PMZB670UPE
20 V, single P-channel Trench MOSFET
Rev. 3 — 23 March 2012
Product data sheet
1. Product profile
1.1 General description
P-channel enhancement mode Field-Effect Transistor (FET) in a leadless ultra small
DFN1006B-3 (SOT883B) Surface-Mounted Device (SMD) plastic package using Trench
MOSFET technology.
1.2 Features and benefits
Very fast switching
ESD protection up to 2 kV
Low threshold voltage
Ultra thin package profile of 0.37 mm
Trench MOSFET technology
1.3 Applications
Relay driver
High-side loadswitch
High-speed line driver
Switching circuits
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
-20
V
VGS
gate-source voltage
-8
8
V
-680
mA
0.67
0.85
Ω
drain current
ID
VGS = -4.5 V; Tamb = 25 °C
[1]
Static characteristics
RDSon
[1]
drain-source on-state
resistance
VGS = -4.5 V; ID = -400 mA; Tj = 25 °C
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 1 cm2.
PMZB670UPE
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
G
gate
2
S
source
1
3
D
drain
2
Graphic symbol
D
3
Transparent
top view
G
DFN1006B-3
(SOT883B)
S
017aaa259
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
PMZB670UPE
DFN1006B-3
Leadless ultra small plastic package; 3 solder lands;
body 1.0 x 0.6 x 0.37 mm
SOT883B
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PMZB670UPE
0000 1011
[1]
For DFN1006B-3 (SOT883B) binary marking code description see Figure 1.
4.1 Binary marking code description
PIN 1 INDICATION
READING DIRECTION
READING EXAMPLE:
0111
1011
MARKING CODE
(EXAMPLE)
READING DIRECTION
006aac673
Fig 1.
PMZB670UPE
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
PMZB670UPE
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
-20
V
VGS
gate-source voltage
drain current
ID
total power dissipation
Ptot
8
V
-680
mA
VGS = -4.5 V; Tamb = 100 °C
[1]
-425
mA
Tamb = 25 °C; single pulse; tp ≤ 10 µs
peak drain current
IDM
-8
[1]
Tamb = 25 °C
-2.7
A
[2]
360
mW
[1]
715
mW
2700
mW
Tsp = 25 °C
Tj
junction temperature
-55
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
Source-drain diode
source current
IS
Tamb = 25 °C
[1]
-680
mA
HBM
[3]
2000
V
ESD maximum rating
electrostatic discharge voltage
VESD
[1]
[2]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
[3]
Measured between all pins.
017aaa123
120
Pder
Ider
80
80
40
40
−75
Fig 2.
017aaa124
120
−25
25
75
125
Normalized total power dissipation as a
function of junction temperature
PMZB670UPE
Product data sheet
−75
175
Tj (°C)
Fig 3.
−25
25
75
125
175
Tj (°C)
Normalized continuous drain current as a
3 of 15
PMZB670UPE
Nexperia
017aaa375
-10
ID
(A)
Limit RDSon = VDS/ID
-1
(1)
(2)
(3)
-10-1
(4)
(5)
-10-2
-10-1
-1
-10
-102
VDS (V)
IDM = single pulse
(1) tp = 1 ms
(2) DC; Tsp = 25 °C
(3) tp = 10 ms
(4) tp = 100 ms
(5) DC; Tamb = 25 °C; drain mounting pad 1 cm2
Fig 4.
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drain-source
voltage
PMZB670UPE
Product data sheet
4 of 15
PMZB670UPE
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
thermal resistance
from junction to
ambient
Rth(j-a)
Conditions
in free air
Min
Typ
Max
Unit
[1]
305
360
K/W
[2]
150
175
K/W
40
K/W
thermal resistance
from junction to solder
point
Rth(j-sp)
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
017aaa109
103
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.5
0.33
102
0.25
0.2
0.1
0.05
0.01
10
10−3
10−2
10−1
1
10
102
103
tp (s)
FR4 PCB, standard footprint
Fig 5.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
017aaa110
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.5
0.25
0.33
0.2
0.1
10−3
0.05
0.02
0.01
10−2
10−1
1
10
102
103
tp (s)
FR4 PCB, mounting pad for drain 1 cm2
Fig 6.
