PSMN2R5-60PL
N-channel 60 V, 2.6 mΩ logic level MOSFET in SOT78
27 February 2013
Product data sheet
1. General description
Logic level N-channel MOSFET in SOT78 using TrenchMOS technology. Product design
and manufacture has been optimized for use in battery operated power tools.
2. Features and benefits
High efficiency due to low switching & conduction losses
Robust construction for demanding applications
Logic level gate
3. Applications
Battery-powered tools
Load switching
Motor control
Uninterruptible power supplies
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
60
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 1
150
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 2
349
W
VGS = 10 V; ID = 25 A; Tj = 25 °C;
2
2.6
mΩ
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Fig. 11
Dynamic characteristics
QG(tot)
QGD
total gate charge
VGS = 10 V; ID = 25 A; VDS = 48 V;
223
nC
gate-drain charge
Fig. 13; Fig. 14
41.2
nC
ID = 150 A; Vsup ≤ 60 V; RGS = 50 Ω;
521.7
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drainsource avalanche
energy
[1]
VGS = 10 V; Tj(init) = 25 °C; unclamped;
Fig. 3
Continuous current is limited by package.
PSMN2R5-60PL
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
3
S
source
Simplified outline
Graphic symbol
D
mb
G
mbb076
S
1 2 3
TO-220AB (SOT78)
6. Ordering information
Table 3.
Type number
Package
PSMN2R5-60PL
Name
Description
Version
TO-220AB
plastic single-ended package; heatsink mounted; 1 mounting
hole; 3-lead TO-220AB
SOT78
7. Marking
Table 4.
Marking codes
Type number
Marking code
PSMN2R5-60PL
PSMN2R5-60PL
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
60
V
VDGR
drain-gate voltage
RGS = 20 kΩ
60
V
VGS
gate-source voltage
-20
V
ID
drain current
IDM
peak drain current
PSMN2R5-60PL
Product data sheet
Tmb = 25 °C; VGS = 10 V; Fig. 1
[1]
150
A
Tmb = 100 °C; VGS = 10 V; Fig. 1
[1]
150
A
1002
A
Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 4
All information provided in this document is subject to legal disclaimers.
27 February 2013
Nexperia B.V. 2017. All rights reserved
2 / 13
PSMN2R5-60PL
Nexperia
Symbol
Parameter
Conditions
Min
Max
Unit
Ptot
Tmb = 25 °C; Fig. 2
349
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Tsld(M)
peak soldering temperature
260
°C
150
A
Source-drain diode
IS
source current
Tmb = 25 °C
ISM
peak source current
pulsed; tp ≤ 10 µs; Tmb = 25 °C
1002
A
521.7
mJ
[1]
EDS(AL)S
non-repetitive drain-source
avalanche energy
Fig. 3
[1]
003aak800
300
ID
(A)
250
03aa16
120
Pder
80
200
(1)
150
40
100
50
60
90
120
150
Tj (°C)
(1) Capped at 150A due to package
Fig. 1.
Continuous drain current as a function of
mounting base temperature
PSMN2R5-60PL
Product data sheet
Fig. 2.
150
Tmb (°C)
200
Normalized total power dissipation as a
function of mounting base temperature
27 February 2013
50
3 / 13
PSMN2R5-60PL
Nexperia
IAL
(A)
003aak801
103
(1)
102
(2)
10
1
10-3
Fig. 3.
10-2
10-1
1
tAL (ms)
10
Avalanche rating; avalanche current as a function of avalanche time
ID
(A)
003aak802
104
103
tp = 10 us
Limit RDSon = VDS / ID
102
100 us
DC
10
1 ms
10 ms
100 ms
1
10-1
10-1
Fig. 4.
1
10
VDS (V)
102
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 5
0.35
0.43
K/W
Rth(j-a)
thermal resistance
from junction to
ambient
60
K/W
PSMN2R5-60PL
Product data sheet
vertical in still air
27 February 2013
4 / 13
PSMN2R5-60PL
Nexperia
003aaf570
1
Zth(j-mb)
(K/W)
= 0.5
0.2
10-1
0.1
0.05
tp
T
P
10-2
0.02
10-3
10-6
Fig. 5.
t
tp
single shot
10-5
10-4
10-3
10-2
T
10-1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration.
