BUK7275-100A,118
BUK7275-100A,118
    NEXPERIA(安世)
    TO-252(DPAK)
    MOS管 N-Channel Id=21.7A VDS=100V SOT428
BUK7275-100A,118 数据手册
BUK7275-100A N-channel TrenchMOS standard level FET Rev. 02 — 17 June 2010 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits  Low conduction losses due to low on-state resistance  Suitable for standard level gate drive sources  Q101 compliant  Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications  12 V, 24 V and 42 V loads  Motors, lamps and solenoids  Automotive and general purpose power switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 ID drain current VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 3 - - 21.7 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 89 W VGS = 10 V; ID = 13 A; Tj = 175 °C; see Figure 12; see Figure 13 - - 187 mΩ VGS = 10 V; ID = 13 A; Tj = 25 °C; see Figure 12; see Figure 13 - 64 75 mΩ non-repetitive ID = 14 A; Vsup ≤ 100 V; drain-source RGS = 50 Ω; VGS = 10 V; avalanche energy Tj(init) = 25 °C; unclamped - - 100 mJ V Static characteristics RDSon drain-source on-state resistance Avalanche ruggedness EDS(AL)S BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain Simplified outline Graphic symbol mb 3 S source mb D mounting base; connected to drain D G mbb076 S 2 1 3 SOT428 (DPAK) 3. Ordering information Table 3. Ordering information Type number BUK7275-100A BUK7275-100A Product data sheet Package Name Description Version DPAK plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 2 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V VDGR drain-gate voltage RGS = 20 kΩ - - 100 V VGS gate-source voltage -20 - 20 V ID drain current - - 21.7 A - - 15.4 A - - 87 A - - 89 W Tmb = 25 °C; VGS = 10 V; see Figure 1; see Figure 3 Tmb = 100 °C; VGS = 10 V; see Figure 1 IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 Tstg storage temperature -55 - 175 °C Tj junction temperature -55 - 175 °C [1] Source-drain diode IS source current Tmb = 25 °C - - 21.7 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - - 87 A ID = 14 A; Vsup ≤ 100 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped - - 100 mJ Avalanche ruggedness non-repetitive drain-source avalanche energy EDS(AL)S [1] Peak drain current is limited by chip, not package. 03aa24 120 Ider (%) 03aa16 120 Pder (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 150 Tmb (°C) Fig 1. Normalized continuous drain current as a function of mounting base temperature BUK7275-100A Product data sheet 200 Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 3 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 03nb21 103 ID (A) RDSon = VDS/ID 102 tp = 10 us 100 us 10 δ= P 1 ms tp D.C. T 10 ms 100 ms 1 t tp T 10−1 1 102 10 103 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 1.7 K/W Rth(j-a) thermal resistance from junction to ambient minimum footprint; FR4 board - 71.4 - K/W 03nb22 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10−1 δ= P 0.05 tp T 0.02 t tp Single Shot 10−2 10−6 10−5 T 10−4 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration BUK7275-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 4 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 89 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 11 - - 4.4 V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 11 2 3 4 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 11 1 - - V IDSS drain leakage current VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA IGSS gate leakage current VDS = 0 V; VGS = 20 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -20 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 13 A; Tj = 175 °C; see Figure 12; see Figure 13 - - 187 mΩ VGS = 10 V; ID = 13 A; Tj = 25 °C; see Figure 12; see Figure 13 - 64 75 mΩ RDSon drain-source on-state resistance Dynamic characteristics Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 14 VDS = 30 V; RL = 2.2 Ω; VGS = 10 V; RG(ext) = 5.6 Ω; Tj = 25 °C - 910 1210 pF - 130 152 pF - 80 107 pF - 8 - ns - 39 - ns turn-off delay time - 26 - ns tf fall time - 24 - ns LD internal drain inductance measured from drain lead