PMZB670UPE
Product data sheet
5 of 15
PMZB670UPE
Nexperia
7. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = -250 µA; VGS = 0 V; Tj = 25 °C
-20
V
VGSth
gate-source threshold
voltage
ID = -250 µA; VDS = VGS; Tj = 25 °C
-0.5
-0.9
-1.3
V
IDSS
drain leakage current
VDS = -20 V; VGS = 0 V; Tj = 25 °C
-1
µA
VDS = -20 V; VGS = 0 V; Tj = 150 °C
-10
µA
IGSS
gate leakage current
VGS = 8 V; VDS = 0 V; Tj = 25 °C
-2
µA
VGS = -8 V; VDS = 0 V; Tj = 25 °C
-2
µA
VGS = 4.5 V; VDS = 0 V; Tj = 25 °C
-0.5
µA
RDSon
gfs
resistance
forward
transconductance
VGS = -4.5 V; VDS = 0 V; Tj = 25 °C
-0.5
µA
0.67
0.85
Ω
VGS = -4.5 V; ID = -400 mA; Tj = 150 °C
1.1
1.4
Ω
VGS = -2.5 V; ID = -200 mA; Tj = 25 °C
1.2
1.5
Ω
VGS = -1.8 V; ID = -10 mA; Tj = 25 °C
1.8
2.8
Ω
VDS = -10 V; ID = -200 mA; Tj = 25 °C
610
mS
VDS = -10 V; ID = -400 mA;
VGS = -4.5 V; Tj = 25 °C
0.76
1.14
nC
0.28
nC
0.18
nC
58
87
pF
21
pF
12
pF
18
36
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VDS = -10 V; f = 1 MHz; VGS = 0 V;
Tj = 25 °C
VDS = -10 V; RL = 250 Ω; VGS = -4.5 V;
RG(ext) = 6 Ω; Tj = 25 °C
tr
rise time
30
ns
td(off)
turn-off delay time
80
160
ns
tf
fall time
72
ns
-0.48
-0.84
-1.2
V
Source-drain diode
VSD
source-drain voltage
PMZB670UPE
Product data sheet
IS = -300 mA; VGS = 0 V; Tj = 25 °C
6 of 15
PMZB670UPE
Nexperia
017aaa363
-0.5
-4.5 V
ID
(A)
-2.5 V
-2.0 V
017aaa364
-10-3
ID
(A)
-0.4
VGS = -1.8 V
-10-4
-0.3
(1)
(3)
(2)
-1.6 V
-0.2
-10-5
-1.4 V
-0.1
0.0
-2
-3
VDS (V)
-4
-10-6
0.0
Tj = 25 °C
-0.5
-1.0
VGS (V)
-1.5
Tj = 25 °C; VDS = -5 V
(1) minimum values
(2) typical values
(3) maximum values
Fig 7.
Output characteristics: drain current as a
function of drain-source voltage; typical values
017aaa365
4
RDSon
(Ω)
(2)
(1)
Fig 8.
Sub-threshold drain current as a function of
gate-source voltage
017aaa366
4
RDSon
(Ω)
(3)
3
3
2
2
(4)
1
(1)
1
(5)
(2)
-0.1
-0.2
-0.3
-0.4
ID (A)
-0.5
Tj = 25 °C
ID = -400 mA
(1) VGS = -1.5 V
(1) Tj = 150 °C
(2) VGS = -1.8 V
(2) Tj = 25 °C
-2
-3
-4
VGS (V)
-5
(3) VGS = -2.0 V
(4) VGS = -2.5 V
(5) VGS = -4.5 V
Fig 9.
