PHP33NQ20T
N-channel TrenchMOS standard level FET
Rev. 02 — 3 February 2009
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Higher operating power due to low
thermal resistance
Simple gate drive required due to low
gate charge
Low conduction losses due to low
on-state resistance
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
DC-to-DC convertors switching
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
200
V
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1; see Figure 3
32.7
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
230
W
VGS = 10 V; ID = 25 A;
VDS = 100 V; Tj = 25 °C;
see Figure 11
9.6
nC
VGS = 10 V; ID = 15 A;
Tj = 25 °C; see Figure 9;
see Figure 10
65
77
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PHP33NQ20T
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
S
1 2 3
SOT78
(TO-220AB; SC-46)
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
PHP33NQ20T
TO-220AB;
plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78
SC-46
TO-220AB
PHP33NQ20T_2
Product data sheet
2 of 13
Nexperia B.V. 2017. All rights reserved
PHP33NQ20T
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
200
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ
VGS
gate-source voltage
ID
drain current
200
V
-20
V
VGS = 10 V; Tmb = 100 °C; see Figure 1
23.1
A
VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 3
32.7
A
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
65.4
A
Ptot
total power dissipation
230
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
32.7
A
ISM
peak source current
65.4
A
190
mJ
Avalanches ruggedness
non-repetitive
VGS = 10 V; Tj(init) = 25 °C; ID = 10.4 A; Vsup ≤ 200 V;
drain-source avalanche unclamped; tp = 0.14 ms; RGS = 50 Ω
energy
EDS(AL)S
03aa24
120
Ider
03aa16
120
Pder
80
80
40
40
100
150
200
100
150
Tmb (°C)
Fig 1.
Normalized continuous drain current as a
function of mounting base temperature
200
Tmb (°C)
Fig 2.
Normalized total power dissipation as a
PHP33NQ20T_2
Product data sheet
3 of 13
PHP33NQ20T
Nexperia
03ao10
102
tp = 10 μ s
ID
(A)
100 μ s
Limit RDSon = VDS / ID
10
DC
1 ms
10 ms
1
10-1
1
102
10
103
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PHP33NQ20T_2
Product data sheet
4 of 13
PHP33NQ20T
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-a)
Rth(j-mb)
Conditions
Min
Typ
Max
Unit
thermal resistance from vertical in still air
junction to ambient
60
K/W
thermal resistance from see Figure 4
junction to mounting
base
0.65
K/W
03ao09
10
Zth(j-mb)
(K/W)
1
δ = 0.5
10-1
0.2
0.1
0.05
δ=
P
0.02
single pulse
10-2
tp
T
t
tp
T
10-3
10-5
10-4
10-3
10-2
10-1
1
tp (s)
Fig 4.
Transient thermal impedance from junction to mounting base as a function of pulse duration
PHP33NQ20T_2
Product data sheet
5 of 13
PHP33NQ20T
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 250 µA; VGS = 0 V; Tj = -55 °C
180
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
200
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 7; see Figure 8
1
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
4.4
V
VDS = 160 V; VGS = 0 V; Tj = 175 °C
500
µA
VDS = 160 V; VGS = 0 V; Tj = 25 °C
1
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
10
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
10
100
nA
VGS = 10 V; ID = 15 A; Tj = 25 °C;
see Figure 9; see Figure 10
65
77
mΩ
VGS = 10 V; ID = 15 A; Tj = 175 °C;
182
215
mΩ
ID = 25 A; VDS = 100 V; VGS = 10 V;
Tj = 25 °C; see Figure 11
32.2
nC
6.5
nC
9.6
nC
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
tf
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
1870
pF
230
pF
70
pF
12
ns
35
ns
turn-off delay time
43
ns
fall time
45
ns
VDS = 100 V; RL = 4 Ω; VGS = 10 V;
RG(ext) = 6 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 13
0.87
1.2
V
trr
reverse recovery time
150
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 25 V; Tj = 25 °C
645
nC
PHP33NQ20T_2
Product data sheet
6 of 13
PHP33NQ20T
Nexperia
03ao11
40
Tj = 25 °C
ID
(A)
03ao13
40
10 V 5 V
VDS > ID x RDSon
ID
(A)
4.6 V
30
30
4.4 V
4.2 V
175 °C
10
Tj = 25 °C
10
4V
VGS = 3.8 V
Fig 5.
1
2
3
4
VDS (V)
5
Output characteristics: drain current as a
function of drain-source voltage; typical values
03aa32
5
Fig 6.
2
4
VGS (V)
6
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03aa35
10−1
ID
(A)
VGS(th)
(V)
4
max
10−4
min
10−5
1
−60
typ
10−3
typ
2
min
10−2
max
3
Fig 7.
10−6
120
2
4
6
Tj (°C)
VGS (V)
Gate-source threshold voltage as a function of
Fig 8.
Sub-threshold drain current as a function of
gate-source voltage
PHP33NQ20T_2
Product data sheet
7 of 13
PHP33NQ20T
Nexperia
03ao12
125
03al52
3
Tj = 25 °C
RDSon
(mΩ)
a
VGS = 4.4 V
100
4.6 V
2
5V
75
10 V
1
50
−60
25
Fig 9.
10
ID (A)
40
Drain-source on-state resistance as a function
of drain current; typical values
03ao16
10
60
120
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
03ao15
C
(pF)
8
Ciss
100 V
VDS = 40 V
180
Tj (°C)
104
ID = 25 A
Tj = 25 °C
VGS
(V)
160 V
6
Coss
4
102
Crss
2
QG (nC)
40
Fig 11. Gate-source voltage as a function of gate
charge; typical values
10
10-1
1
10
VDS (V)
102
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PHP33NQ20T_2
Product data sheet
8 of 13
PHP33NQ20T
Nexperia
03ao14
40
VGS = 0 V
IS
(A)
30
175 °C
Tj = 25 °C
0.6
0.9
VSD (V)
1.2
Fig 13. Source current as a function of source-drain voltage; typical values
PHP33NQ20T_2
Product data sheet
9 of 13
PHP33NQ20T
Nexperia
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
c
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig 14. Package outline SOT78 (TO-220AB)
PHP33NQ20T_2
Product data sheet
10 of 13
PHP33NQ20T
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHP33NQ20T_2
20090203
Product data sheet
PHP_PHB33NQ20T_1
Modifications:
PHP_PHB33NQ20T_1
(9397 750 14003)
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20041108
Product data sheet
PHP33NQ20T_2
Product data sheet
11 of 13
PHP33NQ20T
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PHP33NQ20T_2
Product data sheet
12 of 13
Nexperia
PHP33NQ20T
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Contact information. . . . . . . . . . . . . . . . . . . . . .12
Date of release: 03 February 2009
很抱歉,暂时无法提供与“PHP33NQ20T,127”相匹配的价格&库存,您可以联系我们找货
