27080
    • 1000+1.784701000+0.23060
    • 1500+1.772701500+0.22910
    • 3000+1.581103000+0.20430
    • 9000+1.461309000+0.18880
    • 24000+1.3296024000+0.17180
    库存:2051
    PSMN013-30MLC,115
      • 1000+1.83040
      库存:1005