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
60
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
54
V
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
1.4
1.7
2.1
V
2.45
V
0.5
V
VDS = 60 V; VGS = 0 V; Tj = 25 °C
0.08
1
µA
VDS = 60 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 16 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -16 V; VDS = 0 V; Tj = 25 °C
2
100
nA
2
2.6
mΩ
2.3
3.15
mΩ
5.6
mΩ
0.5
1
2
Ω
V(BR)DSS
VGS(th)
Fig. 9; Fig. 10
ID = 1 mA; VDS = VGS; Tj = -55 °C;
Fig. 9
ID = 1 mA; VDS = VGS; Tj = 175 °C;
Fig. 9
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
Fig. 11
VGS = 4.5 V; ID = 25 A; Tj = 25 °C;
Fig. 11
VGS = 10 V; ID = 25 A; Tj = 175 °C;
Fig. 12; Fig. 11
RG
gate resistance
PSMN2R5-60PL
Product data sheet
f = 1 MHz
27 February 2013
5 / 13
PSMN2R5-60PL
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 25 A; VDS = 48 V; VGS = 10 V;
223
nC
120
nC
QG(tot)
total gate charge
Fig. 13; Fig. 14
ID = 25 A; VDS = 48 V; VGS = 5 V;
Fig. 13; Fig. 14
QGS
gate-source charge
25.6
nC
QGD
gate-drain charge
Fig. 13; Fig. 14
41.2
nC
Ciss
input capacitance
VGS = 0 V; VDS = 25 V; f = 1 MHz;
11700 -
pF
Coss
output capacitance
Tj = 25 °C; Fig. 15
1025
pF
Crss
reverse transfer
capacitance
490
pF
td(on)
turn-on delay time
VDS = 25 V; RL = 1.8 Ω; VGS = 5 V;
71
ns
tr
rise time
RG(ext) = 5 Ω
119
ns
td(off)
turn-off delay time
224
ns
tf
fall time
128
ns
IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 16
0.77
1.2
V
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
53
ns
recovered charge
VDS = 25 V
98
nC
Qr
003aai159
360
VGS (V) = 10
ID
(A)
5
003aai160
10
3.5
RDSon
(mΩ )
270
7.5
3
180
5
2.8
90
2.6
2.4
2.2
1
1.5 V (V) 2
DS
Tj = 25 °C; tp = 300 μs
Fig. 6.
Fig. 7.
Output characteristics; drain current as a
function of drain-source voltage; typical values
PSMN2R5-60PL
Product data sheet
7.5 V (V) 10
GS
Drain-source on-state resistance as a function
of gate-source voltage; typical values
27 February 2013
2.5
6 / 13
PSMN2R5-60PL
Nexperia
003aag347
400
003aah025
3
VGS(th)
(V)
2.5
ID
(A)
max
300
2
typ
1.5
200
min
1
100
Fig. 8.
Tj = 175 °C
Tj = 25 ° C
2
4
0.5
VGS (V)
6
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
60
120
RDSon
(mΩ )
-2
180
003aai165
10
ID
(A)
Tj (° C)
Gate-source threshold voltage as a function of
003aah026
10-1
10
Fig. 9.
3
2.8
7.5
min
10-3
typ
max
5
10
-4
3.5
10-6
5
2.5
10-5
VGS (V) = 10
2
V GS (V)
Fig. 10. Sub-threshold drain current as a function of
gate-source voltage
PSMN2R5-60PL
Product data sheet
180
270 I (A) 360
D
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
27 February 2013
7 / 13
PSMN2R5-60PL
Nexperia
003aag821
2.4
VDS
a
ID
1.8
VGS(pl)
VGS(th)
1.2
VGS
QGS1
0.6
QGS2
QGS
QGD
QG(tot)
003aaa508
120
Tj (°C)
Fig. 13. Gate charge waveform definitions
180
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
003aag353
10
003aag349
105
VGS
(V)
C
(pF)
8
Ciss
104
6
14 V
4
VDS = 48 V
103
Coss
2
Crss
120
180
QG (nC)
102
10-1
240
Tj = 25 °C; ID = 25 A
Product data sheet
10
102
VDS (V)
103
VGS = 0 V; f = 1 MHz
Fig. 14. Gate-source voltage as a function of gate
charge; typical values
PSMN2R5-60PL
1
Fig. 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
27 February 2013
8 / 13
PSMN2R5-60PL
Nexperia
003aag354
300
IS
(A)
240
180
120
Tj = 175 °C
60
Tj = 25 °C
1
VSD (V)
1.5
VGS = 0 V
Fig. 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values
PSMN2R5-60PL
Product data sheet
27 February 2013
9 / 13
PSMN2R5-60PL
Nexperia
11. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
e
c
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig. 17. Package outline TO-220AB (SOT78)
PSMN2R5-60PL
Product data sheet
27 February 2013
10 / 13
PSMN2R5-60PL
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
12. Legal information
12.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PSMN2R5-60PL
Product data sheet
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
27 February 2013
11 / 13
PSMN2R5-60PL
Nexperia
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PSMN2R5-60PL
Product data sheet
27 February 2013
12 / 13
PSMN2R5-60PL
Nexperia
13. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................2
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
Package outline ................................................... 10
12
12.1
12.2
12.3
12.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 27 February 2013
PSMN2R5-60PL
Product data sheet
27 February 2013
13 / 13
