BUK9615-100A
N-channel TrenchMOS logic level FET
Rev. 3 — 19 April 2011
Product data sheet
1. Product profile
1.1 General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
AEC Q101 compliant
Low conduction losses due to low
on-state resistance
1.3 Applications
Automotive and general purpose
power switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
VDS
Conditions
Min
Typ
Max
Unit
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
100
V
ID
drain current
75
A
Ptot
total power
dissipation
230
W
Tj
junction temperature
-55
175
°C
VGS = 10 V; ID = 25 A;
Tj = 25 °C
11.5
14.4
mΩ
VGS = 5 V; ID = 25 A;
Tj = 25 °C
12
15
mΩ
ID = 35 A; Vsup ≤ 25 V;
RGS = 50 Ω; VGS = 5 V;
Tj(init) = 25 °C; unclamped
120
mJ
Tmb = 25 °C
Static characteristics
RDSon
drain-source
on-state resistance
Avalanche ruggedness
EDS(AL)S
non-repetitive
drain-source
avalanche energy
BUK9615-100A
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base;
connected to drain
Simplified outline
Graphic symbol
mb
D
G
mbb076
S
2
1
3
SOT404 (D2PAK)
3. Ordering information
Table 3.
Type number
Package
BUK9615-100A
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404
(one lead cropped)
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
100
V
VDGR
drain-gate voltage
RGS = 20 kΩ
100
V
VGS
gate-source voltage
ID
drain current
-10
10
V
Tmb = 25 °C
75
A
Tmb = 100 °C
53
A
313
A
IDM
peak drain current
Tmb = 25 °C; pulsed
Tmb = 25 °C
Ptot
total power dissipation
230
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
VGSM
peak gate-source voltage
pulsed; tp ≤ 50 µs
-15
15
V
Source-drain diode
IS
source current
Tmb = 25 °C
75
A
ISM
peak source current
pulsed; Tmb = 25 °C
313
A
ID = 35 A; Vsup ≤ 25 V; RGS = 50 Ω;
VGS = 5 V; Tj(init) = 25 °C; unclamped
120
mJ
EDS(AL)S
non-repetitive drain-source
avalanche energy
BUK9615-100A
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
BUK9615-100A
Nexperia
003aaf364
100
Pder
80
003aaf365
100
ID
80
60
60
40
40
100
150
200
80
120
160
200
Tmb (°C)
Tmb (°C)
VGS ≥ 5 V
Fig 1.
Normalized total power dissipation as a
function of mounting base temperature
003aaf379
100
WDSS
80
Fig 2.
Normalized continuous drain current as a
003aaf380
102
lAV
25 °C
60
10
40
Tj prior to avalanche = 150 °C
10−3
100
140
180
10−2
10−1
1
unclamped inductive load
ID = 75 A
Fig 3.
Normalised drain-source non-repetitive
avalanche energy as a function of
mounting-base temperature
BUK9615-100A
Product data sheet
10
tAV (ms)
Tmb (°C)
Fig 4.
Single-shot avalanche rating; avalanche
current as a function of avalanche period
3 of 13
BUK9615-100A
Nexperia
003aaf366
103
ID
(A)
Limit RDSon = VDS / ID
tp =10 μ s
102
100 μ s
10
1 ms
DC
1
10 ms
100 ms
10-1
1
102
10
103
V DS (V)
Tmb = 25 °C; IDM is single pulse
Fig 5.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Rth(j-mb)
thermal resistance from
junction to mounting base
Rth(j-a)
junction to ambient
minimum footprint; FR4 board
Typ
Max
Unit
0.65
K/W
50
K/W
003aaf367
1
Zth(j-mb)
(K/W)
Min
δ = 0.5
0.2
10−1
0.1
0.05
δ=
P
0.02
10−2
t
tp
10−3
T
10−6
Fig 6.
