BUK7675-55A,118
BUK7675-55A,118
    NEXPERIA(安世)
    SOT404
    MOS管 N-Channel Id=20.3A VDS=55V SOT404
BUK7675-55A,118 数据手册
BUK7675-55A N-channel TrenchMOS standard level FET 25 August 2014 Product data sheet 1. General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 2. Features and benefits • • • • AEC Q101 compliant Low conduction losses due to low on-state resistance Suitable for standard level gate drive sources Suitable for thermally demanding environments due to 175 °C rating 3. Applications • • • 12 V and 24 V loads Automotive and general purpose power switching Motors, lamps and solenoids 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 55 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2; Fig. 3 - - 20.3 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 62 W VGS = 10 V; ID = 10 A; Tj = 175 °C; - - 150 mΩ - 64 75 mΩ - - 30.3 mJ Static characteristics RDSon drain-source on-state resistance Fig. 11; Fig. 12 VGS = 10 V; ID = 10 A; Tj = 25 °C; Fig. 11; Fig. 12 Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy ID = 11 A; Vsup ≤ 55 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 2 1 S 3 D2PAK (SOT404) 6. Ordering information Table 3. Ordering information Type number Package BUK7675-55A Name Description Version D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404 (one lead cropped) 7. Marking Table 4. Marking codes Type number Marking code BUK7675-55A BUK7675-55A 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 55 V VDGR drain-gate voltage RGS = 20 kΩ - 55 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 62 W ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 2; Fig. 3 - 20.3 A Tmb = 100 °C; VGS = 10 V; Fig. 2 - 14.3 A Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3 - 81 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 2 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET Symbol Parameter Conditions Min Max Unit Source-drain diode IS source current Tmb = 25 °C - 20.3 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 81 A ID = 11 A; Vsup ≤ 55 V; RGS = 50 Ω; - 30.3 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped 03na19 120 Pder (%) Ider (%) 80 80 40 40 0 Fig. 1. 03aa24 120 0 50 100 150 Tmb (°C) 0 200 Normalized total power dissipation as a function of mounting base temperature Fig. 2. 0 50 100 150 Tmb (°C) 200 Normalized continuous drain current as a function of mounting base temperature 03nc12 103 ID (A) 102 RDSon = VDS / ID tp = 10 µs 10 100 µs P δ= 1 tp 10- 1 Fig. 3. 1 tp 1 ms D.C. T 10 ms 100 ms t T 10 VDS (V) 102 Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 3 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - - 2.4 K/W Rth(j-a) thermal resistance from junction to ambient mounted on printed-circuit board; minimum footprint - 50 - K/W 03nc13 10 Zth(j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 10- 1 0.02 P δ= tp T single shot tp 10- 2 10- 6 Fig. 4. 10- 5 10- 4 10- 3 10- 2 10- 1 t T tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 55 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 50 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 175 °C; 1 - - V 2 3 4 V - - 4.4 V VDS = 55 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 55 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA Static characteristics V(BR)DSS VGS(th) Fig. 10 ID = 1 mA; VDS = VGS; Tj = 25 °C; Fig. 10 ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 10 IDSS drain leakage current BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 4 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET Symbol Parameter Conditions Min Typ Max Unit IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 10 A; Tj = 175 °C; - - 150 mΩ - 64 75 mΩ RDSon drain-source on-state resistance Fig. 11; Fig. 12 VGS = 10 V; ID = 10 A; Tj = 25 °C; Fig. 11; Fig. 12 Dynamic characteristics Ciss input capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; - 320 483 pF Coss output capacitance Tj = 25 °C; Fig. 13 - 92 113 pF Crss reverse transfer capacitance - 64 90 pF td(on) turn-on delay time VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; - 10 - ns tr rise time RG(ext) = 10 Ω; Tj = 25 °C - 50 - ns td(off) turn-off delay time - 70 - ns tf fall time - 40 - ns LD internal drain inductance from upper edge of drain mounting base to centre of die; Tj = 25 °C - 2.5 - nH from drain lead 6 mm from package to centre of die; Tj = 25 °C - 4.5 - nH from source lead to source bond pad; Tj = 25 °C - 7.5 - nH IS = 15 A; VGS = 0 V; Tj = 25 °C; Fig. 14 - 0.85 1.2 V LS internal source inductance Source-drain diode VSD source-drain voltage trr reverse recovery time IS = 20 A; dIS/dt = -100 A/µs; - 32 - ns recovered charge VGS = -10 V; VDS = 30 V; Tj = 25 °C - 120 - nC Qr BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 5 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 03nc09 60 ID (A) 50 VGS (V) = 16 14 03nc08 160 RDSon (mΩ) 20 140 12 10.5 40 120 9.5 30 100 8.5 7.5 20 80 6.5 10 0 Fig. 5. 60 5.5 4.5 0 2 4 6 8 40 10 VDS (V) Output characteristics; drain current as a Fig. 6. function of drain-source voltage; typical values 03aa35 10- 1 ID (A) min 10- 2 typ 5 10 15 VGS (V) 20 Drain-source on-state risistance as a function of gate-source voltage; typical values 03nc07 25 ID (A) max 20 10- 3 15 10- 4 10 10- 5 5 Tj = 175 °C 10- 6 Fig. 7. 0 2 4 VGS (V) 0 6 Sub-threshold drain current as a function of gate-source voltage BUK7675-55A Product data sheet Fig. 8. Tj = 25 °C 0 2 6 8 10 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 25 August 2014 4 © Nexperia B.V. 2017. All rights reserved 6 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 03nc05 10 VGS (V) 4 VDD = 14 V 6 3 4 2 2 1 0 Fig. 9. VGS(th) (V) VDD = 44 V 8 0 5 10 QG (nC) 0 - 60 15 Gate-source voltage as a function of gate charge; typical values 5.5 6 6.5 7 max typ min 0 60 120 Tj (°C) 180 Fig. 10. Gate-source threshold voltage as a function of junction temperature 03nc10 180 RDSon (mΩ) 160 03aa32 5 03aa28 2.4 a 8 VGS (V) = 10 1.8 140 120 1.2 100 80 0.6 60 40 0 10 20 30 40 ID (A) 0 - 60 50 Fig. 11. Drain-source on-state resistance as a function of drain current; typical values BUK7675-55A Product data sheet 0 60 120 Tj (°C) 180 Fig. 12. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 7 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 03nc11 600 C (pF) 500 Ciss Coss 80 400 Crss 300 60 200 40 100 20 0 03nc04 120 IS (A) 100 10- 2 10- 1 1 10 VDS (V) 0 102 Tj = 175 °C Tj = 25 °C 0 0.5 1.0 1.5 VSD (V) 2.0 Fig. 13. Input, output and reverse capicitances as a Fig. 14. Reverse diode current as a function of reverse function of drain-source voltage; typical values dioode voltage; typical values BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 8 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 11. Package outline Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) SOT404 A A1 E mounting base D1 D HD 2 Lp 1 3 b2 c b e e Q 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 b b2 c 4.5 1.40 0.85 1.45 0.64 4.1 1.27 0.60 1.05 0.46 D D1 E 11 1.6 10.3 1.2 9.7 e 2.54 HD Lp Q 15.8 2.9 2.6 14.8 2.1 2.2 sot404_po Outline version References IEC JEDEC JEITA European projection Issue date 06-03-16 13-02-25 SOT404 Fig. 15. Package outline D2PAK (SOT404) BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 9 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. BUK7675-55A Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 10 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 11 / 12 BUK7675-55A Nexperia N-channel TrenchMOS standard level FET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 4 11 Package outline ..................................................... 9 12 12.1 12.2 12.3 12.4 Legal information .................................................10 Data sheet status ............................................... 10 Definitions ...........................................................10 Disclaimers .........................................................10 Trademarks ........................................................ 11 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 August 2014 BUK7675-55A Product data sheet All information provided in this document is subject to legal disclaimers. 25 August 2014 © Nexperia B.V. 2017. All rights reserved 12 / 12
BUK7675-55A,118 价格&库存
很抱歉,暂时无法提供与“BUK7675-55A,118”相匹配的价格&库存,您可以联系我们找货
BUK7675-55A,118
  • 1+13.42734
  • 10+8.48042
  • 800+6.62383
