2SC3835
2SC3835
    SPTECH(质超)
    TO3PN
    硅NPN功率晶体管
2SC3835 数据手册
SPTECH Product Specification SPTECH Silicon NPN Power Transistor 2SC3835 DESCRIPTION ·Low Collector Saturation Voltage : VCE(sat)= 0.5V(Max)@ IC=3A ·Collector-Emitter Breakdown Voltage: V(BR)CEO= 120V (Min) ·Good Linearity of hFE APPLICATIONS ·Designed for use in humidifier , DC/DC converter and general purpose applications ABSOLUTE MAXIMUM RATINGS(Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage 200 V VCEO Collector-Emitter Voltage 120 V VEBO Emitter-Base Voltage 8 V IC Collector Current-Continuous 7 A ICM Collector Current-Pulse 14 A IB Base Current-Continuous 3 A PC Collector Power Dissipation @ TC=25℃ 70 W TJ Junction Temperature 150 ℃ -55~150 ℃ Tstg Storage Temperature Range SPTECH website:www.superic-tech.com 1 SPTECH Product Specification SPTECH Silicon NPN Power Transistor 2SC3835 ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER V(BR)CEO Collector-Emitter Breakdown Voltage IC= 50mA ; IB= 0 VCE(sat) Collector-Emitter Saturation Voltage IC= 3A; IB= 0.3A 0.5 V VBE(sat) Base-Emitter Saturation Voltage IC= 3A; IB= 0.3A 1.2 V ICBO Collector Cutoff Current VCB= 200V; IE= 0 100 μA IEBO Emitter Cutoff Current VEB= 8V; IC= 0 100 μA hFE DC Current Gain IC= 3A ; VCE= 4V 70 Current-Gain—Bandwidth Product IE= 0.5A ; VCE= 12V 20 Output Capacitance IE=0 ; VCB=10V;ftest=1.0MHz fT COB CONDITIONS MIN TYP. MAX 120 UNIT V 220 MHz 110 pF Switching times ton Turn-on Time tstg Storage Time tf  IC= 3A ;IB1=0.3A; IB2= -0.6A RL= 16.7Ω; VCC= 50V Fall Time 0.5 μs 3.0 μs 0.5 μs hFE Classifications O Y G 70-120 100-200 160-220 SPTECH website:www.superic-tech.com 2
2SC3835 价格&库存
很抱歉,暂时无法提供与“2SC3835”相匹配的价格&库存,您可以联系我们找货
2SC3835
    • 1+3.90000
    • 10+3.60000
    • 30+3.54000