tp
T
10−5
10−4
10−3
10−2
10−1
1
10
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK9615-100A
Product data sheet
4 of 13
BUK9615-100A
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
100
V
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
89
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C
1
1.5
2
V
ID = 1 mA; VDS = VGS; Tj = -55 °C
2.3
V
ID = 1 mA; VDS = VGS; Tj = 175 °C
0.5
V
VDS = 100 V; VGS = 0 V; Tj = 175 °C
500
µA
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 4.5 V; ID = 25 A; Tj = 25 °C
16
mΩ
VGS = 5 V; ID = 25 A; Tj = 175 °C
40.5
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C
11.5
14.4
mΩ
VGS = 5 V; ID = 25 A; Tj = 25 °C
12
15
mΩ
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C
6500
8600
pF
550
660
pF
325
400
pF
45
65
ns
130
195
ns
400
560
ns
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
drain-source on-state
resistance
Dynamic characteristics
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
tf
fall time
LD
internal drain
inductance
LS
internal source
inductance
VDS = 30 V; RL = 1.2 Ω; VGS = 5 V;
RG(ext) = 10 Ω; Tj = 25 °C
130
190
ns
measured from upper edge of drain tab
to centre of die; Tj = 25 °C
2.5
nH
measured from drain lead 6 mm from
package to centre of die; Tj = 25 °C
4.5
nH
measured from source lead to source
bond pad; Tj = 25 °C
7.5
nH
IS = 75 A; VGS = 0 V; Tj = 25 °C
1.1
V
IS = 25 A; VGS = 0 V; Tj = 25 °C
0.85
1.2
V
IS = 75 A; dIS/dt = -100 A/µs;
VGS = -10 V; VDS = 30 V; Tj = 25 °C
60
ns
0.24
µC
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
Qr
recovered charge
BUK9615-100A
Product data sheet
5 of 13
BUK9615-100A
Nexperia
003aaf368
250
ID
(A)
200
VGS (V) = 10
5
003aaf369
19
RDS(on)
(mΩ)
4.0
3.8
3.6
VGS (V) = 3.0
3.2
3.4
3.6
4.0
5.0
17
3.4
150
3.2
15
3.0
100
2.8
13
2.6
2.4
50
11
4
6
8
10
60
80
VDS (V)
Tj = 25 °C
Fig 7.
100
ID (A)
Tj = 25 °C
Output characteristics: drain current as a
function of drain-source voltage; typical values
003aaf370
14.5
Fig 8.
Drain-source on-state resistance as a function
of drain current; typical values
003aaf371
100
ID
(A)
80
RDS(on)
(mΩ)
13.5
60
12.5
40
11.5
Tj = 175 °C
10.5
Tj = 25 °C
5
7
9
11
2
3
VGS (V)
Tj = 25 °C
Fig 9.
VDS > ID x RDSon
of gate-source voltage; typical values
BUK9615-100A
Product data sheet
4
VGS (V)
Fig 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
6 of 13
BUK9615-100A
Nexperia
003aaf372
150
003aaf373
3
a
gfs
(S)
2.5
100
2
1.5
50
1
60
80
100
ID (A)
0.5
−100
200
Tmb (°C)
VDS > ID x RDSon
ID = 25 A; VGS = 5 V
Fig 11. Forward transconductance as a function of
003aaf374
2.5
VGS(th)
(V)
2
maximum
10−1
ID
(A)
10−2
typical
10−3
minimum
10−4
1.5
1
Fig 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
003aaf375
typical
2%
98 %
10−5
0.5
−100
10−6
200
2
3
Tj = 25 °C; VDS = VGS
Fig 13. Gate-source threshold voltage as a function of
Product data sheet
1
VGS (V)
BUK9615-100A
Tj (°C)
Fig 14. Sub-threshold drain current as a function of
gate-source voltage
7 of 13
BUK9615-100A
Nexperia
003aaf376
003aaf377
5
VGS
(V)
C
(nF)
Ciss
15
4
VDS = 14 V
3
VDS = 80 V
Coss
10
Crss
2
5
1
10−2
10−1
1
102
10
60
80
100
QG (nC)
VDS (V)
VGS = 0 V; f = 1 MHz
Tj = 25 °C; ID = 25 A
Fig 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
BUK9615-100A
Product data sheet
Fig 16. Gate-source voltage as a function of gate
charge; typical values
8 of 13
BUK9615-100A
Nexperia
7. Package outline
SOT404
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
c
b
e
e
Q
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
max.
D1
E
e
Lp
HD
Q
mm
4.50
4.10
1.40
1.27
0.85
0.60
0.64
0.46
11
1.60
1.20
10.30
9.70
2.54
2.90
2.10
15.80
14.80
2.60
2.20
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-02-11
06-03-16
SOT404
Fig 17. Package outline SOT404 (D2PAK)
BUK9615-100A
Product data sheet
9 of 13
BUK9615-100A
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK9615-100A v.3
20110419
Product data sheet
BUK9515_9615-100A_2
Modifications:
BUK9515_9615-100A_2
BUK9615-100A
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type number BUK9615-100A separated from data sheet BUK9515_9615-100A_2.
19991101
Product specification
BUK9515-100A_1
10 of 13
BUK9615-100A
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
BUK9615-100A
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. The product is not designed, authorized or warranted to be
suitable for use in medical, military, aircraft, space or life support equipment,
nor in applications where failure or malfunction of a Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia accepts no
liability for inclusion and/or use of Nexperia products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
11 of 13
BUK9615-100A
Nexperia
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK9615-100A
Product data sheet
12 of 13
Nexperia
BUK9615-100A
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Contact information. . . . . . . . . . . . . . . . . . . . . .12
Date of release: 19 April 2011
很抱歉,暂时无法提供与“BUK9615-100A,118”相匹配的价格&库存,您可以联系我们找货
