TIP36C
TIP36C
    SPTECH(质超)
    TO3PN
    硅PNP功率晶体管
TIP36C 数据手册
SPTECH Product Specification SPTECH Silicon PNP Power Transistor TIP36C DESCRIPTION ·DC Current Gain: hFE= 25(Min)@IC = -1.5A ·Collector-Emitter Sustaining Voltage: VCEO(SUS)= -100V(Min) ·Complement to Type TIP35C ·Current Gain-Bandwidth Product: fT= 3.0MHz(Min)@IC= -1.0A APPLICATIONS ·Designed for use in general purpose power amplifier and switching applications. ABSOLUTE MAXIMUM RATINGS (Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage -100 V VCEO Collector-Emitter Voltage -100 V VEBO Emitter-Base Voltage -5 V IC Collector Current-Continuous -25 A ICM Collector Current-peak -40 A IB Base Current -5 A PC Collector Power Dissipation@TC=25℃ 125 W Tj Junction Temperature 150 ℃ -65~150 ℃ MAX UNIT 1.0 ℃/W Tstg Storage Temperature Range THERMAL CHARACTERISTICS SYMBOL Rth j-c PARAMETER Thermal Resistance,Junction to Case SPTECH website:www.superic-tech.com 1 SPTECH Product Specification SPTECH Silicon PNP Power Transistor TIP36C ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER VCEO(SUS) Collector-Emitter Sustaining Voltage IC= -30mA ;IB= 0 VCE(sat)-1 Collector-Emitter Saturation Voltage IC= -15A ;IB= -1.5A -1.8 V VCE(sat)-2 Collector-Emitter Saturation Voltage IC= -25A; IB= -5A -4.0 V VBE(on)-1 Base-Emitter On Voltage IC= -15A ; VCE= -4V -2.0 V VBE(on)-2 Base-Emitter On Voltage IC= -25A ; VCE= -4V -4.0 V ICEO Collector Cutoff Current VCE= -60V; IB= 0 -1.0 mA ICBO Collector Cutoff Current VCB= -100V; IE= 0 -0.7 mA IEBO Emitter Cutoff Current VEB= -5V; IC= 0 -1.0 mA hFE-1 DC Current Gain IC= -1.5A ; VCE= -4V 25 hFE-2 DC Current Gain IC= -15A ; VCE= -4V 15 Current-Gain—Bandwidth Product IC= -1A ; VCE= -10V;ftest= 1.0MHz 3 fT SPTECH website:www.superic-tech.com CONDITIONS MIN MAX -100 UNIT V 75 MHz 2
TIP36C
物料型号:TIP36C
器件简介: - 直流电流增益:h_{FE}=25(最小值)@ I_{C}=-1.5 A - 集电极-发射极维持电压:VCEO(SUS)= -100V(最小值) - 与TIP35C型号互补 - 电流增益-带宽积:f_{T}=3.0 MHz(最小值)@ I_{C}=-1.0 A
引脚分配: - 1.Base(基极) - 2.Collector(集电极) - 3.Emitter(发射极) - 封装类型:TO-3PN
参数特性: - 集电极-基极电压:VCBO -100V - 集电极-发射极电压:VCEO -100V - 发射极-基极电压:VEBO -5V - 集电极电流-连续:Ic -25A - 集电极电流-峰值:IcM -40A - 基极电流:1s -5A - 集电极功耗:Pc 125W @ Tc=25°C - 结温:Tj 150°C - 存储温度范围:Tstg -65~150°C
功能详解: - 设计用于通用功率放大器和开关应用。
应用信息: - 适用于一般用途的功率放大和开关应用。
封装信息: - 封装类型:TO-3PN - 封装尺寸:A 19.60-20.30mm,B 15.50-15.70mm,C 4.70-4.90mm,D 0.90-1.10mm,E 1.90-2.10mm,F 3.40-3.60mm,G 2.90-3.20mm,H 3.20-3.40mm,J 0.595-0.605mm,K 19.80-20.70mm,N 10.89-10.91mm,Q 4.90-5.10mm,R 3.35-3.45mm,S 1.995-2.100mm,U 5.90-6.20mm,Y 9.90-10.10mm
热特性: - 结到外壳的热阻:Rth j-c 1.0°C/W
TIP36C 价格&库存
很抱歉,暂时无法提供与“TIP36C”相匹配的价格&库存,您可以联系我们找货
TIP36C
  • 1+5.05440
  • 10+4.11480
  • 30+3.65040
  • 90+3.18600
  • 510+2.91600
  • 1200+2.76480
TIP36C
    • 1+2.53000
    • 10+2.42000
