74HC299; 74HCT299
8-bit universal shift register; 3-state
Rev. 03 — 28 July 2008
Product data sheet
1. General description
The 74HC299; 74HCT299 are high-speed Si-gate CMOS devices which are
pin-compatible with Low-power Schottky TTL (LSTTL) devices. They are specified in
compliance with JEDEC standard no. 7A.
The 74HC299; 74HCT299 contain eight edge-triggered D-type flip-flops and the
interstage logic necessary to perform synchronous shift-right, shift-left, parallel load and
hold operations. An operation is determined by the mode select inputs S0 and S1, as
shown in Table 3.
Pins I/O0 to I/O7 are flip-flop 3-state buffer outputs which allow them to operate as data
inputs in parallel load mode. The serial outputs Q0 and Q7 are used for expansion in
serial shifting of longer words.
A LOW signal on the asynchronous master reset input MR overrides the Sn and clock CP
inputs and resets the flip-flops. All other state changes are initiated by the rising edge of
the clock pulse. Inputs can change when the clock is in either state, provided that the
recommended set-up and hold times are observed.
A HIGH signal on the 3-state output enable inputs OE1 or OE2 disables the 3-state
buffers and the I/On outputs are set to the high-impedance OFF-state. In this condition,
the shift, hold, load and reset operations still occur when preparing for a parallel load
operation. The 3-state buffers are also disabled by HIGH signals on both S0 and S1.
2. Features
n Multiplexed inputs/outputs provide improved bit density
n Four operating modes:
u Shift left
u Shift right
u Hold (store)
u Load data
n Operates with output enable or at high-impedance OFF-state (Z)
n 3-state outputs drive bus lines directly
n Cascadable for n-bit word lengths
n ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
74HC299; 74HCT299
NXP Semiconductors
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74HC299D
−40 °C to +125 °C
SO20
plastic small outline package; 20 leads; body
width 7.5 mm
SOT163-1
74HC299DB
−40 °C to +125 °C
SSOP20
plastic shrink small outline package; 20 leads;
body width 5.3 mm
SOT339-1
SOT146-1
74HC299
74HC299N
−40 °C to +125 °C
DIP20
plastic dual in-line package; 20 leads (300 mil)
74HC299PW
−40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads; SOT360-1
body width 4.4 mm
74HCT299D
−40 °C to +125 °C
SO20
width 7.5 mm
SOT163-1
74HCT299DB
−40 °C to +125 °C
SSOP20
body width 5.3 mm
SOT339-1
SOT146-1
74HCT299
74HCT299N
−40 °C to +125 °C
DIP20
74HCT299PW
−40 °C to +125 °C
TSSOP20
body width 4.4 mm
4. Functional diagram
1
11
12
9
8
2
3
19
S0
DSR
S1
DSL
18
CP
8-BIT SHIFT REGISTER
MR
Q7
Q0
17
OE1
INPUT/3-STATE OUTPUT CIRCUITRY
OE2
I/O0 I/O1 I/O2 I/O3 I/O4 I/O5 I/O6 I/O7
7
Fig 1.
13
6
5
15
4
16
001aai460
Functional diagram
74HC_HCT299_3
Product data sheet
14
© NXP B.V. 2008. All rights reserved.
2 of 24
74HC299; 74HCT299
NXP Semiconductors
9
2
3
1
19
12
1
S0
I/O0
7
19
S1
I/O1
13
11
DSR
I/O2
6
18
DSL
I/O3
14
I/O4
5
12
CP
I/O5
15
9
MR
I/O6
4
I/O7
16
Q0
8
2
3
OE
Q7
11
7
13
R
M
3
1
C4/1 /2
1, 4D
3, 4D
6, 5
Logic symbol
8
6
14
5
15
4
16
18
17
3, 4D
7, 5
2, 4D
Z7
17
001aai459
Fig 3.
IEC logic symbol
74HC_HCT299_3
Product data sheet
Z6
3, 4D
5
001aai458
Fig 2.
SRG8
3EN5
3 of 24
74HC299; 74HCT299
NXP Semiconductors
DSR
S0
D
S1
Q
CP
FF0
RD
I/O0
CP
Q0
D
OE1
Q
CP
FF1
RD
OE2
I/O1
D
Q
CP
FF2
RD
I/O2
D
Q
CP
FF3
RD
I/O3
D
Q
CP
FF4
RD
I/O4
D
Q
CP
FF5
RD
I/O5
D
Q
CP
FF6
RD
I/O6
DSL
D
Q
CP
FF7
RD
Q7
001aai461
MR
Fig 4.
