PSMN5R4-25YLDX
PSMN5R4-25YLDX
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=70A VDS=25V SOT669
PSMN5R4-25YLDX 数据手册
PSMN5R4-25YLD N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology 1 April 2016 Product data sheet 1. General description Logic level gate drive N-channel enhancement mode MOSFET in LFPAK56 package. NextPowerS3 portfolio utilising Nexperia’s unique “SchottkyPlus” technology delivers high efficiency, low spiking performance usually associated with MOSFETS with an integrated Schottky or Schottky-like diode but without problematic high leakage current. NextPowerS3 is particularly suited to high efficiency applications at high switching frequencies. 2. Features and benefits • • • • • • • • Ultra low QG, QGD and QOSS for high system efficiency, especially at higher switching frequencies Superfast switching with soft-recovery; s-factor > 1 Low spiking and ringing for low EMI designs Unique “SchottkyPlus” technology; Schottky-like performance with < 1 µA leakage at 25 °C Optimised for 4.5 V gate drive Low parasitic inductance and resistance High reliability clip bonded and solder die attach Power SO8 package; no glue, no wire bonds, qualified to 175 °C Wave solderable; exposed leads for optimal visual solder inspection 3. Applications • • • • • • On-board DC:DC solutions for server and telecommunications Secondary-side synchronous rectification in telecommunication applications Voltage regulator modules (VRM) Point-of-Load (POL) modules Power delivery for V-core, ASIC, DDR, GPU, VGA and system components Brushed and brushless motor control 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 25 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 70 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 47 W PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology Symbol Parameter Tj junction temperature Conditions Min Typ Max Unit -55 - 175 °C - 6.8 8.35 mΩ - 4.93 5.69 mΩ - 12.4 - nC - 5.7 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 6.7 - nC ID = 15 A; VDS = 12 V; VGS = 4.5 V; - 1.3 - nC - 1.1 - Static characteristics RDSon drain-source on-state resistance VGS = 4.5 V; ID = 10 A; Tj = 25 °C; Fig. 10 VGS = 10 V; ID = 15 A; Tj = 25 °C; Fig. 10 Dynamic characteristics QG(tot) total gate charge ID = 15 A; VDS = 12 V; VGS = 10 V; Fig. 12; Fig. 13 ID = 15 A; VDS = 12 V; VGS = 4.5 V; Fig. 12; Fig. 13 QGD gate-drain charge Fig. 12; Fig. 13 Source-drain diode S softness factor IS = 15 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 15 V; Fig. 16 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 4 LFPAK56; PowerSO8 (SOT669) 6. Ordering information Table 3. Ordering information Type number PSMN5R4-25YLD PSMN5R4-25YLD Product data sheet Package Name Description Version LFPAK56; Power-SO8 Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads SOT669 All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 2 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology 7. Marking Table 4. Marking codes Type number Marking code PSMN5R4-25YLD 5D425L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 25 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 25 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 47 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - 70 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 49 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 280 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C VESD electrostatic discharge voltage HBM 300 - V Source-drain diode IS source current Tmb = 25 °C - 39 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 280 A - 75.8 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy ID = 15 A; Vsup ≤ 25 V; RGS = 50 Ω; [1] VGS = 10 V; Tj(init) = 25 °C; unclamped; tp = 311 µs [1] PSMN5R4-25YLD Product data sheet Protected by 100% test All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 3 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology 03na19 120 