Sunlord
Specifications for Multi-layer Chip Ferrite Beads
Page 1 of 10
Sunlord
S P E C I F I C AT I O N S
Customer
Product Name
Sunlord Part Number
PZ2012D600-3R0TF
Customer Part Number
New Released,
Revised]
SPEC No.: PZ201260
Rev.
Effective Date
Changed Contents
Change reasons
Approved By
01
New release
Hai Guo
【 This SPEC is total 10 pages.】
【RoHS Compliant Parts】
Approved By
Checked By
Issued By
Shenzhen Sunlord Electronics Co., Ltd.
Address:Sunlord Industrial Park,Dafuyuan Industrial Zone,Guanlan,Shenzhen,China 518110
Tel: 0086-755-82400574
Fax:0086-755-82269029
E-Mail:sunlord@sunlordinc.com
【For Customer approval Only】
Qualification Status:
Full
Approved By
Comments:
Verified By
Date:
Restricted
Rejected
Re-checked By
Checked By
Sunlord
Page 2 of 10
Table of Contents
1.
Scope
2.
Reference Documents
3
3
3.
Product Descriptions and Identification (Part Number)
3
4.
Electrical Characteristics
3
5.
Shape and Dimensions
4
6.
Test and Measurement Procedures
4~6
6.1 Test Conditions
6.2 Visual Examination
6.3 Electrical Test
6.3.1
DC Resistance
6.3.2
Impedance
6.3.3
Rated Current
6.4 Reliability Test
7.
6.4.1
Teminal Strength
6.4.2
Resistance to Flexure
6.4.3
Vibration
6.4.4
Dropping
6.4.5
Temperature Characteristics
6.4.6
Solderability
6.4.7
Resistance to Soldering Heat
6.4.8
Thermal Shock
6.4.9
Resistance to Low Temperature
6.4.10
Resistance to High Temperature
6.4.11
Damp Heat (Steady State)
6.4.12
Loading Under Dampe Heat
6.4.13
Loading at High Temperature(Life Test)
Packaging Storage and Transportation
7.1 Packaging
7.2 Storage
7.3 Transportation
7.4 General Handing Precautions
7.5 Precautions on Use
8.
Packaging Documents and Marking
8.1 Packaging Documents
8.2 Marking
9.
Recommended Soldering Technologies
9.1 RE-flowing Profile
9.2 Iron Soldering Profile
9.3 Solder Volume
9.4 Attention Regarding PCB Bending
9.5 Cleaning
10. Supplier Information
4
4
4~5
4
4
5
5~6
5
5
5
5
5
5
6
6
6
6
6
6
6
6~8
6~7
8
8
8
8
8~9
8
8~9
9~10
9
9
9
10
10
10
Sunlord
1.
2.
3.
①
②
Type
PZ
③
External Dimensions(L X W) [mm]
For Large current
2012 [0805]
④
Material Code
D
⑤
2.0 X 1.25
Nominal Impedance
Example
Nominal Value
600
60 Ω
Rate Current
3R0
⑦
3.0 A
⑥
Packing
HSF Products
Hazardous Substance Free Products
4.
Page 3 of 10
Scope
This specification applies to PZ2012D600-3R0TF multi-layer ferrite chip beads.
Applied Documents
EIA/IS-759
Multi-layer Chip Bead Qualification Specification.
MIL-STD-202 Test Methods for Electronic and Electrical Chip Parts.
IEC-68
Test Methods for Environmental Testing.
Product Description and Identification (Part Number)
1) Description:
Ferrite Bead,2012,60Ohm@ 100MHz,0.02Ohm RDC,3000mA
2) Product Identification (Part Number)
PZ
2012
D
600 -3R0 T
F
①
②
③
④
⑤
⑥
⑦
B
Bulk Package
T
Tape Carrier Package
Part Number
Impedance (Ω)
PZ2012D600
60±25%
Z Test Freq.(MHz)
DCR (Ω) Max.
100
Ir (mA) Max.
0.02
3000
Impedance Frequency Characteristics
PZ2012D600
150
Impedance(Ω)
120
90
Z
R
60
30
X
10
100
1000
Frequency(MHz)
1)
2)
Operating and storage temperature range (individual chip without packing)::-40℃ to +85℃
Storage temperature range (packaging conditions):-10℃~+40℃ and RH 70% (Max.)