I/O7
Logic diagram
74HC_HCT299_3
Product data sheet
4 of 24
74HC299; 74HCT299
NXP Semiconductors
5. Pinning information
5.1 Pinning
74HC299
74HCT299
74HC299
74HCT299
S0
1
20 VCC
OE1
2
19 S1
OE2
3
18 DSL
I/O6
4
17 Q7
S0
1
20 VCC
OE1
2
19 S1
OE2
3
18 DSL
I/O4
5
16 I/O7
I/O6
4
17 Q7
I/O2
6
15 I/O5
I/O4
5
16 I/O7
I/O2
6
15 I/O5
I/O0
7
14 I/O3
I/O0
7
14 I/O3
Q0
8
13 I/O1
Q0
8
13 I/O1
MR
9
12 CP
MR
9
12 CP
GND 10
GND 10
11 DSR
001aai511
Fig 5.
11 DSR
001aai457
Pin configuration (SO20 and (T)SSOP20)
Fig 6.
Pin configuration (DIP20)
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
S0
1
mode select input
OE1
2
3-state output enable input (active LOW)
OE2
3
I/O6
4
parallel data input or 3-state parallel output (bus driver)
I/O4
5
I/O2
6
I/O0
7
Q0
8
serial output (standard output)
MR
9
asynchronous master reset input (active LOW)
GND
10
ground (0 V)
DSR
11
serial data shift-right input
CP
12
clock input (LOW to HIGH, edge-triggered)
I/O1
13
I/O3
14
I/O5
15
I/O7
16
Q7
17
74HC_HCT299_3
Product data sheet
5 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 2.
Pin description …continued
Symbol
Pin
Description
DSL
18
serial data shift-left input
S1
19
mode select input
VCC
positive supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Response
MR
S1
S0
CP
L
X
X
X
asynchronous reset; Q0 to Q7 = LOW
H
H
H
parallel load; I/On → Qn
H
L
H
shift right; DSR → Q0, Q0 → Q1, etc.
H
H
L
shift left; DSL → Q7, Q7 → Q6, etc.
H
L
L
X
hold
[1]
H = HIGH voltage level;
L = LOW voltage level;
↑ = LOW to HIGH CP transition;
X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
−0.5
+7
V
±20
mA
±20
mA
standard outputs
±25
mA
bus driver outputs
±35
mA
standard outputs
50
mA
bus driver outputs
70
mA
standard outputs
−50
mA
bus driver outputs
−70
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
IIK
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
−0.5 V < VO < VCC + 0.5 V
supply current
ICC
IGND
[1]
ground current
Tamb = −40 °C to +125 °C
DIP20 package
[2]
750
mW
SO20 package
[3]
500
mW
(T)SSOP20 package
[4]
500
mW
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
74HC_HCT299_3
Product data sheet
6 of 24
74HC299; 74HCT299
NXP Semiconductors
[2]
Ptot derates linearly at 12 mW/K above 70 °C.
[3]
Ptot derates linearly at 8 mW/K above 70 °C.
[4]
Ptot derates linearly at 5.5 mW/K above 60 °C.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
74HC299
74HCT299
Unit
Min
Typ
Max
Min
Typ
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+125 −40
+125 °C
∆t/∆V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
1.39
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
74HC299
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
74HC_HCT299_3
Product data sheet
V
7 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 6.
Static characteristics …continued
Symbol
VOH
Parameter
HIGH-level
output voltage
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
IO = −20 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −20 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −20 µA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = −4.0 mA;
VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = −5.2 mA;
VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = −6.0 mA;
VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = −7.8 mA;
VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 µA; VCC = 2.0 V
0.1
0.1
V
IO = 20 µA; VCC = 4.5 V
0.1
0.1
V
IO = 20 µA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
IO = 6.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
µA
VI = VIH or VIL
all outputs
standard outputs
bus driver outputs
VOL
LOW-level
output voltage
VI = VIH or VIL
all outputs
standard outputs
bus driver outputs
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
±0.1
±1.0
±1.0
IOZ
OFF-state output
current
VI = VIH or VIL; VO = VCC or
GND; VCC = 6.0 V
±0.5
±5.0
±10.0 µA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
µA
CI
input capacitance
3.5
pF
CI/O
input/output
capacitance
10
pF
CPD
power dissipation
capacitance
120
pF
2.0
1.6
2.0
2.0
V
[1]
per package
74HCT299
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
74HC_HCT299_3
Product data sheet
8 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 6.
