PSMN8R5-100ESQ
PSMN8R5-100ESQ
    NEXPERIA(安世)
    SOT226
    MOS管 N-channel Id=100A VDS=100V SOT226
PSMN8R5-100ESQ 数据手册
PSMN8R5-100ES N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 11 October 2012 Product data sheet 1. Product profile 1.1 General description Standard level N-channel MOSFET in a I2PAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits • High efficiency due to low switching and conduction losses • Suitable for standard level gate drive sources 1.3 Applications • AC-to-DC power supply equipment • Motor control • Server power supplies • Synchronous rectification 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current Tj = 25 °C; VGS = 10 V; Fig. 1 - - 100 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - - 263 W VGS = 10 V; ID = 25 A; Tj = 25 °C; - 6.4 8.5 mΩ [1] Static characteristics RDSon drain-source on-state resistance Fig. 13; Fig. 12 Dynamic characteristics QGD gate-drain charge VGS = 10 V; ID = 25 A; VDS = 50 V; - 33 - nC QG(tot) total gate charge Fig. 14; Fig. 15 - 111 - nC VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; - - 219 mJ Avalanche Ruggedness EDS(AL)S non-repetitive drainsource avalanche energy [1] Vsup ≤ 100 V; RGS = 50 Ω; unclamped; Fig. 3 Continious current limited by package. PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 I2PAK (SOT226) 3. Ordering information Table 3. Ordering information Type number Package PSMN8R5-100ES Name Description Version I2PAK plastic single-ended package (I2PAK); TO-262 SOT226 4. Marking Table 4. Marking codes Type number Marking code PSMN8R5-100ES PSMN8R5-100ES 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 100 V VGS gate-source voltage -20 20 V ID drain current - 100 A VGS = 10 V; Tmb = 100 °C; Fig. 1 - 75 A VGS = 10 V; Tj = 25 °C; Fig. 1 [1] IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 4 - 429 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - 263 W Tstg storage temperature -55 175 °C PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 2 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK Symbol Parameter Tj Tsld(M) Conditions Min Max Unit junction temperature -55 175 °C peak soldering temperature - 260 °C - 100 A Source-drain diode IS source current Tmb = 25 °C ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 429 A VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; - 219 mJ [1] Avalanche Ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Vsup ≤ 100 V; RGS = 50 Ω; unclamped; Fig. 3 [1] Continious current limited by package. 003aak417 160 ID (A) 03aa16 120 Pder (%) 120 80 (1) 80 40 40 0 0 50 100 150 Tmb (°C) (1) Capped at 100A due to package Fig. 1. Continuous drain current as a function of mounting base temperature PSMN8R5-100ES Product data sheet 0 200 Fig. 2. 0 100 150 Tmb (°C) 200 Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 11 October 2012 50 © Nexperia B.V. 2017. All rights reserved 3 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 003aak418 103 IAL (A) 102 (1) 10 (2) 1 10-3 Fig. 3. 10-2 10-1 1 tAL (ms) 10 Avalanche rating; avalanche current as a function of avalanche time 003aak419 103 ID (A) Limit RDSon = V DS / ID tp =10 µ s 102 100 µ s 10 DC 1 ms 1 10 ms 100 ms 10-1 10-1 Fig. 4. 1 10 102 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 5 - 0.49 0.57 K/W PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 4 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 003aah108 1 δ = 0.5 Zth(j-mb) (K/W) 0.2 10-1 0.1 0.05 0.02 10 -2 10 -3 P single shot t tp 10-6 Fig. 5. 10-5 10-4 10-3 10-2 tp T δ= T 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration 7. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 90 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; 2.4 3 4 V Fig. 10; Fig. 11 gate-source threshold voltage 1 - - V Fig. 10 - - 4.5 V VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VDS = 100 V; VGS = 0 V; Tj = 100 °C - - 20 µA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 25 A; Tj = 175 °C; - - 22.6 mΩ - - 14.9 mΩ - 6.4 8.5 mΩ - 0.71 - Ω Static characteristics V(BR)DSS VGS(th) VGSth ID = 1 mA; VDS = VGS; Tj = 175 °C; ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 10 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 12 VGS = 10 V; ID = 25 A; Tj = 100 °C; Fig. 12 VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 13; Fig. 12 RG gate resistance PSMN8R5-100ES Product data sheet f = 1 MHz All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 5 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK Symbol Parameter Conditions Min Typ Max Unit total gate charge ID = 25 A; VDS = 50 V; VGS = 10 V; - 111 - nC QGS gate-source charge Fig. 14; Fig. 15 - 24 - nC QGS(th) pre-threshold gatesource charge - 16 - nC QGS(th-pl) post-threshold gatesource charge - 8 - nC QGD gate-drain charge - 33 - nC VGS(pl) gate-source plateau voltage ID = 15 A; VDS = 50 V; Fig. 14; Fig. 15 - 4.4 - V Ciss input capacitance VDS = 50 V; VGS = 0 V; f = 1 MHz; - 5512 - pF - 380 - pF - 256 - pF Dynamic characteristics QG(tot) Tj = 25 °C; Fig. 16; Fig. 17 Coss output capacitance VDS = 50 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 16 Crss reverse transfer capacitance VDS = 50 V; VGS = 0 V; f = 1 MHz; td(on) turn-on delay time VDS = 50 V; RL = 2 Ω; VGS = 10 V; - 20 - ns tr rise time RG(ext) = 5 Ω - 35 - ns td(off) turn-off delay time - 87 - ns tf fall time - 43 - ns Tj = 25 °C; Fig. 16; Fig. 17 Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 18 - 0.82 1.2 V trr reverse recovery time IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; - 53 - ns Qr recovered charge VDS = 50 V - 124 - nC PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 6 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 003aah739 240 6 VGS (V) = 10 ID (A) 003aak421 20 RDSon (mΩ ) 5.5 180 15 5 120 10 60 5 4.5 0 4 0 2 4 0 6 VDS(V) Tj = 25 °C; tp = 300 μs Fig. 6. Fig. 7. 