MJW0281A
MJW0281A
    SPTECH(质超)
    TO3PN
    硅NPN功率晶体管
MJW0281A 数据手册
SPTECH Product Specification SPTECH Silicon NPN Power Transistor DESCRIPTION ·High DC current amplifier rate hFE: 50-200@VCE= 5V,IC= 1A ·Minimum Lot-to-Lot variations for robust device performance and reliable operation APPLICATIONS ·High power audio, disk head positioners and other linear applications. ABSOLUTE MAXIMUM RATINGS(Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage 250 V VCEO Collector-Emitter Voltage 250 V VEBO Emitter-Base Voltage 5 V IC Collector Current-Continuous 15 A ICP Collector Current-Pulse 30 A IB Base Current-Continuous 1.5 A PC Total Power Dissipation @ TC=25℃ 150 W TJ Junction Temperature 150 ℃ -65~150 ℃ Tstg Storage Temperature Range THERMAL CHARACTERISTICS SYMBOL PARAMETER MAX UNIT Rth j-c Thermal Resistance,Junction to Case 0.63 ℃/W SPTECH website:www.superic-tech.com 1 MJW0281A SPTECH Product Specification SPTECH Silicon NPN Power Transistor MJW0281A ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER CONDITIONS VCEO(SUS) Collector-Emitter Sustaining Voltage IC=100mA ; IB=0 VCE(sat) Collector-Emitter Saturation Voltage IC= 10A; IB= 1A 2 V VBE(on) Base-Emitter Saturation Voltage IC= 8A; VCE= 5V 2 V ICBO Collector Cutoff Current VCB= 250V ; IE=0 50 µA IEBO Emitter Cutoff Current VEB= 5V; IC=0 5 µA hFE-1 DC Current Gain IC= 100mA ; VCE= 5V 75 150 hFE-2 DC Current Gain IC= 1A ; VCE= 5V 75 150 hFE-3 DC Current Gain IC= 8A ; VCE= 5V 75 hFE-4 DC Current Gain IC= 15A ; VCE= 5V 12 SPTECH website:www.superic-tech.com 2 MIN MAX 250 UNIT V
MJW0281A
物料型号:MJW0281A SPTECH
器件简介:这是一个硅NPN功率晶体管,具有高直流电流放大率(hFE: 50-200@VCE=5V, IC=1A),并且批次间变化小,确保了设备性能的稳定性和可靠性。
应用信息:适用于高保真音频放大、磁盘头定位器等线性应用。
引脚分配:1.Base(基极),2.Collector(集电极),3.Emitter(发射极)。
参数特性:包括集电极-基极电压(VcBO)、集电极-发射极电压(VCEO)、发射极-基极电压(VEBO)、连续集电极电流(Ic)、脉冲集电极电流(Icp)、连续基极电流(Is)、总功耗(Pc)、结温(TJ)和存储温度范围(Tstg)。
功能详解:文档详细列出了热特性和电气特性,包括热阻、集电极-发射极维持电压、饱和电压、基极-发射极饱和电压、截止电流等。
封装信息:采用TO-3PN封装。
MJW0281A 价格&库存
很抱歉,暂时无法提供与“MJW0281A”相匹配的价格&库存,您可以联系我们找货
MJW0281A
    • 1+4.55000
    • 10+4.20000
    • 30+4.13000
    MJW0281A
    • 1+7.04862
    • 10+5.74560
    • 30+4.74012
    • 90+4.09374
    • 510+3.70386
    • 1200+3.49866
    库存:120