Sunlord
5.
Page 4 of 10
1) Dimensions and recommended PCB pattern for reflow soldering: See Fig.5-1, Fig.5-2 and Table 5-1
2) Structure: See Fig. 5-3 and Fig. 5-4
Chip Bead
Solder-resist
C
Land pattern
B
Fig. 5-1
[Table 5-1]
T
Type
L
W
2012
[0805]
2.0 (+0.3, -0.1)
[0.079 (+0.012, -0.004)]
1.25±0.2
[0.049±0.008]
②
③
Fig. 5-3
④
0.80~
0.80~
0.90~
1.20
1.20
1.60
① Ferrite for Bead Series
Ferrite
Sn
W
①
0.5±0.3
[0.020±0.012]
④-2
Ni
④-1
Ag
③ Pull out electrode( Ag)
④-1 Terminal electrode :Inside (Ag)
④-2 Outside (Electro-plating Ni-Sn)
Fig. 5-4
Material Information
6.
C
② Internal electrode (Ag)
T
a
Unit: mm [inch]
A
B
a
Structure of
Electro-plating
T
L
a
0.85±0.2
[0.033±0.008]
A
B
Fig. 5-2
Code
Part Name
Material Name
①
②
③
Ferrite Body
Inner Coils
Pull-out Electrode (Ag)
Ferrite Powder
Silver Paste
Silver Paste
Termination Silver
Composition
Plating Chemicals
④-1
Terminal Electrode: Inside Ag
④-2
Electro-Plating: Ni/Sn plating
6.1 Test Conditions
Unless otherwise specified, the standard atmospheric conditions for measurement/test as:
a. Ambient Temperature: 20±15℃
b. Relative Humidity: 65±20%
c. Air Pressure: 86 KPa to 106 KPa
If any doubt on the results, measurements/tests should be made within the following limits:
a. Ambient Temperature: 20±2℃
b. Relative Humidity: 65±5%
c. Air Pressure: 86KPa to 106 KPa
a. Inspection Equipment: 20 X magnifier
6.3 Electrical Test
6.3.1 DC Resistance (DCR)
a. Refer to Item 4.
b. Test equipment (Analyzer): High Accuracy Milliohmmeter-HP4338B
6.3.2 Impedance (Z)
a. Refer to Item 4.
b. Test equipment:High Accuracy RF Impedance /Material Analyzer-HP4291B+16192A
c. Test signal: -20dBm or 50mV
d. Test frequency refers to Item 4.
Sunlord
Page 5 of 10
6.3.3 Rated Current
a. Refer to Item 4.
b. Test equipment (see Fig.6.3.3-1): Electric Power, Electric current meter, Thermometer.
c. Measurement method (see Fig. 6.3.3-1):
1. Set test current to be 0 mA.
2. Measure initial temperature of chip surface.
3. Gradually increase voltage and measure chip temperature for corresponding current.
d. Definition of Rated Current(IDC): IDC is direct electric current as chip surface temperature rose just 20℃
against chip initial surface temperature(Ta). (see Fig. 6.3.3-2):
Thermometer
Electric Power
+20
Electric
Ta
Current Meter
Chip
R
Rated current
Requirements
Test Methods and Remarks
No removal or split of the termination or
other defects shall occur.
Chip
F
Mounting Pad
6.4.2
Resistance to
Flexure
Glass Epoxy Board
Fig.6.4.1-1
No visible mechanical damage.
Unit: mm [inch]
Type
2012[0805]
a
1.2
b
c
4.0
1.65
b
100
Fig.6.4.2-1
① No visible mechanical damage.
② Impedance change: within ±20%
Cu pad
①
Solder the bead to the test jig (glass epoxy board
shown in Fig.6.4.2-1) Using a eutectic solder. Then apply a
force in the direction shown Fig. 6.4.2-2.
②
Flexure: 2mm
③
Pressurizing Speed: 0.5mm/sec.
④
Keep time: 30 sec.
Φ4.5
c
a
6.4.3 Vibration
①
Solder the bead to the testing jig (glass
epoxy board shown in Fig.6.4.1-1) using eutectic solder.
