PSMN4R2-30MLDX
PSMN4R2-30MLDX
    NEXPERIA(安世)
    SOT-1210
    MOS管 N-channel Id=70A VDS=30V SOT1210
PSMN4R2-30MLDX 数据手册
PSMN4R2-30MLD N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 11 August 2015 Product data sheet 1. General description Logic level gate drive N-channel enhancement mode MOSFET in LFPAK33 package. NextPowerS3 portfolio utilising Nexperia’s unique “SchottkyPlus” technology delivers high efficiency, low spiking performance usually associated with MOSFETs with an integrated Schottky or Schottky-like diode but without problematic high leakage current. NextPowerS3 is particularly suited to high efficiency applications at high switching frequencies. 2. Features and benefits • • • • • • • • Ultra low QG, QGD and QOSS for high system efficiency, especially at higher switching frequencies Superfast switching with soft-recovery; s-factor > 1 Low spiking and ringing for low EMI designs Unique “SchottkyPlus” technology; Schottky-like performance with < 1 µA leakage at 25 °C Optimised for 4.5 V gate drive Low parasitic inductance and resistance High reliability clip bonded and solder die attach Mini Power SO8 package; no glue, no wire bonds, qualified to 175 °C Exposed leads for optimal visual solder inspection 3. Applications • • • • • • On-board DC-to-DC solutions for server and telecommunications Secondary-side synchronous rectification in telecommunication applications Voltage regulator modules (VRM) Point-of-Load (POL) modules Power delivery for V-core, ASIC, DDR, GPU, VGA and system components Brushed and brushless motor control 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 30 V ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 2 - - 70 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 65 W [1] PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Tj junction temperature Min Typ Max Unit -55 - 175 °C - 4.5 5.7 mΩ - 3.45 4.3 mΩ - 3.1 4.6 nC - 9.2 13.8 nC - 1.05 - Static characteristics RDSon drain-source on-state resistance VGS = 4.5 V; ID = 20 A; Tj = 25 °C; Fig. 10 VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 10 Dynamic characteristics QGD gate-drain charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; Fig. 12; Fig. 13 QG(tot) total gate charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; Fig. 12; Fig. 13 Source-drain diode S softness factor IS = 25 A; VGS = 0 V; dIS/dt = -100 A/µs; VDS = 15 V; Fig. 16 [1] Continuous current is limited by package 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D G mbb076 1 2 3 S 4 LFPAK33 (SOT1210) 6. Ordering information Table 3. Ordering information Type number PSMN4R2-30MLD PSMN4R2-30MLD Product data sheet Package Name Description Version LFPAK33 Plastic single ended surface mounted package (LFPAK33); 8 leads SOT1210 All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 2 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 7. Marking Table 4. Marking codes Type number Marking code PSMN4R2-30MLD 4D230L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 30 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 30 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 65 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - 70 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 65 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 366 A [1] IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 54 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 366 A - 59 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy VGS = 10 V; Tj(init) = 25 °C; ID = 25 A; [2] Vsup ≤ 30 V; RGS = 50 Ω; unclamped; tp = 122 µs [1] [2] PSMN4R2-30MLD Product data sheet Continuous current is limited by package Protected by 100% test All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 3 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 03aa16 120 Pder (%) aaa-008514 100 ID (A) 80 (1) 80 60 40 40 20 0 Fig. 1. ID (A) 0 50 100 150 Tmb (°C) 0 200 Normalized total power dissipation as a function of mounting base temperature 0 25 50 75 100 125 150 175 Tmb (°C) 200 (1) Capped at 70A due to package Fig. 2. Continuous drain current as a function of mounting base temperature aaa-009548 103 Limit RDSon = VDS / ID 102 tp = 10 us 100 us 10 DC 1 ms 10 ms 100 ms 1 10-1 10-1 Fig. 3. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - 2.09 2.32 K/W PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 4 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient Fig. 5 - 57 - K/W Fig. 6 - 178 - K/W aaa-008515 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10-1 0.05 P 0.02 δ= 10-2 10-6 10-5 10-4 10-3 10-2 t T 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration aaa-008477 aaa-008476 Fig. 5. T single shot tp Fig. 4. tp PCB layout for thermal resistance junction to ambient 1" square pad; FR4 Board; 2oz copper Fig. 6. PCB layout for thermal resistance junction to ambient minimum footprint; FR4 Board; 2oz copper 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C 1.2 1.7 2.2 V Static characteristics V(BR)DSS VGS(th) PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 5 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature 25 °C ≤ Tj ≤ 150 °C - -4.1 - mV/K IDSS drain leakage current VDS = 24 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 24 V; VGS = 0 V; Tj = 125 °C - 0.67 - µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 