PSMN1R7-25YLDX
PSMN1R7-25YLDX
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=100A VDS=25V SOT669
PSMN1R7-25YLDX 数据手册
PSMN1R7-25YLD N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 19 April 2016 Product data sheet 1. General description Logic level gate drive N-channel enhancement mode MOSFET in LFPAK56 package. NextPowerS3 portfolio utilising Nexperia’s unique “SchottkyPlus” technology delivers high efficiency, low spiking performance usually associated with MOSFETS with an integrated Schottky or Schottky-like diode but without problematic high leakage current. NextPowerS3 is particularly suited to high efficiency applications at high switching frequencies. 2. Features and benefits • • • • • • • • • 100% Avalanche tested at I(AS) = 100 A Ultra low QG, QGD and QOSS for high system efficiency, especially at higher switching frequencies Superfast switching with soft-recovery Low spiking and ringing for low EMI designs Unique “SchottkyPlus” technology; Schottky-like performance with < 1 µA leakage at 25 °C Optimised for 4.5 V gate drive Low parasitic inductance and resistance High reliability clip bonded and solder die attach Power SO8 package; no glue, no wire bonds, qualified to 175 °C Wave solderable; exposed leads for optimal visual solder inspection 3. Applications • • • • • • On-board DC:DC solutions for server and telecommunications Secondary-side synchronous rectification in telecommunication applications Voltage regulator modules (VRM) Point-of-Load (POL) modules Power delivery for V-core, ASIC, DDR, GPU, VGA and system components Brushed and brushless motor control 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 25 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 100 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 135 W [1] PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology Symbol Parameter Conditions Tj junction temperature Min Typ Max Unit -55 - 175 °C - 1.53 1.75 mΩ - 2.03 2.42 mΩ - 46.7 - nC - 21.5 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 24.6 - nC ID = 25 A; VDS = 12 V; VGS = 4.5 V; - 5.1 - nC - 0.9 - Static characteristics RDSon drain-source on-state resistance VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 10 VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 10 Dynamic characteristics QG(tot) total gate charge ID = 25 A; VDS = 12 V; VGS = 10 V; Fig. 12; Fig. 13 ID = 25 A; VDS = 12 V; VGS = 4.5 V; Fig. 12; Fig. 13 QGD gate-drain charge Fig. 12; Fig. 13 Source-drain diode S softness factor IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 12 V; Fig. 16 [1] Continuous current is limited by package. 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 4 LFPAK56; PowerSO8 (SOT669) 6. Ordering information Table 3. Ordering information Type number PSMN1R7-25YLD PSMN1R7-25YLD Product data sheet Package Name Description Version LFPAK56; Power-SO8 Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads SOT669 All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 2 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 7. Marking Table 4. Marking codes Type number Marking code PSMN1R7-25YLD 1D725L PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 3 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 25 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 25 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 135 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 [1] - 100 A VGS = 10 V; Tmb = 100 °C; Fig. 2 [1] - 100 A - 860 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C VESD electrostatic discharge voltage 1400 - V - 100 A - 860 A - 746 mJ HBM Source-drain diode IS source current Tmb = 25 °C ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C [1] Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy ID = 25 A; Vsup ≤ 25 V; RGS = 50 Ω; [2] VGS = 10 V; Tj(init) = 25 °C; unclamped; tp = 1.84 ms [1] [2] PSMN1R7-25YLD Product data sheet Continuous current is limited by package. Protected by 100% test All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 4 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 03aa16 120 Pder (%) aaa-021692 250 ID (A) 200 80 150 100 (1) 40 50 0 Fig. 1. 