Symbol
Parameter
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
1.2
0.8
0.8
0.8
V
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
3.98
4.32
3.84
3.7
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
IO = 6.0 mA
0.16
0.26
0.33
0.4
V
µA
VIL
LOW-level
input voltage
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
all outputs
IO = −20 µA
standard outputs
IO = −4.0 mA
bus driver outputs
IO = −6.0 mA
LOW-level
output voltage
VOL
all outputs
IO = 20 µA
standard outputs
IO = 4.0 mA
bus driver outputs
II
input leakage
current
VI = VCC or GND;
VCC = 5.5 V
±0.1
±1.0
±1.0
IOZ
OFF-state output
current
GND per input pin; other
inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
±0.5
±5.0
±10.0 µA
ICC
supply current
VCC = 5.5 V
8.0
80
∆ICC
additional supply
current
per input pin;
VI = VCC − 2.1 V;
other inputs at VCC or
GND; IO = 0 A;
I/On, DSR, DSL, MR
and S1
25
90
112.5
CP, S0
60
216
270
294
OEn
160
µA
122.5 µA
µA
30
108
135
147
µA
CI
input capacitance
3.5
pF
CI/O
input/output
capacitance
10
pF
CPD
power dissipation
capacitance
125
pF
[1]
per package
[1]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi + ∑(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
74HC_HCT299_3
Product data sheet
9 of 24
74HC299; 74HCT299
NXP Semiconductors
∑(CL × VCC2 × fo) = sum of outputs.
CL = output load capacitance in pF;
VCC = supply voltage in V;
VI = GND to VCC for 74HC299;
VI = GND to (VCC − 1.5 V) for 74HCT299.
10. Dynamic characteristics
Table 7.
GND (ground = 0 V); for test circuit, see Figure 11.
Symbol
Parameter
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
66
200
250
300
ns
VCC = 4.5 V
24
40
50
60
ns
VCC = 5.0 V; CL = 15 pF
ns
VCC = 6.0 V
19
34
43
51
ns
66
200
250
300
ns
VCC = 4.5 V
24
40
50
60
ns
ns
19
34
43
51
ns
VCC = 2.0 V
66
200
250
300
ns
VCC = 4.5 V
24
40
50
60
ns
ns
19
34
43
51
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
74HC299
tpd
propagation
delay
CP to Q0, Q7; see Figure 7
[1]
CP to I/On; see Figure 7
VCC = 2.0 V
VCC = 6.0 V
MR to Q0, Q7 or I/On;
see Figure 8
[2]
VCC = 6.0 V
tt
transition time
bus driver (I/On); see Figure 7
[3]
standard (Q0, Q7); see Figure 7
74HC_HCT299_3
Product data sheet
10 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 7.
Dynamic characteristics …continued
Symbol
tW
Parameter
pulse width
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
80
17
100
120
ns
VCC = 4.5 V
16
6
ns
VCC = 6.0 V
14
5
17
ns
VCC = 2.0 V
80
19
100
120
ns
VCC = 4.5 V
16
7
ns
14
6
17
ns
VCC = 2.0 V
50
155
195
235
ns
VCC = 4.5 V
18
31
39
47
ns
VCC = 6.0 V
14
26
33
40
ns
VCC = 2.0 V
41
130
165
195
ns
VCC = 4.5 V
15
26
33
39
ns
12
22
28
33
ns
VCC = 2.0 V
66
185
230
280
ns
VCC = 4.5 V
24
37
46
56
ns
VCC = 6.0 V
19
31
39
48
ns
VCC = 2.0 V
55
155
195
235
ns
VCC = 4.5 V
39
47
ns
VCC = 6.0 V
16
26
33
40
ns
VCC = 2.0 V
5
−14
5
5
ns
VCC = 4.5 V
5
−5
5
5
ns
VCC = 6.0 V
5
−4
5
5
ns
CP HIGH or LOW; see Figure 7
MR LOW; see Figure 8
VCC = 6.0 V
tPZH
tPZL
OFF-state to
HIGH
propagation
delay
OFF-state to
LOW
propagation
delay
OEn to I/On; see Figure 10
[4]
VCC = 6.0 V
tPHZ
tPLZ
trec
HIGH to
OFF-state
propagation
delay
LOW to
OFF-state
propagation
delay
recovery time
[5]
MR to CP; see Figure 8
74HC_HCT299_3
Product data sheet
11 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 7.
