BUK9277-55A,118
BUK9277-55A,118
    NEXPERIA(安世)
    TO-252(DPAK)
    MOS管 N-channel Id=18A VDS=55V SOT428
BUK9277-55A,118 数据手册
BUK9277-55A N-channel TrenchMOS logic level FET 12 June 2014 Product data sheet 1. General description Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 2. Features and benefits • • • Q101 compliant Suitable for logic level gate drive sources Suitable for thermally demanding environments due to 175 °C rating 3. Applications • • • 12 V and 24 V loads Automotive and general purpose power switching Motors, lamps and solenoids 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 55 V ID drain current VGS = 5 V; Tmb = 25 °C; Fig. 2; Fig. 3 - - 18 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 51 W VGS = 10 V; ID = 10 A; Tj = 25 °C - 59 69 mΩ VGS = 4.5 V; ID = 10 A; Tj = 25 °C - - 86 mΩ VGS = 5 V; ID = 10 A; Tj = 25 °C; Fig. 13 - 65 77 mΩ ID = 18 A; Vsup ≤ 55 V; RGS = 50 Ω; - - 33 mJ Static characteristics RDSon drain-source on-state resistance Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy VGS = 5 V; Tj(init) = 25 °C; unclamped BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol D mb G mbb076 2 1 S 3 DPAK (SOT428) 6. Ordering information Table 3. Ordering information Type number Package Name Description Version BUK9277-55A DPAK plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 BUK9277-55A/CD DPAK plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 7. Marking Table 4. Marking codes Type number Marking code BUK9277-55A BUK9277-55A BUK9277-55A/CD 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 55 V VDGR drain-gate voltage RGS = 20 kΩ - 55 V VGS gate-source voltage -15 15 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 51 W ID drain current Tmb = 25 °C; VGS = 5 V; Fig. 2; Fig. 3 - 18 A Tmb = 100 °C; VGS = 5 V; Fig. 2 - 13 A BUK9277-55A Product data sheet All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 2 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET Symbol Parameter Conditions Min Max Unit IDM peak drain current Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3 - 73 A Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 18 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 73 A non-repetitive drain-source avalanche energy ID = 18 A; Vsup ≤ 55 V; RGS = 50 Ω; - 33 mJ repetitive drain-source avalanche energy Fig. 4 - J Avalanche ruggedness EDS(AL)S EDS(AL)R [1] [2] [3] [4] VGS = 5 V; Tj(init) = 25 °C; unclamped [1][2][3][4]- Maximum value not quoted. Repetitive rating defined in avalanche rating figure. Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. Repetitive avalanche rating limited by an average junction temperature of 170 °C. Refer to application note AN10273 for further information. 03aa16 120 003aab510 20 ID (A) Pder (%) 15 80 10 40 5 0 Fig. 1. 0 50 100 150 Tmb (°C) Normalized total power dissipation as a function of mounting base temperature BUK9277-55A Product data sheet 0 200 Fig. 2. 0 100 150 Tmb (°C) 200 Continuous drain current as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 12 June 2014 50 © Nexperia B.V. 2017. All rights reserved 3 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 003aab511 102 10 µs Limit RDSon = V DS / ID ID (A) 10 100 µs 1 ms DC 10 ms 1 10-1 Fig. 3. 100 ms 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 003aab531 102 IAL (A) (1) 10 (2) 1 (3) 10-1 10-2 10-3 Fig. 4. 10-2 10-1 1 t (ms) 10 AL Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-mb) thermal resistance from junction to mounting base BUK9277-55A Product data sheet Conditions All information provided in this document is subject to legal disclaimers. 12 June 2014 Min Typ Max Unit - - 2.93 K/W © Nexperia B.V. 2017. All rights reserved 4 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient Fig. 5 - 71.4 - K/W 03ne00 10 Zth(j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 10- 1 0.02 P δ= tp T single shot tp 10- 2 10- 6 Fig. 5. 10- 5 10- 4 10- 3 10- 2 10- 1 t T tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 55 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 50 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = -55 °C; - - 2.3 V 1 1.5 2 V 0.5 - - V VDS = 55 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 55 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VGS = 15 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -15 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 10 A; Tj = 25 °C - 59 69 mΩ VGS = 4.5 V; ID = 10 A; Tj = 25 °C - - 86 mΩ VGS = 5 V; ID = 10 A; Tj = 175 °C; - - 154 mΩ Static characteristics V(BR)DSS VGS(th) Fig. 12 ID = 1 mA; VDS = VGS; Tj = 25 °C; Fig. 12 ID = 1 mA; VDS = VGS; Tj = 175 °C; Fig. 12 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 13 BUK9277-55A Product data sheet All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 5 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET Symbol Parameter Conditions Min Typ Max Unit VGS = 5 V; ID = 10 A; Tj = 25 °C; Fig. 13 - 65 77 mΩ Dynamic characteristics QG(tot) total gate charge ID = 10 A; VDS = 44 V; VGS = 5 V; - 11 - nC QGS gate-source charge Fig. 14 - 1.6 - nC QGD gate-drain charge - 5 - nC Ciss input capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; - 440 643 pF Coss output capacitance Tj = 25 °C; Fig. 15 - 90 110 pF Crss reverse transfer capacitance - 60 93 pF td(on) turn-on delay time VDS = 30 V; RL = 1.2 Ω; VGS = 5 V; - 10 - ns tr rise time RG(ext) = 10 Ω; Tj = 25 °C - 47 - ns td(off) turn-off delay time - 28 - ns tf fall time - 33 - ns LD internal drain inductance meausured from drain lead from package to centre of die; Tj = 25 °C - 2.5 - nH LS internal source inductance measured from source lead from package to source bond pad; Tj = 25 °C - 7.5 - nH IS = 15 A; VGS = 0 V; Tj = 25 °C; Fig. 16 - 0.85 1.2 V Source-drain diode VSD source-drain voltage trr reverse recovery time IS = 20 A; dIS/dt = -100 A/µs; - 33 - ns recovered charge VGS = -10 V; VDS = 30 V; Tj = 25 °C - 60 - nC Qr 03nd43 60 VGS (V) = 8 10 ID (A) 7 6 40 03nd42 120 RDSon (mΩ) 100 5 80 4 20 60 3 0 Fig. 6. 0 2 4 6 8 2.2 10 VDS (V) 40 Output characteristics: drain current as a Fig. 7. function of drain-source voltage; typical values BUK9277-55A Product data sheet 2 6 8 VGS (V) 10 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 12 June 2014 4 © Nexperia B.V. 2017. All rights reserved 6 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 03aa36 10-1 ID (A) 03nd40 15 gfs (S) 10-2 10 10-3 min typ max 10-4 5 10-5 10-6 Fig. 8. 0 1 2 VGS (V) 0 3 Sub-threshold drain current as a function of gate-source voltage Fig. 9. 03nd41 25 0 5 10 15 20 25 Forward transconductance as a function of drain current; typical values 03nd39 5 ID (A) ID (A) VGS (V) 20 4 15 3 10 2 5 1 Tj = 175 °C 0 0 1 Tj = 25 °C 2 3 4 VGS (V) 0 5 Fig. 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values BUK9277-55A Product data sheet VDD = 44(V) VDD = 14(V) 0 5 10 QG (nC) 15 Fig. 11. Gate-source voltage as a function of turn-on gate charge; typical values All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 7 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 03aa33 2.5 VGS(th) (V) 2 003aab504 180 VGS (V) = 3 3.4 3.8 4 5 RDSon (mΩ) max 130 1.5 typ 1 min 80 0.5 0 -60 0 60 120 Tj (° C) 30 180 Fig. 12. Gate-source threshold voltage as a function of junction temperature 003aab508 5 VGS (V) 0 10 20 30 40 I (A) 50 D Fig. 13. Drain-source on-state resistance as a function of drain current; typical values 003aab506 1200 C (pF) 4 VDS (V) = 14 800 VDS (V) = 44 3 C iss 2 400 C oss 1 0 0 5 10 QG (nC) Fig. 14. Gate-source voltage as a function of gate charge; typical values BUK9277-55A Product data sheet 0 10-2 15 C rss 10-1 1 10 VDS (V) 102 Fig. 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 8 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 003aab509 50 IS (A) 40 30 20 Tj = 175 °C 10 0 0.0 0.5 Tj = 25 °C 1.0 VSD (V) 1.5 Fig. 16. Source current as a function of source-drain voltage; typical values BUK9277-55A Product data sheet All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 9 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 11. Package outline Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 y E A A A1 b2 see Note 1 E1 mounting base D2 D1 HD 2 L2 L 1 L1 3 b1 b w c A e e1 0 5 10 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b max 2.38 0.93 0.89 nom min 2.22 0.46 0.71 b1 b2 c D1 1.1 5.46 0.56 6.22 0.9 5.00 0.20 5.98 D2 E E1 6.73 4.0 6.47 4.45 e e1 2.285 4.57 HD L L1 10.4 2.95 9.6 2.55 L2 0.9 0.5 0.5 w 0.2 y 0.2 Note 1. Plastic body may have 45° chamfer. Outline version SOT428 sot428_po References IEC JEDEC JEITA TO-252 SC-63 European projection Issue date 06-03-16 14-06-10 Fig. 17. Package outline DPAK (SOT428) BUK9277-55A Product data sheet All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 10 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. BUK9277-55A Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 11 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BUK9277-55A Product data sheet All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 12 / 13 BUK9277-55A Nexperia N-channel TrenchMOS logic level FET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 June 2014 BUK9277-55A Product data sheet All information provided in this document is subject to legal disclaimers. 12 June 2014 © Nexperia B.V. 2017. All rights reserved 13 / 13
BUK9277-55A,118
1. 物料型号:BUK9277-55A 2. 器件简介: - 这是一个N-channel TrenchMOS逻辑电平FET,采用塑料封装,并使用TrenchMOS技术。 - 产品已根据适当的AEC标准设计和认证,适用于汽车关键应用。 3. 引脚分配: - G:栅极 - D:漏极 - S:源极 - mb:安装底座;连接到漏极 4. 参数特性: - 漏源电压(Vps):最大55V - 漏电流(lp):最大18A - 总功率耗散(Ptot):最大51W - 漏源导通电阻(RDSon):在特定条件下最小值为59mΩ,典型值为69mΩ 5. 功能详解: - 器件适用于12V和24V负载,汽车和通用电源开关,电动机、灯具和电磁铁。 - 器件符合Q101标准,适用于逻辑电平门驱动源,适用于温度要求较高的环境,因为其耐温等级为175°C。 6. 应用信息: - 主要应用于汽车和一般用途的功率开关,包括电动机、灯具和电磁铁的控制。 7. 封装信息: - 封装类型:DPAK(SOT428) - 描述:塑料单端表面贴装封装(DPAK);3个引脚(一个引脚被剪短)。
BUK9277-55A,118 价格&库存
很抱歉,暂时无法提供与“BUK9277-55A,118”相匹配的价格&库存,您可以联系我们找货
