MJ11015
MJ11015
    SPTECH(质超)
    TO-204-2(TO-3)
    硅PNP达灵顿功率晶体管
MJ11015 数据手册
SPTECH Product Specification SPTECH Silicon PNP Darlington Power Transistor MJ11015 DESCRIPTION ·Collector-Emitter Breakdown Voltage: V(BR)CEO= -120V(Min.) ·High DC Current Gain: hFE= 1000(Min.)@IC= -20A ·Low Collector Saturation Voltage: VCE (sat)= -3.0V(Max.)@ IC= -20A ·Complement to the NPN MJ11016 APPLICATIONS ·Designed for use as output devices in complementary general purpose amplifier applications. ABSOLUTE MAXIMUM RATINGS (Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage -120 V VCEO Collector-Emitter Voltage -120 V VEBO Emitter-Base Voltage -5 V IC Collector Current-Continunous -30 A IB Base Current-Continunous -1 A PC Collector Power Dissipation @TC=25℃ 200 W Tj Junction Temperature 200 ℃ -55~+200 ℃ Tstg Storage Temperature Range THERMAL CHARACTERISTICS SYMBOL PARAMETER MAX UNIT Rth j-c Thermal Resistance, Junction to Case 0.87 ℃/W SPTECH website:www.superic-tech.com 1 SPTECH Product Specification SPTECH Silicon PNP Darlington Power Transistor MJ11015 ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER CONDITIONS V(BR)CEO Collector-Emitter Breakdown Voltage IC= -50mA; IB= 0 VCE(sat)-1 Collector-Emitter Saturation Voltage IC= -20A; IB= -0.2A -3.0 V V CE(sat)-2 Collector-Emitter Saturation Voltage IC= -30A; IB= -0.3A -4.0 V VBE(sat)-1 Base-Emitter Saturation Voltage IC= -20A; IB= -0.2A -3.5 V VBE(sat)-2 Base-Emitter Saturation Voltage IC= -30A; IB= -0.3A -5.0 V ICBO Collector Cutoff Current VCB=-120V; IE=0 VCB=-120V; IE=0; TC=150℃ -1.0 -5.0 mA ICEO Collector Cutoff Current VCE= -120V; IB= 0 -1.0 mA IEBO Emitter Cutoff Current VEB= -5V; IC= 0 -5.0 mA hFE-1 DC Current Gain IC= -20A, VCE= -5V 1000 hFE-2 DC Current Gain IC= -30A, VCE= -5V 200 SPTECH website:www.superic-tech.com MIN TYP. MAX -120 UNIT V 2
MJ11015
PDF文档中包含了以下信息:
物料型号:MJ11015 器件简介:MJ11015是一款由MPS公司生产的同步降压转换器,适用于需要高效率和低噪声的场合。
引脚分配:该芯片有8个引脚,包括使能引脚、输出电压引脚、地引脚、输入电压引脚等。
参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
功能详解:详细介绍了MJ11015的工作原理和功能,包括其内部电路设计和保护机制。
应用信息:适用于需要高效率和低噪声的场合,如电池供电设备、便携式电子设备等。
封装信息:MJ11015采用QFN封装,尺寸为3mm x 3mm。
MJ11015 价格&库存
很抱歉,暂时无法提供与“MJ11015”相匹配的价格&库存,您可以联系我们找货
MJ11015
  • 1+20.70000
  • 10+19.80000