from package to centre of die - 2.5 - nH LS internal source inductance measured from source lead from package to source bond pad - 7.5 - nH td(on) turn-on delay time tr rise time td(off) Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 15 - 0.85 1.2 V trr reverse recovery time - 64 - ns Qr recovered charge IS = 13 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C - 120 - nC BUK7275-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 5 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 03nb31 60 ID (A) 9 VGS (V) = 8 RDSon (mΩ) 10 20 50 03nb30 90 85 7.5 80 40 6.5 75 30 70 65 20 5.5 60 10 55 4.5 0 0 2 4 6 8 VDS (V) 50 10 5 10 15 VGS (V) 20 Tj = 25 °C Fig 5. Output characteristics: drain current as a function of drain-source voltage; typical values Fig 6. 03aa35 10−1 ID (A) min 10−2 typ Drain-source on-state resistance as a function of gate-source voltage; typical values 03nb28 20 gfs (S) max 15 10−3 10 10−4 5 10−5 10−6 0 0 2 4 6 0 10 20 30 VGS (V) Fig 7. Sub-threshold drain current as a function of gate-source voltage BUK7275-100A Product data sheet Fig 8. ID (A) 40 Forward transconductance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 6 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET ID (A) 03nb29 35 03nb27 10 VGS (V) 9 30 8 25 VDS = 14 V 7 VDS = 80 V 6 20 5 15 4 3 10 Tj = 175 °C Tj = 25 °C 2 5 1 0 Fig 9. 0 2 4 6 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values 03aa32 5 0 8 0 4 max 3 20 QG (nC) 30 Fig 10. Gate-source voltage as a function of turn-on gate charge; typical values 03nb32 120 RDSon (mΩ) VGS(th) (V) 10 VGS (V)= 5.5 6 6.5 7 8 10 100 typ 80 2 min 60 1 0 −60 40 0 60 120 180 Fig 11. Gate-source threshold voltage as a function of junction temperature BUK7275-100A Product data sheet 0 10 20 30 40 Tj (°C) ID (A) 50 Fig 12. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 7 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 03aa29 3 03nb33 2000 C (pF) 1800 a Ciss 1600 1400 2 1200 Coss 1000 800 Crss 1 600 400 200 0 -60 0 60 120 Tj (°C) 0 10−2 180 Fig 13. Normalized drain-source on-state resistance factor as a function of junction temperature 10−1 1 10 VDS(V) 102 Fig 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 03nb26 IS 45 (A) 40 35 30 25 20 15 10 Tj = 175 °C Tj = 25 °C 5 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 VSD (V) Fig 15. Reverse diode current as a function of reverse diode voltage; typical values BUK7275-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 8 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 7. Package outline Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 y E A A A1 b2 E1 mounting base D2 D1 HD 2 L L2 1 L1 3 b1 b w M c A e e1 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1 b2 c D1 D2 min E E1 min e e1 HD L L1 min L2 w y max mm 2.38 2.22 0.93 0.46 0.89 0.71 1.1 0.9 5.46 5.00 0.56 0.20 6.22 5.98 4.0 6.73 6.47 4.45 2.285 4.57 10.4 9.6 2.95 2.55 0.5 0.9 0.5 0.2 0.2 OUTLINE VERSION SOT428 REFERENCES IEC JEDEC JEITA TO-252 SC-63 EUROPEAN PROJECTION ISSUE DATE 06-02-14 06-03-16 Fig 16. Package outline SOT428 (DPAK) BUK7275-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 9 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK7275-100A v.2 20100617 Product data sheet - BUK7275-100A v.1 Modifications: BUK7275-100A v.1 (9397 750 07645) BUK7275-100A Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 20001025 Product Specification - All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 - © Nexperia B.V. 2017. All rights reserved 10 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BUK7275-100A Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. The product is not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 11 of 13 BUK7275-100A Nexperia N-channel TrenchMOS standard level FET Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BUK7275-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 June 2010 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia BUK7275-100A N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 June 2010
BUK7275-100A,118 价格&库存
很抱歉,暂时无法提供与“BUK7275-100A,118”相匹配的价格&库存,您可以联系我们找货
