2SC4467
2SC4467
    SPTECH(质超)
    TO3PN
    硅NPN功率晶体管
2SC4467 数据手册
SPTECH Product Specification SPTECH Silicon NPN Power Transistors 2SC4467 DESCRIPTION ・With TO-3PN package ・Complement to type 2SA1694 APPLICATIONS ・Audio and general purpose PINNING PIN DESCRIPTION 1 Base 2 Collector;connected to mounting base 3 Emitter Fig.1 simplified outline (TO-3PN) and symbol Absolute maximum ratings(Ta=℃) SYMBOL PARAMETER CONDITIONS VALUE UNIT VCBO Collector-base voltage Open emitter 160 V VCEO Collector-emitter voltage Open base 120 V VEBO Emitter-base voltage Open collector 6 V IC Collector current 8 A IB Base current 3 A PC Collector power dissipation 80 W Tj Junction temperature 150 ℃ Tstg Storage temperature -55~150 ℃ TC=25℃ SPTECH website:www.superic-tech.com 1 SPTECH Product Specification SPTECH Silicon NPN Power Transistors 2SC4467 CHARACTERISTICS Tj=25℃ unless otherwise specified SYMBOL PARAMETER CONDITIONS MIN TYP. MAX V(BR)CEO Collector-emitter breakdown voltage IC=50mA ;IB=0 VCEsat Collector-emitter saturation voltage IC=3A ;IB=0.3A 1.5 V ICBO Collector cut-off current VCB=160V; IE=0 10 μA IEBO Emitter cut-off current VEB=6V; IC=0 10 μA hFE DC current gain IC=3A ; VCE=4V COB Output capacitance IE=0 ; VCB=10V,f=1MHz 200 pF fT Transition frequency IC=0.5A ; VCE=12V 20 MHz 0.13 Μs 3.50 Μs 0.32 Μs 120 UNIT V 50 180 Switching times ‹ ton Turn-on time ts Storage time tf Fall time IC=4A;RL=10Ω IB1=- IB2=0.4A VCC=40V hFE Classifications O P Y 50-100 70-140 90-180 SPTECH website:www.superic-tech.com 2 SPTECH Product Specification SPTECH Silicon NPN Power Transistors PACKAGE OUTLINE Fig.2 outline dimensions (unindicated tolerance:±0.1mm) SPTECH website:www.superic-tech.com 3 2SC4467 SPTECH Product Specification SPTECH Silicon NPN Power Transistors SPTECH website:www.superic-tech.com 4 2SC4467
2SC4467
物料型号:2SC4467
器件简介: - 该晶体管是SPTECH品牌的硅NPN功率晶体管。 - 它与2SA1694型号的晶体管相辅相成。 - 主要应用于音频和一般用途。
引脚分配: - 引脚1:基极(Base) - 引脚2:集电极,连接到安装底座(Collector:connected to mounting base) - 引脚3:发射极(Emitter)
参数特性: - 绝对最大额定值: - 集电极-基极电压(VCBO):160V - 集电极-发射极电压(VCEO):120V - 发射极-基极电压(VEBO):6V - 集电极电流(Ic):8A - 基极电流(Ib):3A - 集电极功耗(Pc):80W - 结温(T):150°C - 存储温度(Tsg):-55~150°C
功能详解: - 特性参数: - 集电极-发射极击穿电压(V(BR)CEO):120V - 集电极-发射极饱和电压(VCEsat):1.5V - 集电极截止电流(IcBo):10A - 发射极截止电流(IEBO):10A - 直流电流增益(hFE):50~180 - 输出电容(COB):200pF - 转换频率(fr):20MHz - 开关时间: - 导通时间(ton):0.13ms - 存储时间(ts):3.50ms - 关断时间(t):0.32ms - hFE分类: - O类:50-100 - P类:70-140 - Y类:90-180
应用信息: - 该晶体管适用于音频和一般用途。
封装信息: - 封装类型:TO-3PN - 封装尺寸图和安全工作区图在文档中有所描述。
2SC4467 价格&库存
很抱歉,暂时无法提供与“2SC4467”相匹配的价格&库存,您可以联系我们找货
2SC4467
    • 1+3.12000
    • 10+2.88000
    • 30+2.83200
    2SC4467
    • 1+5.69430
    • 10+4.58622
    • 30+4.03218
    • 90+3.47814
    • 510+3.14982
    • 990+2.97540
    库存:118
