2SD844
2SD844
    SPTECH(质超)
    TO3PI
    硅NPN功率晶体管
2SD844 数据手册
SPTECH Product Specification SPTECH Silicon NPN Power Transistor 2SD844 DESCRIPTION ·Collector-Emitter Breakdown Voltage: V(BR)CEO= 50V (Min) ·Low Collector-Emitter Saturation Voltage: VCE(sat)= 0.4V (Max)@IC= 4A ·High Collector Power Dissipation : PC= 60W @TC=25℃ ·Complement to Type 2SB754 APPLICATIONS ·High current switching applications ·Power amplifier applications ABSOLUTE MAXIMUM RATINGS(Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage 50 V VCEO Collector-Emitter Voltage 50 V VEBO Emitter-Base Voltage 5 V IC Collector Current-Continuous 7 A IE Emitter Current-Continuous 7 A Collector Power Dissipation @ Ta=25℃ 2.5 Collector Power Dissipation @ TC=25℃ 60 Junction Temperature 150 ℃ -55~150 ℃ PC TJ Tstg Storage Temperature Range W SPTECH website:www.superic-tech.com 1 SPTECH Product Specification 2SD844 SPTECH Silicon NPN Power Transistor ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER V(BR)CEO Collector-Emitter Breakdown Voltage IC= 10mA ; IB= 0 50 V V(BR)EBO Emitter-Base Breakdown Voltage IE= 1mA ; IC= 0 5 V VCE(sat) Collector-Emitter Saturation Voltage IC= 4A; IB= 0.4A 0.2 0.4 V VBE(on) Base-Emitter On Voltage IC= 4A ; VCE= 1V 0.9 1.2 V ICBO Collector Cutoff Current VCB= 50V ; IE= 0 10 μA IEBO Emitter Cutoff Current VEB= 5V ; IC= 0 10 μA hFE -1 DC Current Gain IC= 1A ; VCE= 1V 70 hFE -2 DC Current Gain IC= 4A ; VCE= 1V 30 Current-Gain—Bandwidth Product IC= 1A; VCE= 5V 15 MHz Output Capacitance IE= 0; VCB= 10V; ftest= 1.0MHz 250 pF fT COB  CONDITIONS MIN TYP. MAX UNIT 240 hFE-1 Classifications O Y 70-140 120-240 SPTECH website:www.superic-tech.com 2
2SD844 价格&库存
很抱歉,暂时无法提供与“2SD844”相匹配的价格&库存,您可以联系我们找货
2SD844
  • 1+5.83794
  • 10+4.72986
  • 30+4.03218
  • 90+3.47814
  • 510+3.14982
  • 1200+2.97540
库存:28
2SD844
    • 1+3.12000
    • 10+2.88000
    • 30+2.83200