Drain-source on-state resistance as a function
of drain current; typical values
PMZB670UPE
Product data sheet
Fig 10. Drain-source on-state resistance as a function
of gate-source voltage; typical values
7 of 15
PMZB670UPE
Nexperia
017aaa367
-0.5
ID
(A)
017aaa368
2.0
a
-0.4
1.5
-0.3
1.0
-0.2
(2)
(1)
0.5
-0.1
0.0
0.0
-0.5
-1.0
-1.5
VGS (V)
-2.0
0.0
-60
120
Tj (°C)
180
VDS > ID × RDSon
(1) Tj = 25 °C
(2) Tj = 150 °C
Fig 11. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
017aaa369
-1.5
Fig 12. Normalized drain-source on-state resistance as
a function of ambient temperature; typical
values
017aaa370
102
(1)
(1)
VGS(th)
(V)
C
(pF)
(2)
-1.0
(3)
(2)
10
(3)
-0.5
0.0
-60
120
Tj (°C)
180
1
-10-1
-1
ID = -0.25 mA; VDS = VGS
(1) maximum values
(1) Ciss
(2) typical values
(2) Coss
(3) minimum values
(3) Crss
Fig 13. Gate-source threshold voltage as a function of
PMZB670UPE
Product data sheet
-10
VDS (V)
-102
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
8 of 15
PMZB670UPE
Nexperia
017aaa371
-5
VDS
VGS
(V)
ID
-4
VGS(pl)
-3
VGS(th)
VGS
-2
QGS1
QGS2
QGS
-1
QGD
QG(tot)
017aaa137
0.2
0.4
0.6
QG (nC)
0.8
ID = -0.4 A; VDD = -10 V; Tamb = 25 °C
Fig 15. Gate-source voltage as a function of gate
charge; typical values
Fig 16. Gate charge waveform definitions
017aaa372
-0.5
IS
(A)
-0.4
-0.3
-0.2
(1)
(2)
-0.1
0.0
0.0
-0.2
-0.4
-0.6
-0.8
-1.0
VSD (V)
VGS = 0 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
Fig 17. Source current as a function of source-drain voltage; typical values
PMZB670UPE
Product data sheet
9 of 15
PMZB670UPE
Nexperia
8. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig 18. Duty cycle definition
9. Package outline
0.65
0.55
0.40
0.34
0.35
1
2
0.20
0.12
0.04 max
0.30
0.22
1.05
0.65
0.95
0.30
0.22
3
0.55
0.47
Dimensions in mm
11-11-02
Fig 19. Package outline DFN1006B-3 (SOT883B)
PMZB670UPE
Product data sheet
10 of 15
PMZB670UPE
Nexperia
10. Soldering
Footprint information for reflow soldering
SOT883B
1.3
0.7
R0.05 (8x)
0.9
0.6
0.7
0.25
(2x)
0.3
(2x)
0.3
0.4
(2x)
0.4
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
sot883b_fr
Fig 20. Reflow soldering footprint for DFN1006B-3 (SOT883B)
PMZB670UPE
Product data sheet
11 of 15
PMZB670UPE
Nexperia
11. Revision history
Table 8.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PMZB670UPE v.3
20120323
Product data sheet
PMZB670UPE v.2
Modifications:
1.2 “Features and benefits” is corrected.
PMZB670UPE v.2
20120207
Product data sheet
PMZB670UPE v.1
PMZB670UPE v.1
20120131
Product data sheet
PMZB670UPE
Product data sheet
12 of 15
PMZB670UPE
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1] [2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with theTerms and conditions of commercial sale of Nexperia.
PMZB670UPE
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
13 of 15
PMZB670UPE
Nexperia
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
13. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
PMZB670UPE
Product data sheet
14 of 15
Nexperia
PMZB670UPE
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Test information . . . . . . . . . . . . . . . . . . . . . . . . .10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12
Legal information. . . . . . . . . . . . . . . . . . . . . . . .13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Contact information. . . . . . . . . . . . . . . . . . . . . .14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 23 March 2012