Symbol
tsu
Parameter
set-up time
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
100
33
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
10
21
26
ns
VCC = 2.0 V
100
33
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
10
21
26
ns
VCC = 2.0 V
125
39
155
190
ns
VCC = 4.5 V
25
14
31
38
ns
VCC = 6.0 V
21
11
26
32
ns
VCC = 2.0 V
−14
ns
VCC = 4.5 V
−5
ns
VCC = 6.0 V
−4
ns
VCC = 2.0 V
−28
ns
VCC = 4.5 V
−10
ns
VCC = 6.0 V
−8
ns
VCC = 2.0 V
5.0
15
4.0
3.4
MHz
VCC = 4.5 V
25
45
MHz
DSR, DSL to CP; see Figure 7
S0, S1 to CP; see Figure 9
I/On to CP; see Figure 7
th
hold time
I/On, DSR, DSL to CP;
see Figure 7
fmax
maximum
frequency
CP input; see Figure 7
50
MHz
29
54
24
MHz
VCC = 4.5 V
22
37
46
56
ns
19
ns
22
37
46
56
ns
19
ns
VCC = 4.5 V
27
46
58
69
ns
23
ns
VCC = 6.0 V
74HCT299
tpd
propagation
delay
[1]
VCC = 4.5 V
see Figure 8
[2]
74HC_HCT299_3
Product data sheet
12 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 7.
Symbol
tt
Parameter
transition time
25 °C
Conditions
−40 °C to
+85 °C
−40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
5
12
15
18
ns
7
15
19
22
ns
25
30
ns
25
30
ns
19
30
38
45
ns
24
37
46
56
ns
40
48
ns
10
2
9
11
ns
25
14
31
38
ns
32
18
40
48
ns
−11
ns
−17
ns
25
42
MHz
46
MHz
[3]
VCC = 4.5 V
VCC = 4.5 V
pulse width
tW
clock HIGH or LOW; see Figure 7
VCC = 4.5 V
master reset LOW; see Figure 8
VCC = 4.5 V
enable time
ten
[4]
VCC = 4.5 V
tPHZ
tPLZ
trec
HIGH to
OFF-state
propagation
delay
LOW to
OFF-state
propagation
delay
recovery time
VCC = 4.5 V
VCC = 4.5 V
VCC = 4.5 V
set-up time
tsu
[5]
see Figure 7
VCC = 4.5 V
VCC = 4.5 V
hold time
th
see Figure 7
VCC = 4.5 V
VCC = 4.5 V
maximum
frequency
fmax
VCC = 4.5 V
[1]
tpd is the same as tPHL and tPLH.
[2]
tpd is the same as tPHL.
[3]
tt is the same as tTHL and tTLH.
[4]
ten is the same as tPZH and tPZL.
[5]
tdis is the same as tPHZ and tPLZ.
74HC_HCT299_3
Product data sheet
13 of 24
74HC299; 74HCT299
NXP Semiconductors
[6]
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
Σ(CL × VCC2 × fo) = sum of outputs;
N = number of inputs switching.
11. Waveforms
VI
I/On, DSR, DSL
inputs
VM
GND
th
th
tsu
tsu
1/fmax
VI
CP input
VM
GND
tW
tPHL
tPLH
VOH
I/On, Q0, Q7
outputs
VM
VOL
tTHL
tTLH
001aai462
The shaded areas indicate when the input is permitted to change for predictable output performance.
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 7.
Clock pulse to outputs I/On, Q0, Q7 propagation delays, the clock pulse width, the I/On, DSR and DSL to
clock pulse set-up and hold times, the output transition times and the maximum clock frequency
74HC_HCT299_3
Product data sheet
14 of 24
74HC299; 74HCT299
NXP Semiconductors
VI
VM
MR input
GND
tW
trec
VI
VM
CP input
GND
tPHL
VOH
I/On, Q0, Q7
outputs
VOL
VM
001aai463
Fig 8.
The master reset pulse width (LOW), the master reset to outputs I/On, Q0, Q7 propagation delays and the
master reset to clock pulse removal time
VI
I/On, DSR, DSL, Sn
inputs
VM
GND
tsu
th
tsu
th
VI
CP input
VM
GND
001aai464
Fig 9.
