X321532768KGB2SI
X321532768KGB2SI
    YXC(扬兴科技)
    SMD3215_2P
    无源晶振 12.5pF 70KΩ ±10ppm -40℃~+85℃ SMD3215_2P 32.768KHz
X321532768KGB2SI 数据手册
YST310S Features . External dimensions: 3.2 x 1.5 x 0.75 mm. X X 2 X 3 C Y X .Frequency range: 32.768KHz. . 2 pads surface mount package. .A pplication for NB, Smart Phone, variety of compact portable consumer products reference clocks. .High reliable environmental performance. Electrical Specifications Item / Type YST310S 32.768 KHz Vibration Mode AT Fundamental Re ar m rk : : Sp Nominal Frequency Range Load Capacitance 12.5 pF , or specify Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 20 ppm, or specify Operating Temperature – 40 ~ + 85 ℃ Storage Temperature – 55 ~ +125 ℃ Shunt Capacitance 1.5pF typical Level Of Drive 0.1 μW Max. Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Insulation Resistance 500 MΩ Min. Motional Capacitance 6.7pF typical Turnover Temperature 25 ℃ ± 5 ℃ Parabolic Coefficient ( - 0.03 ± 0.01 ) * 10-6 / ℃2 Equivalent Series Resistance(ESR) Fundamental 70 KΩ Max Dimensions YXC32XXX Units: mm come visit our site http://www.yxc.hk 1/2 YST310S ★ PART NUMBER GUIDE 部件号示例 Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 32768K 3215 Frequency Stability Overall (ppm) G ★ TAPING SPECIFICATION (Unit: mm) 4.0 YST310S =3.2 ×1.5 SMD SEAM TYPE e.g. X3215327 68 K G D2SI Pin Material Operating Temp. Range 2 S I D 编带规格 φ1.50 1.1 12 0° φ13 5.1 C B D SMD3215 G A F E A B C 180±2.0 12.0±0.3 D 3.45±0.10 1.75±0.10 E F G 3.84±0.1 1.0 ±0.10 60.0±1.0 3000 pcs per reel ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ come visit our site http://www.yxc.hk 2/2 120sec. max
X321532768KGB2SI
物料型号为 YST310S,是一款32.768KHz的晶振。
器件简介包括外部尺寸为3.2×1.5×0.75mm,适用于笔记本电脑、智能手机和各种便携式消费产品。
引脚分配为2个焊盘表面贴装。
参数特性包括标称频率范围32.768KHz,负载电容12.5pF,频率容差±10ppm或20ppm,工作温度-40至+85°C,存储温度-55至+125°C。
功能详解包括高可靠性的环境性能和电气规格。
应用信息为参考时钟,封装信息为3.2±0.1mm的尺寸,建议的布局图和编带规格也已提供。
回流焊焊接曲线包括无铅回流,预热160~180°C最长120秒,主加热220°C最长60秒,峰值260°C最长10秒。
更多信息可访问官网 http://www.yxc.hk。
X321532768KGB2SI 价格&库存
很抱歉,暂时无法提供与“X321532768KGB2SI”相匹配的价格&库存,您可以联系我们找货