Then apply a force in the direction of the arrow.
②
10N force for 2012 series.
③
Keep time: 10±1s
④
Speed:1.0mm/s.
Solder mask
6.4.4
Dropping
Glass Epoxy Board
Fig. 6.4.3-1
6.4.5
Temperature
6.4.6
Solderability
Impedance change should be within ±20%
of initial value measuring at 20℃.
② Wetting shall exceed 95% coverage.
R230
40
Items
6.4.1
Terminal
Strength
Fig. 6.3.3-2
Fig. 6.3.3-1
IDC (mA)
Flexure
45[1.772]
45[1.772]
Fig.6.4.2-2
① Solder the bead to the testing jig (glass epoxy board
shown in Fig.6.4.3-1) using eutectic solder.
② The bead shall be subjected to a simple harmonic
motion having total amplitude of 1.5mm, the frequency being
varied uniformly between the approximate limits of 10 and 55
Hz.
③ The frequency range from 10 to 55 Hz and return to 10
Hz shall be traversed in approximately 1 minute. This motion
shall be applied for a period of 2 hours in each 3mutually
perpendicular directions (total of 6 hours)
Drop chip bead 10 times on a concrete floor from a height of
100 cm.
Temperature range:-40℃ to +85℃
Reference temperature: +20℃
① Solder temperture:240±2℃
② Duration: 3 sec.
③ Solder: Sn/3.0Ag/0.5Cu
④ Flux: 25% Resin and 75% ethanol in weight.
Sunlord
6.4.7
Resistance to
Soldering
Heat
6.4.8 Thermal
Shock
①
②
③
①
②
No mechanical damage.
Impedance change:
Within ±20%
+85℃
30 min.
30 min.
①
②
③
④
⑤
①
②
③
④
Ambient
Temperature
-40℃
Page 6 of 10
Solder temperature :260±3℃
Duration: 5 sec.
The chip shall be stabilized at normal condition for
1~2hours before measuring.
Temperature, Time: (See Fig.6.4.8-1).
-40℃for 30±3 min →+85℃ for 30±3min
Transforming interval: Max. 20 sec.
Tested cycle: 100 cycles
The chip shall be stabilized at normal condition for 1~2
30 min.
Fig. 6.4.8-1
20sec. (max.)
6.4.9
Resistance to
Low
Temperature
①
②
①
②
③
Temperature: -40±2℃
Duration: 1000+24 hours
6.4.10
Resistance to
High
Temperature
6.4.11
Damp Heat
(Steady
States)
①
②
①
②
③
①
②
③
④
Temperature: 85±2℃
Temperature: 55±2℃
Humidity: 90% to 95% RH
6.4.12
Loading
Under Damp
Heat
①
②
③
④
⑤
Temperature: 55±2℃
Applied current: Rated current.
6.4.13
Loading at
High
Temperature
(Life Test)
①
②
①
②
③
④
Temperature:+85±2℃
7.
Packaging, Storage and Transportation
7.1 Packaging
There are two types of packaging for the chip beads. Please specify the packing code when ordering.
7.1.1 Bulk Packaging:
Packaging code: B, The quantity of each bag is integral multiple of 1000.
Remark: The actual quantity in a package may change sometimes.
7.1.2 Tape Carrier Packaging:
Packaging code: T
a. Tape carrier packaging are specified in attached figure Fig.7.1-1~4
b. Tape carrier packaging quantity please see the following table:
c.
d.
e.
Type
2012[0805]
T(mm)
0.85±0.2
Tape
Paper Tape
Quantity
4K
Reel shall be packaged in vinyl bag.
Maximum of 5 or 10 reels bags shall be packaged in an inner box.
Maximum of 6 or 10 inner boxes shall be packaged in an outer case.
Sunlord
Page 7 of 10
(1) Taping Drawings (Unit: mm)
Top Tape
Paper Tape
Sprocket Hole
Bottom Tape
Chip Cavity
Fig 7.1-1
Remark: The sprocket holes are to the right as the tape is pulled toward the user.