0 50 100 150 Tmb (°C) 0 200 25 50 75 100 125 150 175 Tmb (°C) 200 VGS ≥ 10 V Normalized total power dissipation as a function of mounting base temperature (1) Capped at 100A due to package Fig. 2. ID (A) 0 Continuous drain current as a function of mounting base temperature aaa-021695 103 Limit RDSon = VDS / ID tp = 10 us 102 100 us 10 1 ms DC 10 ms 100 ms 1 10-1 10-1 1 10 VDS (V) 102 Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 5 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - 0.95 1.11 K/W Rth(j-a) thermal resistance from junction to ambient Fig. 5 - 50 - K/W Fig. 6 - 125 - K/W aaa-022079 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 10-1 0.1 0.05 0.02 P single shot δ= 10-2 Fig. 4. 10-5 10-4 10-3 10-2 T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration aaa-005751 aaa-005750 Fig. 5. T t tp 10-3 10-6 tp PCB layout for thermal impedance junction to ambient 1" square pad; FR4 Board; 2oz copper PSMN1R7-25YLD Product data sheet Fig. 6. PCB layout for thermal resistance junction to ambient minimum footprint; FR4 Board; 2oz copper All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 6 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 25 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 22.5 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C 1.2 1.8 2.2 V ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature 25 °C ≤ Tj ≤ 175 °C - -4.9 - mV/K IDSS drain leakage current VDS = 20 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 20 V; VGS = 0 V; Tj = 125 °C - 3.9 - µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; - 1.53 1.75 mΩ - - 2.98 mΩ - 2.03 2.42 mΩ - - 4.11 mΩ f = 1 MHz - 0.9 - Ω ID = 25 A; VDS = 12 V; VGS = 10 V; - 46.7 - nC - 21.5 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 24.6 - nC Static characteristics V(BR)DSS IGSS RDSon gate leakage current drain-source on-state resistance Fig. 10 VGS = 10 V; ID = 25 A; Tj = 175 °C; Fig. 10; Fig. 11 VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 10 VGS = 4.5 V; ID = 25 A; Tj = 175 °C; Fig. 10; Fig. 11 RG gate resistance Dynamic characteristics QG(tot) total gate charge Fig. 12; Fig. 13 ID = 25 A; VDS = 12 V; VGS = 4.5 V; Fig. 12; Fig. 13 QGS gate-source charge ID = 25 A; VDS = 12 V; VGS = 4.5 V; - 8.8 - nC QGS(th) pre-threshold gatesource charge Fig. 12; Fig. 13 - 5.1 - nC QGS(th-pl) post-threshold gatesource charge - 3.7 - nC QGD gate-drain charge - 5.1 - nC VGS(pl) gate-source plateau voltage - 2.9 - V PSMN1R7-25YLD Product data sheet ID = 25 A; VDS = 12 V; Fig. 12; Fig. 13 All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 7 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Ciss input capacitance VDS = 12 V; VGS = 0 V; f = 1 MHz; - 3415 - pF Coss output capacitance Tj = 25 °C; Fig. 14 - 1404 - pF Crss reverse transfer capacitance - 208 - pF td(on) turn-on delay time VDS = 12 V; RL = 0.6 Ω; VGS = 4.5 V; - 21.4 - ns tr rise time RG(ext) = 5 Ω - 25.4 - ns td(off) turn-off delay time - 21.6 - ns tf fall time - 14.3 - ns Qoss output charge - 25.4 - nC IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.81 1.2 V - 31.1 - ns - 25.1 - nC VGS = 0 V; VDS = 12 V; f = 1 MHz; Tj = 25 °C Source-drain diode VSD source-drain voltage trr reverse recovery time IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; Qr recovered charge VDS = 12 V; Fig. 16 ta reverse recovery rise time - 16.5 - ns tb reverse recovery fall time - 14.6 - ns S softness factor - 0.9 - [1] [1] includes capacitive recovery aaa-022080 150 ID (A) 3.5 V 120 10 V RDSon (mΩ) 4.5 V aaa-022081 6 5 4 90 VGS = 3 V 3 60 2 2.8 V 30 0 Fig. 7. 1 2.6 V 2.4 V 0 0.63 1.25 1.88 VDS (V) 0 2.5 0 2 4 6 8 10 12 14 VGS (V) 16 Tj = 25 °C Tj = 25 °C; ID = 25 A Output characteristics; drain current as a Fig. 8. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 8 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology aaa-021826 150 ID (A) 120 16 90 12 60 8 30 0 175°C 0 0.5 1 1.5 2 3 3.5 VGS (V) 0 4 VDS = 12 V Fig. 9. a 2.8 V 3V 3.5 V 4 Tj = 25°C 2.5 aaa-022082 20 RDSon (mΩ) 4.5 V VGS = 10 V 0 30 60 90 120 ID (A) 150 Tj = 25 °C Transfer characteristics; drain current as a function of gate-source voltage; typical values Fig. 10. Drain-source on-state resistance as a function of drain current; typical values aaa-021697 2 VGS (V) 10 V 1.6 1.2 aaa-022083 10 8 6 VGS = 4.5 V 20 V 0.8 12 V 4 VDS = 5 V 0.4 0 -60 2 -30 0 30 60 90 120 150 Tj (°C) 0 180 Fig. 11. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN1R7-25YLD Product data sheet 0 10 20 30 40 50 QG (nC) 60 Tj = 25 °C; ID = 25 A Fig. 12. Gate-source voltage as a function of gate charge; typical values All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 9 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology aaa-022084 104 C (pF) VDS ID Ciss Coss 103 VGS(pl) VGS(th) Crss VGS QGS2 QGS1 QGS 102 QGD QG(tot) 003aaa508 10 10-1 Fig. 13. Gate charge waveform definitions 1 10 VDS (V) 102 VGS = 0 V; f = 1 MHz Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values IS (A) 003aal160 aaa-022085 103 ID (A) 102 trr ta tb 0 10 0.25 IRM 1 175°C 10-1 0 0.2 0.4 0.6 Tj = 25°C 0.8 IRM 1 VSD (V) t (s) 1.2 VGS = 0 V Fig. 16. Reverse recovery timing definition Fig. 15. Source-drain (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 10 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 11. Package outline Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads E A2 A SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w b A X c 1/2 e A (A3) A1 C q L detail X 0 y C θ 5 mm 8° scale 0° Dimensions (mm are the original dimensions) Unit(1) mm A A1 A2 A3 b b2 max 1.20 0.15 1.10 0.50 4.41 nom 0.25 min 1.01 0.00 0.95 0.35 3.62 c c2 D(1) D1(1) E(1) E1(1) b3 b4 2.2 0.9 0.25 0.30 4.10 4.20 5.0 3.3 2.0 0.7 0.19 0.24 3.80 4.8 3.1 e 1.27 H L L1 L2 6.2 0.85 1.3 1.3 5.8 0.40 0.8 0.8 Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. Outline version SOT669 References IEC JEDEC JEITA w y 0.25 0.1 sot669_po European projection Issue date 11-03-25 13-02-27 MO-235 Fig. 17. Package outline LFPAK56; Power-SO8 (SOT669) PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 11 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN1R7-25YLD Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 12 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 13 / 14 PSMN1R7-25YLD Nexperia N-channel 25 V, 1.75 mΩ, 170 A logic level MOSFET in LFPAK56 using NextPowerS3 Technology 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 3 8 Limiting values .......................................................4 9 Thermal characteristics .........................................6 10 Characteristics ....................................................... 7 11 Package outline ................................................... 11 12 12.1 12.2 12.3 12.4 Legal information .................................................12 Data sheet status ............................................... 12 Definitions ...........................................................12 Disclaimers .........................................................12 Trademarks ........................................................ 13 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 April 2016 PSMN1R7-25YLD Product data sheet All information provided in this document is subject to legal disclaimers. 19 April 2016 © Nexperia B.V. 2017. All rights reserved 14 / 14
PSMN1R7-25YLDX 价格&库存
很抱歉,暂时无法提供与“PSMN1R7-25YLDX”相匹配的价格&库存,您可以联系我们找货
PSMN1R7-25YLDX
  • 1+15.19379
  • 10+13.63172
  • 100+12.56951
  • 500+11.70516
  • 1000+10.48674
库存:1500
PSMN1R7-25YLDX
  • 1+21.400381+2.77980
  • 10+17.1377010+2.22610
  • 100+12.78803100+1.66110
PSMN1R7-25YLDX
  • 1500+4.90492
库存:1500
PSMN1R7-25YLDX
  • 1+19.495441+2.53236
  • 10+12.4619410+1.61875
  • 50+9.4119950+1.22257
  • 100+8.42954100+1.09496
  • 500+6.70466500+0.87091
库存:1500
PSMN1R7-25YLDX
  • 1500+5.867051500+0.76210
  • 4500+5.230794500+0.67946
库存:1500
PSMN1R7-25YLDX
    PSMN1R7-25YLDX
    • 1+19.93139
    • 10+15.93074
    • 100+11.91811