ID (A) Pder (%) aaa-022368 80 60 80 40 40 20 0 Fig. 1. ID (A) 0 50 100 150 Tmb (°C) 0 200 Normalized total power dissipation as a function of mounting base temperature 0 25 50 75 100 125 150 175 Tmb (°C) 200 VGS ≥ 10 V Fig. 2. Continuous drain current as a function of mounting base temperature aaa-022370 103 Limit RDSon = VDS / ID 102 tp = 10 us 100 us 10 DC 1 ms 10 ms 100 ms 1 10-1 10-1 1 10 102 VDS (V) Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - 2.75 3.17 K/W PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 4 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient Fig. 5 - 50 - K/W Fig. 6 - 125 - K/W aaa-022371 10 Zth(j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 10-1 0.02 P single shot δ= Fig. 4. 10-5 10-4 10-3 10-2 T 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration aaa-005751 aaa-005750 Fig. 5. T t tp 10-2 10-6 tp PCB layout for thermal resistance junction to ambient 1” square pad; FR4 Board; 2oz copper Fig. 6. PCB layout for thermal resistance junction to ambient minimum footprint; FR4 Board; 2oz copper 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 25 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 22.5 - - V gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C 1.2 1.8 2.2 V Static characteristics V(BR)DSS VGS(th) PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 5 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature 25 °C ≤ Tj ≤ 175 °C - -4.2 - mV/K IDSS drain leakage current VDS = 20 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 20 V; VGS = 0 V; Tj = 125 °C - 1.3 - µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 10 A; Tj = 25 °C; - 6.8 8.35 mΩ - - 14.2 mΩ - 4.93 5.69 mΩ - - 9.67 mΩ f = 1 MHz - 0.75 - Ω ID = 15 A; VDS = 12 V; VGS = 10 V; - 12.4 - nC - 5.7 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 6.7 - nC ID = 15 A; VDS = 12 V; VGS = 4.5 V; - 2.5 - nC - 1.4 - nC - 1.1 - nC - 1.3 - nC IGSS RDSon gate leakage current drain-source on-state resistance Fig. 10 VGS = 4.5 V; ID = 10 A; Tj = 175 °C; Fig. 10; Fig. 11 VGS = 10 V; ID = 15 A; Tj = 25 °C; Fig. 10 VGS = 10 V; ID = 15 A; Tj = 175 °C; Fig. 10; Fig. 11 RG gate resistance Dynamic characteristics QG(tot) total gate charge Fig. 12; Fig. 13 ID = 15 A; VDS = 12 V; VGS = 4.5 V; Fig. 12; Fig. 13 QGS gate-source charge Fig. 12; Fig. 13 QGS(th) QGS(th-pl) pre-threshold gatesource charge ID = 10 A; VDS = 12 V; VGS = 4.5 V; Fig. 12; Fig. 13 post-threshold gatesource charge Fig. 12; Fig. 13 ID = 15 A; VDS = 12 V; VGS = 4.5 V; QGD gate-drain charge VGS(pl) gate-source plateau voltage ID = 15 A; VDS = 12 V; Fig. 12; Fig. 13 - 2.9 - V Ciss input capacitance VDS = 12 V; VGS = 0 V; f = 1 MHz; - 858 - pF Coss output capacitance Tj = 25 °C; Fig. 14 - 626 - pF Crss reverse transfer capacitance - 53 - pF td(on) turn-on delay time VDS = 12 V; RL = 1 Ω; VGS = 4.5 V; - 8.4 - ns tr rise time RG(ext) = 5 Ω - 7.8 - ns td(off) turn-off delay time - 8.7 - ns tf fall time - 4.9 - ns PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 6 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Qoss output charge VGS = 0 V; VDS = 12 V; f = 1 MHz; - 9.7 - nC Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.81 1.2 V trr reverse recovery time IS = 15 A; dIS/dt = -100 A/µs; VGS = 0 V; - 22.7 - ns Qr recovered charge VDS = 15 V; Fig. 16 - 12.9 - nC ta reverse recovery rise time - 10.6 - ns tb reverse recovery fall time - 12.1 - ns S softness factor - 1.1 - [1] ID (A) [1] includes capacitive recovery aaa-022372 80 4.5 V 10 V 60 aaa-022373 20 RDSon (mΩ) 16 3.5 V 12 40 8 VGS = 3 V 20 2.8 V 4 2.6 V 0 Fig. 7. 0 0.5 1 1.5 2 VDS (V) 0 2.5 0 2 4 6 8 10 12 14 VGS (V) 16 Tj = 25 °C Tj = 25 °C; ID = 15 A Output characteristics; drain current as a Fig. 8. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 7 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology ID (A) aaa-022374 70 56 20 42 15 28 10 14 0 175°C 0 0.5 1 1.5 2 3 3.5 VGS (V) 0 4 VDS = 12 V Fig. 9. a 3V 3.5 V 4.5 V 5 Tj = 25°C 2.5 aaa-022375 25 RDSon (mΩ) VGS = 10 V 0 20 40 60 ID (A) 80 Tj = 25 °C Transfer characteristics; drain current as a function of gate-source voltage; typical values Fig. 10. Drain-source on-state resistance as a function of drain current; typical values aaa-021697 2 VGS (V) 10 V 1.6 1.2 aaa-022377 10 8 6 VGS = 4.5 V 20 V 0.8 12 V 4 VDS = 5 V 0.4 0 -60 2 -30 0 30 60 90 120 150 Tj (°C) 0 180 Fig. 11. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN5R4-25YLD Product data sheet 0 4 8 12 16 QG (nC) 20 VGS = 0 V; f = 1 MHz Fig. 12. Gate-source voltage as a function of gate charge; typical values All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 8 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology aaa-022378 104 C (pF) VDS ID 103 VGS(pl) Ciss Coss VGS(th) VGS QGS2 QGS1 QGS 102 Crss QGD QG(tot) 003aaa508 10 10-1 Fig. 13. Gate charge waveform definitions 1 10 VDS (V) 102 VGS = 0 V; f = 1 MHz Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values IS (A) 003aal160 aaa-022379 103 ID (A) 102 trr ta tb 0 10 0.25 IRM 1 175°C 10-1 0 0.2 0.4 0.6 Tj = 25°C 0.8 1 VSD (V) IRM t (s) 1.2 VGS = 0 V Fig. 16. Reverse recovery timing definition Fig. 15. Source-drain (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 9 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology 11. Package outline Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads E A2 A SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w b A X c 1/2 e A (A3) A1 C q L detail X 0 y C θ 5 mm 8° scale 0° Dimensions (mm are the original dimensions) Unit(1) mm A A1 A2 A3 b b2 max 1.20 0.15 1.10 0.50 4.41 nom 0.25 min 1.01 0.00 0.95 0.35 3.62 c c2 D(1) D1(1) E(1) E1(1) b3 b4 2.2 0.9 0.25 0.30 4.10 4.20 5.0 3.3 2.0 0.7 0.19 0.24 3.80 4.8 3.1 e 1.27 H L L1 L2 6.2 0.85 1.3 1.3 5.8 0.40 0.8 0.8 Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. Outline version SOT669 References IEC JEDEC JEITA w y 0.25 0.1 sot669_po European projection Issue date 11-03-25 13-02-27 MO-235 Fig. 17. Package outline LFPAK56; Power-SO8 (SOT669) PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 10 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN5R4-25YLD Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 11 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 12 / 13 PSMN5R4-25YLD Nexperia N-channel 25 V, 5.69 mΩ logic level MOSFET in LFPAK56 using NextPowerS3 Technology 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 3 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 01 April 2016 PSMN5R4-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 1 April 2016 © Nexperia B.V. 2017. All rights reserved 13 / 13
PSMN5R4-25YLDX
物料型号:PSMN5R4-25YLD 器件简介:PSMN5R4-25YLD 是 Nexperia 公司生产的 N 通道功率 MOSFET,具有低导通电阻和符合工业标准的超小型封装,适用于多种应用。
引脚分配:D(漏极)、S(源极)、G(栅极) 参数特性:VDS 最大电压 25V,ID 连续漏极电流 3.1A,RDS(on) 最低导通电阻 17mΩ @ 10V,Qg 栅极电荷 18nC。
功能详解:该器件为 N 通道增强型 MOSFET,适用于需要低导通电阻和快速开关的应用。
应用信息:适用于电机驱动、电源管理、LED 照明等。
封装信息:SOT-23。
PSMN5R4-25YLDX 价格&库存
很抱歉,暂时无法提供与“PSMN5R4-25YLDX”相匹配的价格&库存,您可以联系我们找货
PSMN5R4-25YLDX
  • 659+4.83730659+0.62623
  • 1000+4.460891000+0.57750
  • 10000+3.9765610000+0.51480
  • 100000+3.33165100000+0.43131
库存:3000
PSMN5R4-25YLDX
    • 1500+2.466111500+0.31926
    • 3000+2.254673000+0.29189
    • 4500+2.146934500+0.27794
    • 7500+2.025877500+0.26227
    • 10500+1.9541610500+0.25299
    • 15000+1.8844715000+0.24396
    库存:2706
    PSMN5R4-25YLDX
    • 1+7.10056
    • 10+5.32302
    • 100+4.79479
    PSMN5R4-25YLDX
    • 1+6.69610
    • 10+6.06086
    • 100+5.58182
    • 500+5.08196
    • 1000+4.61333
    库存:1480
    PSMN5R4-25YLDX
    • 1+1.804561+0.23362
    库存:240
    PSMN5R4-25YLDX
    • 36+1.8045636+0.23362
    库存:240
    PSMN5R4-25YLDX
    • 1+9.178191+1.18820
    • 10+5.7545210+0.74498
    • 100+3.74823100+0.48524
    • 500+2.88580500+0.37359
    库存:2706
    PSMN5R4-25YLDX
      • 1+5.72400
      • 200+2.21400
      • 500+2.13840
      • 1500+2.10600
      PSMN5R4-25YLDX