(2) Taping Dimensions (Unit: mm)
Sprocket Hole Φ1.5 (+0.1,0)
Chip Cavity
8.0±0.3
3.5±0.05
A
Paper Tape
1.75±0.1
B
P
4.0±0.1
Type
A
B
P
T max
2012
[0805]
1.5±0.2
2.3±0.2
4.0±0.1
1.1
T
Fig 7.1-2
Direction of Feed
4.3±0.2mm
(3) Reel Dimensions (Unit: mm)
9.0±1.0mm
2.45±0.1mm
4.0±0.1mm
5.0±0.1mm
58±0.3mm
13.5±0.1mm
3.0±0.1mm
(4) Leader and Blank Portion
Chip Cavity
Blank Portions
Fig. 7.1-3
178±2.0mm
40 Min.
Fig. 7.1-4
Blank Portions
Leader
40 Min.
210 to 250 mm
Direction of Feed
(5) Missing beads number within 0.1% of the number per reel or 1 pcs, whichever is greater, and are not
continuous.
(6) The top tape and bottom tape shall not protrude beyond the edges of the tape and shall not cover sprocket
hole.
(7) Cumulative tolerance of sprocket holes, 10 pitches: ±0.3mm
(8) Peeling off force: 10gf to 70gf in the direction show below.
Top tape or cover tape
1650 to 180 0
Fig. 7.1-5
7.2 Storage
Base tape
a. The solderability of the external electrode may be deteriorated if packages are stored where they are exposed to high
humidity. Package must be stored at 40℃ or less and 70% RH or less.
Sunlord
Page 8 of 10
b.
The solderability of the external electrode may be deteriorated if packages are stored where they are exposed to dust
of harmful gas (e.g. HCl, sulfurous gas of H2S)
c. Packaging material may be deformed if package are stored where they are exposed to heat of direct sunlight.
d. Minimum packages, such as polyvinyl heat-seal packages shall not be opened until they are used. If opened, use the
reels as soon as possible.
e. Solderability specified in Clause 6.4.6 shall be guaranteed for 3 months from the date of delivery on condition that they
are stored at the environment specified in Clause 4 .For those parts, which passed more than 3 months shall be
checked solder-ability before use.
7.3 Transportation
The cases shall not be damaged, destroyed and rained on.
7.4 General Handling Precautions
a. Always wear static control bands to protect against ESD.
b. Any devices used with the beads (soldering iron, measuring instruments) should be properly grounded.
c. Keep bare hands and metal conductors (i.e., metal desk) away from chip electrodes or conductive areas that lead to
chip electrodes.
a. Pre-heating when soldering, see detail in Clause 9 in this specification.
b. When splitting the PC board after mounting beads and other components, care is required so as not to give any stress
of deflection or twisting to the board.
c. Don’t apply current in excess of the rated current value. It may reduce the impedance due to the temperature increase
effect.
d. Always wear static control bands to protect against ESD.
e. Keep clear of anything that may generate magnetic fields such as speakers, coils.
f. When Soldering, the impedance may be varied due to hot energy and mechanical stress.
g. Mounting ships with adhesive in preliminary assembly, before the soldering stage, may lead appropriately checked; the
size of land pattern, type of adhesive, amount applied, hardening of the adhesive on proper usage and amounts of
adhesive to use.
h. Mounting Density: Add special attention to radiating heat of products when mounting the beads near the products with
heating. The excessive heat by other products may cause deterioration at joint of this product with substrate.
8.
Packing Documents and Marking
8.1 Packing documents
Packing documents include the following:
a. Packaging list
b. Certificate of compliance (COC)
8.2
See Fig. 8.2-2
Marking
1.Marking label information on reels includes (see Fig.8.2-1~2):
a. Customer
b. Customer part No.
c. Customer P/O#
d. Sunlord part No.
e. Date code
f. Lot number
g. Quantity per reel
h. Inspection stamp
i. MFG address as ‘MADE IN CHINA’
2.Marking label on inner box (see Fig.8.2-3~4):
a. Customer
c. Customer P/O#
d. Sunlord part No.
e. Date code
f. Quantity per reel
g. Manufacturer
Fig. 8.2-1
Fig. 8.2-2: Marking label on reels
W
L
Inner Box
H
See Fig. 8.2-4
Fig. 8.2-3
Sunlord
Page 9 of 10
Packaging type
L(cm)
W(cm)
H(cm)
①
Inner Box-1
18
7.5
18
②
Inner Box-2
18
12
18
L
W
Fig. 8.2-4: Marking Label on inner box
3.Marking on outer case (see Fig.8.2-5~6):
a. Manufacturer: Sunlord ID:
“Shenzhen Sunlord Electronics Co., Ltd.”
b. Packing label include the following:
i)
Customer
ii)
Manufacture
iii)
Date code
iv)
C/No.