Set-up and hold times from the mode control inputs S0, S1 to the clock pulse
74HC_HCT299_3
Product data sheet
15 of 24
74HC299; 74HCT299
NXP Semiconductors
tr
VI
tf
90 %
OEn input
VM
GND 10 %
tPLZ
VOH
I/On output
LOW to OFF
OFF to LOW
VOL
tPZL
VM
10 %
tPZH
tPHZ
VOH
I/On output
HIGH to OFF
OFF to HIGH
VOL
90 %
VM
outputs
enabled
outputs
disabled
outputs
enabled
001aai465
Fig 10. 3-state enable and disable times for OEn inputs
Table 8.
Measurement points
Type
Input
Output
VI
VM
VM
74HC299
VCC
0.5VCC
0.5VCC
74HCT299
3V
1.3 V
1.3 V
VCC
PULSE
GENERATOR
VI
VCC
VO
RL = 1 kΩ
RT
S1
open
DUT
CL
50 pF
001aai466
Test data is given in Table 9.
Definitions for test circuit:
DUT = Device Under Test.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch
Fig 11. Test circuit for measuring switching times
74HC_HCT299_3
Product data sheet
16 of 24
74HC299; 74HCT299
NXP Semiconductors
Table 9.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
74HC299
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
74HCT299
3V
6 ns
15 pF, 50 pF
1 kΩ
open
74HC_HCT299_3
Product data sheet
17 of 24
74HC299; 74HCT299
NXP Semiconductors
12. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
10
1
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 12. Package outline SOT163-1 (SO20)
74HC_HCT299_3
Product data sheet
18 of 24
74HC299; 74HCT299
NXP Semiconductors
SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm
D
SOT339-1
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
1
10
w M
bp
e
detail X
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
7.4
7.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
0.9
0.5
8
o
o
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
OUTLINE
VERSION
SOT339-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig 13. Package outline SOT339-1 (SSOP20)
74HC_HCT299_3
Product data sheet
19 of 24
74HC299; 74HCT299
NXP Semiconductors
DIP20: plastic dual in-line package; 20 leads (300 mil)
SOT146-1
ME
seating plane
D
A2
A
A1
L
c
e
Z
b1
w M
(e 1)
b
MH
11
pin 1 index
E
1
10
10 mm
scale
UNIT
A
max.
A1
min.
A2
max.
b
b1
c
mm
4.2
0.51
3.2
1.73
1.30
0.53
0.38
0.36
0.23
26.92
26.54
inches
0.17
0.02
0.13
0.068
0.051
0.021
0.015
0.014
0.009
1.060
1.045
D
e
e1
L
ME
MH
w
Z (1)
max.
6.40
6.22
2.54
7.62
3.60
3.05
8.25
7.80
10.0
8.3
0.254
2
0.25
0.24
0.1
0.3
0.14
0.12
0.32
0.31
0.39
0.33
0.01
0.078
(1)
E
(1)
Note
1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
OUTLINE
VERSION
SOT146-1
REFERENCES
IEC
JEDEC
JEITA
MS-001
SC-603
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-13
Fig 14. Package outline SOT146-1 (DIP20)
74HC_HCT299_3
Product data sheet
20 of 24
74HC299; 74HCT299
NXP Semiconductors
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
E
D
A
X
c
HE
y
v M A
Z
11
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
10
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 15. Package outline SOT360-1 (TSSOP20)
74HC_HCT299_3
Product data sheet
21 of 24
74HC299; 74HCT299
NXP Semiconductors
13. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT299_3
20080728
Product data sheet
74HC_HCT299_CNV_2
Modifications:
74HC_HCT299_CNV_2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Section 3: Ordering information added
Section 12: Package outline drawings added
Section 9 “Static characteristics”: Family data added
Section 11 “Waveforms”: Test circuit added
19970828
Product specification
74HC_HCT299_3
Product data sheet
22 of 24
74HC299; 74HCT299
NXP Semiconductors
14. Legal information
14.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
14.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
14.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
15. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
74HC_HCT299_3
Product data sheet
23 of 24
NXP Semiconductors
74HC299; 74HCT299
16. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
14.1
14.2
14.3
14.4
15
16
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 5
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5
Functional description . . . . . . . . . . . . . . . . . . . 6
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6
Recommended operating conditions. . . . . . . . 7
Static characteristics. . . . . . . . . . . . . . . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . 10
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 18
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 22
Legal information. . . . . . . . . . . . . . . . . . . . . . . 23
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 23
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Contact information. . . . . . . . . . . . . . . . . . . . . 23
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2008.
Date of release: 28 July 2008
Document identifier: 74HC_HCT299_3
