YST310S
Features
. External dimensions: 3.2 x 1.5 x 0.75 mm.
X X
2 X
3
C
Y X
.Frequency range: 32.768KHz.
. 2 pads surface mount package.
.A
pplication for NB, Smart Phone, variety of compact portable
consumer products reference clocks.
.High reliable environmental performance.
Electrical Specifications
Item / Type
YST310S
32.768 KHz
Vibration Mode
AT Fundamental
Re ar
m rk :
: Sp
Nominal Frequency Range
Load Capacitance
12.5 pF , or specify
Frequency Tolerance (at 25 ℃)
± 10 ppm, ± 20 ppm, or specify
Operating Temperature
– 40 ~ + 85 ℃
Storage Temperature
– 55 ~ +125 ℃
Shunt Capacitance
1.5pF typical
Level Of Drive
0.1 μW Max.
Frequency Aging (at 25 ℃)
± 3 ppm / year Max.
Insulation Resistance
500 MΩ Min.
Motional Capacitance
6.7pF typical
Turnover Temperature
25 ℃ ± 5 ℃
Parabolic Coefficient
( - 0.03 ± 0.01 ) * 10-6 / ℃2
Equivalent Series Resistance(ESR)
Fundamental
70 KΩ Max
Dimensions
YXC32XXX
Units: mm
come visit our site http://www.yxc.hk
1/2
YST310S
★ PART NUMBER GUIDE 部件号示例
Quartz Crystal Resonator Dimensions Frequency Load Capacitance
(Hz)
(Pf)
X
32768K
3215
Frequency
Stability
Overall
(ppm)
G
★ TAPING SPECIFICATION (Unit: mm)
4.0
YST310S =3.2 ×1.5 SMD SEAM TYPE
e.g. X3215327 68 K G D2SI
Pin
Material
Operating Temp.
Range
2
S
I
D
编带规格
φ1.50
1.1
12
0°
φ13
5.1
C
B
D
SMD3215
G
A
F
E
A
B
C
180±2.0
12.0±0.3
D
3.45±0.10
1.75±0.10
E
F
G
3.84±0.1
1.0 ±0.10
60.0±1.0
3000 pcs per reel
★ REFLOW SOLDERING PROFILE 回流焊特性
Temperature (℃)
260℃ max
220℃
180℃
③
①
②
Times (S)
Pb free reflow
A
①
Preheat
160~180℃
②
Primary heat 220℃
60sec. max
③
Peak
10sec. max.
260℃
2/2
120sec. max
很抱歉,暂时无法提供与“X321532768KGD2SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.85680
- 30+0.82530
- 100+0.76230
- 500+0.69930
- 1000+0.66780
- 国内价格
- 5+1.19140
- 50+1.01490
- 150+0.88000
- 500+0.82550
- 1000+0.77730
- 3000+0.73440
- 国内价格
- 10+3.03630
- 100+1.81120
- 800+1.26790
- 3000+0.90560
- 6000+0.86030
- 30000+0.79690