003aak425 5 10 15 V (V) 20 GS Drain-source on-state resistance as a function of gate-source voltage; typical values Output characteristics; drain current as a function of drain-source voltage; typical values 120 0 003aah742 250 ID (A) gfs (S) 200 90 150 60 100 30 Tj = 25 °C 50 0 Fig. 8. Tj = 175 °C 0 80 160 240 320 ID (A) 0 400 Forward transconductance as a function of drain current; typical values PSMN8R5-100ES Product data sheet Fig. 9. 0 2 6 8 VGS (V) 10 Transfer characteristics; drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 11 October 2012 4 © Nexperia B.V. 2017. All rights reserved 7 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 003aah027 5 VGS(th) (V) ID (A) max 4 10-2 3 typ 10-3 2 min 10-4 0 60 120 T j (°C) 10-6 180 Fig. 10. Gate-source threshold voltage as a function of junction temperature 003aag818 3 20 1.8 15 1.2 10 0.6 5 60 120 Tj (°C) 0 180 Fig. 12. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN8R5-100ES Product data sheet max 2 4 6 VGS (V) Fig. 11. Sub-threshold drain current as a function of gate-source voltage 2.4 0 0 003aak422 25 RDSon (mΩ ) a 0 -60 typ min 10-5 1 0 -60 003aah028 10-1 4.5 5.5 5 6 VGS (V) = 10 0 80 160 ID (A) 240 Fig. 13. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 8 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 003aak426 10 VGS (V) VDS ID 8 VGS(pl) 20 V 6 80 V VGS(th) VDS = 50 V 4 VGS QGS1 QGS2 QGS 2 QGD QG(tot) 003aaa508 0 0 40 80 QG (nC) 120 Fig. 15. Gate charge waveform definitions Fig. 14. Gate-source voltage as a function of gate charge; typical values 003aak423 104 C (pF) 003aak424 12000 C (pF) Ciss Ciss 8000 103 Coss Crss 4000 Crss 102 10-1 1 10 VDS (V) 0 102 0 4 8 VGS (V) 12 Fig. 16. Input, output and reverse transfer capacitances Fig. 17. Input and reverse transfer capacitances as a as a function of drain-source voltage; typical function of gate-source voltage, typical values values PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 9 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 003aah749 400 IS (A) 320 240 160 Tj = 175° C 80 0 Tj = 25 °C 0 0.4 0.8 1.2 V SD (V) 1.6 Fig. 18. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 10 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 8. Package outline Plastic single-ended package (I2PAK); low-profile 3-lead TO-262 SOT226 A A1 E D1 mounting base D L1 Q b1 L 1 2 3 b e c e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1 c D max D1 E e L L1 Q mm 4.5 4.1 1.40 1.27 0.85 0.60 1.3 1.0 0.7 0.4 11 1.6 1.2 10.3 9.7 2.54 15.0 13.5 3.30 2.79 2.6 2.2 OUTLINE VERSION SOT226 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 06-02-14 09-08-25 TO-262 Fig. 19. Package outline I2PAK (SOT226) PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 11 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 9. Legal information 9.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN8R5-100ES Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 12 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 13 / 14 PSMN8R5-100ES Nexperia N-channel 100 V 8.5 mΩ standard level MOSFET in I2PAK 10. Contents 1 1.1 1.2 1.3 1.4 Product profile ....................................................... 1 General description .............................................. 1 Features and benefits ...........................................1 Applications .......................................................... 1 Quick reference data ............................................ 1 2 Pinning information ............................................... 2 3 Ordering information ............................................. 2 4 Marking ................................................................... 2 5 Limiting values .......................................................2 6 Thermal characteristics .........................................4 7 Characteristics ....................................................... 5 8 Package outline ................................................... 11 9 9.1 9.2 9.3 9.4 Legal information .................................................12 Data sheet status ............................................... 12 Definitions ...........................................................12 Disclaimers .........................................................12 Trademarks ........................................................ 13 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 October 2012 PSMN8R5-100ES Product data sheet All information provided in this document is subject to legal disclaimers. 11 October 2012 © Nexperia B.V. 2017. All rights reserved 14 / 14
PSMN8R5-100ESQ 价格&库存
很抱歉,暂时无法提供与“PSMN8R5-100ESQ”相匹配的价格&库存,您可以联系我们找货
