BU931T
BU931T
    SPTECH(质超)
    TO220C-3
    NPN功率晶体管 TO220C
BU931T 数据手册
SPTECH Product Specification SPTECH Silicon NPN Power Transistor BU931T DESCRIPTION ·High Voltage ·DARLINGTON APPLICATIONS ·High ruggedness electronic ignitions ·High voltage ignition coil driver ABSOLUTE MAXIMUM RATINGS (Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage 500 V VCEO Collector-Emitter Voltage 400 V VEBO Emitter-Base Voltage 5 V IC Collector Current 10 A ICM Collector Current-peak 15 A IB Base Current 1 A IBM Base Current-peak 5 A PC Collector Power Dissipation @TC=25℃ 125 W Tj Junction Temperature 150 ℃ -65~150 ℃ Tstg Storage Temperature Range THERMAL CHARACTERISTICS SYMBOL PARAMETER MAX UNIT Rth j-c Thermal Resistance, Junction to Case 1.2 ℃/W SPTECH website:www.superic-tech.com 1 SPTECH Product Specification SPTECH Silicon NPN Power Transistor BU931T ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER VCEO(SUS) Collector-Emitter Sustaining Voltage IC= 50mA; IB= 0 VCE(sat)-1 Collector-Emitter Saturation Voltage IC= 7A; IB= 70mA 1.6 V V CE(sat)-2 Collector-Emitter Saturation Voltage IC= 8 A; IB= 100mA 1.8 V VBE(sat)-1 Base-Emitter Saturation Voltage IC= 7A; IB= 70mA 2.2 V V BE(sat)-2 Base-Emitter Saturation Voltage IC= 8 A; IB= 100mA 2.4 V ICES Collector Cutoff Current VCE= 500V;VBE= 0 VCE= 500V;VBE= 0;Tj= 125℃ 0.1 0.5 mA ICEO Collector Cutoff Current VCE= 450V;IB= 0 VCE= 450V;IB= 0;Tj= 125℃ 0.1 0.5 mA IEBO Emitter Cutoff Current VEB= 5V; IC= 0 20 mA hFE DC Current Gain IC= 5A ; VCE= 10V VECF C-E Diode Forward Voltage IF= 10A 2.5 V SPTECH website:www.superic-tech.com CONDITIONS MIN TYP. MAX 400 UNIT V 300 2
BU931T 价格&库存
很抱歉,暂时无法提供与“BU931T”相匹配的价格&库存,您可以联系我们找货
BU931T