20 A; Tj = 25 °C; - 4.5 5.7 mΩ - - 9.4 mΩ - 3.45 4.3 mΩ - - 7.1 mΩ f = 1 MHz - 0.48 0.95 Ω ID = 25 A; VDS = 15 V; VGS = 10 V; - 19.6 29.3 nC - 9.2 13.8 nC ID = 0 A; VDS = 0 V; VGS = 10 V - 16.8 - nC IGSS RDSon gate leakage current drain-source on-state resistance Fig. 10 VGS = 4.5 V; ID = 20 A; Tj = 150 °C; Fig. 11; Fig. 10 VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 10 VGS = 10 V; ID = 25 A; Tj = 150 °C; Fig. 11; Fig. 10 RG gate resistance Dynamic characteristics QG(tot) total gate charge Fig. 12; Fig. 13 ID = 25 A; VDS = 15 V; VGS = 4.5 V; Fig. 12; Fig. 13 QGS gate-source charge ID = 25 A; VDS = 15 V; VGS = 4.5 V; - 3.1 - nC QGS(th) pre-threshold gatesource charge Fig. 12; Fig. 13 - 1.7 - nC QGS(th-pl) post-threshold gatesource charge - 1.4 - nC QGD gate-drain charge - 3.1 4.6 nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 15 V; Fig. 12; Fig. 13 - 2.9 - V Ciss input capacitance VDS = 15 V; VGS = 0 V; f = 1 MHz; - 1197 1795 pF Coss output capacitance Tj = 25 °C; Fig. 14 - 848 1272 pF Crss reverse transfer capacitance - 87 130 pF td(on) turn-on delay time VDS = 15 V; RL = 0.6 Ω; VGS = 4.5 V; - 10.1 - ns tr rise time RG(ext) = 5 Ω - 18.5 - ns td(off) turn-off delay time - 12 - ns tf fall time - 8.7 - ns PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 6 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Qoss output charge VGS = 0 V; VDS = 15 V; f = 1 MHz; - 16.8 - nC Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 15 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.81 1.2 V trr reverse recovery time IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; - 26 52 ns Qr recovered charge VDS = 15 V; Fig. 16 - 15 30 nC ta reverse recovery rise time - 12.7 - ns tb reverse recovery fall time - 13.3 - ns S softness factor - 1.05 - [1] includes capacitive recovery aaa-009549 120 ID (A) 10 V [1] 4.5 V 3.5 V aaa-009550 20 RDSon (mΩ) 16 90 12 60 VGS = 3 V 8 2.8 V 30 4 2.6 V 2.4 V 0 Fig. 7. 0 0.5 1 1.5 2 2.5 VDS (V) 0 3 Output characteristics; drain current as a Fig. 8. function of drain-source voltage; typical values PSMN4R2-30MLD Product data sheet 0 2 6 8 10 12 14 VGS (V) 16 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 11 August 2015 4 © Nexperia B.V. 2017. All rights reserved 7 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology ID (A) aaa-009551 80 aaa-009552 30 RDSon (mΩ) 2.8 V 3V 24 60 3.5 V 18 40 12 20 150°C Tj = 25°C 4.5 V 6 VGS = 10 V 0 Fig. 9. 0 0.5 1 1.5 2 2.5 3 3.5 VGS (V) 0 4 Transfer characteristics; drain current as a function of gate-source voltage; typical values 36 54 72 ID (A) 90 Fig. 10. Drain-source on-state resistance as a function of drain current; typical values VDS ID 10 V 1.6 VGS(pl) 1.2 VGS(th) VGS = 4.5 V 0.8 VGS QGS2 QGS1 0.4 0 -60 18 003aal037 2 a 0 -30 0 30 60 90 120 150 Tj (°C) QGS QGD QG(tot) 003aaa508 Fig. 12. Gate charge waveform definitions 180 Fig. 11. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 8 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology VGS (V) aaa-009553 10 aaa-009554 104 C (pF) 8 Ciss 103 Coss 6 24 V 15 V 4 102 VDS = 6 V Crss 2 0 0 5 10 15 20 QG (nC) 10 10-1 25 Fig. 13. Gate-source voltage as a function of gate charge; typical values IS (A) 1 10 VDS (V) Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 003aal160 aaa-009555 103 102 ID (A) 102 trr ta 10 0.25 IRM 1 10-1 tb 0 150°C 0 0.2 0.4 Tj = 25°C 0.6 0.8 1 VSD (V) IRM t (s) 1.2 Fig. 15. Source current as a function of source-drain voltage; typical values PSMN4R2-30MLD Product data sheet Fig. 16. Reverse recovery timing definition All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 9 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 11. Package outline Plastic single ended surface mounted package (LFPAK33); 8 leads E e1 L SOT1210 A A c1 b1 E1 mounting base D1 D H 1 4 e b w X A A1 c C θ Lp y C detail X 0 2.5 Dimensions Unit(1) mm 5 mm scale A A1 b b1 c c1 D(1) D1 E(1) E1 e e1 H L Lp w y max 0.90 0.10 0.35 0.35 0.20 0.30 2.70 2.35 3.40 2.45 3.40 0.25 0.50 nom 0.65 0.65 0.20 0.10 3.20 0.13 0.30 min 0.80 0.00 0.25 0.25 0.10 0.20 2.50 1.90 3.20 2.00 θ 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm per side are not included. Outline version sot1210_po References IEC JEDEC JEITA European projection Issue date 11-12-19 12-03-12 SOT1210 Fig. 17. Package outline LFPAK33 (SOT1210) PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 10 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN4R2-30MLD Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 11 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 12 / 13 PSMN4R2-30MLD Nexperia N-channel 30 V, 4.2 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 3 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 August 2015 PSMN4R2-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © Nexperia B.V. 2017. All rights reserved 13 / 13
PSMN4R2-30MLDX 价格&库存
很抱歉,暂时无法提供与“PSMN4R2-30MLDX”相匹配的价格&库存,您可以联系我们找货
PSMN4R2-30MLDX
  • 732+6.42870732+0.83410
  • 1000+5.928101000+0.76920
  • 10000+5.2859010000+0.68590
  • 100000+4.42790100000+0.57450
库存:20470
PSMN4R2-30MLDX
  • 1500+3.556251500+0.46096
  • 3000+3.272343000+0.42416
  • 4500+3.127734500+0.40542
  • 7500+2.965217500+0.38435
  • 10500+2.8689910500+0.37188
  • 15000+2.7754915000+0.35976
库存:2779
PSMN4R2-30MLDX
库存:30
