TIP151
TIP151
    SPTECH(质超)
    TO-220C
    硅NPN达林顿功率晶体管
TIP151 数据手册
SPTECH Product Specification SPTECH Silicon NPN Darlington Power Transistor TIP151 DESCRIPTION ·Collector-Emitter Breakdown Voltage: V(BR)CEO= 350V(Min.) ·Collector-Emitter Saturation Voltage: VCE(sat)= 2.0V(Max.)@ IC= 5A APPLICATIONS ·Designed for use in automotive ignition,switching and motor control applications. ABSOLUTE MAXIMUM RATINGS(Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage 350 V VCEO Collector-Emitter Voltage 350 V VEBO Emitter-Base Voltage 8 V IC Collector Current-Continuous 7 A ICM Collector Current-Peak 10 A IB Base Current- Continuous 1.5 A PC Collector Power Dissipation @TC=25℃ 80 W Tj Junction Temperature 150 ℃ -65~150 ℃ Tstg Storage Temperature Range THERMAL CHARACTERISTICS SYMBOL Rth j-c PARAMETER Thermal Resistance, Junction to Case SPTECH website:www.superic-tech.com MAX UNIT 1.56 ℃/W 1 SPTECH Product Specification SPTECH Silicon NPN Darlington Power Transistor TIP151 ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER V(BR)CEO Collector-Emitter Breakdown Voltage IC= 10mA, IB= 0 350 V V(BR)CBO Collector-Base Breakdown Voltage IC= 1.0mA, IE= 0 350 V VCE(sat)-1 Collector-Emitter Saturation Voltage IC= 1A, IB= 10mA 1.5 V VCE(sat)-2 Collector-Emitter Saturation Voltage IC= 2A, IB= 100mA 1.5 V VCE(sat)-3 Collector-Emitter Saturation Voltage IC= 5A, IB= 250mA 2.0 V VBE(sat)-1 Base-Emitter Saturation Voltage IC= 2A, IB= 100mA 2.2 V VBE(sat)-2 Base-Emitter Saturation Voltage IC= 5A, IB= 250mA 2.3 V C-E Diode Forward Voltage IF= 7A 3.5 V ICEO Collector Cutoff current VCE= 350V, IB= 0 0.25 mA IEBO Emitter Cutoff Current VEB= 8V; IC= 0 15 mA hFE-1 DC Current Gain IC= 2.5A; VCE= 5V 150 hFE-2 DC Current Gain IC= 5A; VCE= 5V 50 hFE-3 DC Current Gain IC= 7A; VCE= 5V 15 COB Collector Output Capacitance IE= 0; VCB= 10V; f= 1MHz 150 pF VF CONDITIONS MIN TYP. MAX UNIT Switching Times td Delay Time tr Rise Time tstg tf Storage Time Fall Time SPTECH website:www.superic-tech.com VCC = 250V, IC = 5.0 A, IB1= -IB2= 250mA; tp= 20μs Duty Cycle≤2% 0.03 μs 0.18 μs 3.5 μs 1.6 μs 2
TIP151 价格&库存
很抱歉,暂时无法提供与“TIP151”相匹配的价格&库存,您可以联系我们找货
TIP151
    • 1+4.94000
    • 10+4.56000
    • 30+4.48400
    TIP151
    • 1+11.67588
    • 10+10.20870
    • 50+9.17244
    • 100+8.25930
    • 500+7.84890
    • 1000+7.66422
    库存:10