Example; “1/10” means
this case is the 1st one
of total 10 cases
v)
P/O No.
①
vi)
Customer P/N
②
vii) Sunlord P/N
viii) QT’Y(K)
Sunlord
See Fig. 8.2-6
Fig. 8.2-5
Packaging type
L(cm)
W(cm)
H(cm)
Outer Case-1
40
Outer Case-2
40
Customer
DATE CODE
Manufacturer
C/No.
Outer Case
H
SHEN ZHEN SUNLORD ELECTRONICS CO.,LTD
P/O No.
Customer P/N
Sunlord P/N
QT’Y(K)
Fig. 8.2-6: Marking label on outer case
9.
9.1 Re-flowing Profile:
△ 1~2 ℃/sec. Ramp
△ Pre-heating: 150~190℃/120±30 sec.
△ Time above 240℃: 20~60sec
△ Peak temperature: 260℃ Max.
△ Solder paste: Sn/3.0Ag/0.5Cu
△ Max.2 times for Re-flowing
9.2 Iron Soldering Profile.
△ Iron soldering power: Max.30W
△ Pre-heating: 150 ℃ / 60 sec.
△ Soldering Tip temperature: 350℃Max.
△ Soldering time: 3 sec Max.
△ Max.1 times for iron soldering
[Note: Take care not to apply the tip of
the soldering iron to the terminal electrodes.]
9.3 Solder Volume
Solder shall be used not to exceed as shown below.
Max: 260℃
260℃
200℃
240℃
190℃
150℃
20~60sec.
Gradual Cooling
120±30sec.
3 sec. Max.
350℃
Soldering Iron
Power: max. 30W
Diameter of Soldering
Iron 1.0mm max.
Tc ℃
Upper Limit
Recommendable
1/3T ≤L≤T
(T: Chip thickness)
L
Fig.9.3-1
Accordingly increasing the solder volume, the mechanical stress to product is also increased. Exceeding solder volume may
cause the failure of mechanical or electrical performance.
Sunlord
Page 10 of 10
The following shall be considered when designing and laying out PCB’s.
(1) PCB shall be designed so that products are not subjected to the mechanical stress from board warp or deflection.
Products shall be located in
the sideways direction to the
(Poor example)
Fig. 9.4-1
mechanical stress
(Good example)
(2) Products location on PCB separation.
C
Seam
B
Product shall be located carefully because they
may be subjected to the mechanical stress in order
of A>C=B>D.
A
D
Fig. 9.4-2
9.5 Cleaning
Products shall be cleaned on the following conditions:
(1) Cleaning temperature shall be limited to 60℃ Max. (40℃ Max. for fluoride and alcohol type cleaner.)
(2) Ultrasonic cleaning shall comply with the following conditions, avoiding the resonance phenomenon at the mounted
products and PCB.
Power: 20W/l Max.
Frequency: 28KHz to 40 KHz
Time: 5 minutes Max
(3) Cleaner
① Alternative cleaner
i. Isopropyl alcohol (IPA)
ii. HCFC-225
② Aqueous agent
z Surface Active Agent Type (Clean through-750H)
z Hydrocarbon Type (Techno Cleaner-335)
z Higher Alcohol Type (Pine Alpha ST-100S)
z Alkali saponifier Type (※ Aqua Cleaner 240)
※ Alkali saponification shall be diluted to 20% volume with de-ionized water.
(4) There shall be no residual flux and residual cleaner after cleaning. In the case of using aqueous agent, product shall be
dried completely after rinse with de-ionized water in order to remove the cleaner.
(5) Some products may become slightly whitened. However, product performance or usage is not affected.
a) Supplier:
b) Manufacturer
c) Manufacturing Address:
Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China
Zip: 518110
