P6SMBSeries 600W Transient Voltage Suppressor
Description
The P6SMB series is designed specifically to
protectsensitive electronic equipment from voltage
transients induced by lightning and other transient
voltage events.
DO-214AA(SMB)
Features
z
For surface mounted applications
z
Reliable low cost construction utilizing molded plastic technique
z
Plastic package has UL flammability classification 94V-O
z
Typical IR less than 1uA above 13V
z
Glass passivated chip junction in DO-15 Package
z
600W peak pulse capability at 10*1000us waveform,repetition rate (duty cycles):0.01%
z
Fast response time: typically less than 1.0ps from 0 Volts to BV min
z
AEC -Q101 qualified.
Maximum Ratings and Electrical Characteristics
(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
PPPM
600
W
Power Dissipation on infinite heat sink at TA=75℃
PD
5.0
W
Peak Forward Surge Current, 8.3ms Single Half Sine
Wave Unidirectional only(Note 2)
IFSM
100
A
Maximum Instantaneous Forward Voltage at 50A for
Unidirectional only (Note 3)
VF
3.5V/5.0
V
TJ, TSTG
-55 to 175
Typical Thermal Resistance Junction to Lead
RuJL
℃/W
Typical Thermal Resistance Junction to Ambient
RuJA
75
℃/W
Peak Pulse Power Dissipation at
TA=25℃ by 10x1000μs waveform (Fig.1)(Note 1)
Operating Junction and Storage Temperature Range
Notes:
1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig. 2.
2. Measured on 8.3ms single half sine wave or equivalent square wave
for unidirectional device only.
3. VF < 3.5V for devices of VBR ≤ 200V and VF< 5.0V for devicesof VBR ≥ 201V.
Applications
Tvsdevices are ideal for the protection of I/O interfaces,Vcc bus and other vulnerable
circuits uded in telecom, computer,industrial and consumer electronic applications.
Rev : 01.06.2014
1/6
www.leiditech.com
Rating And Characteristic Curves (TA=25℃ unless otherwise noted)
Figure 1 – Peak Pulse Power Rating
Figure 2 – Pulse Derating Curve
Figure 3 – Pulse Waveform
Figure 4 – Typical Junction Capacitance
Uni- Directional
Figure 5 – Steady State Power Derating Curve
Rev : 01.06.2014
Figure 6 – Maximum Non-Repetitive
2/6
www.leiditech.com
P6KE PART NUMBER
UNI-POLAR
BI-POLAR
P6SMB6.
8A
P6SMB7.
5A
P6SMB8.
2A
P6SMB9.
1A
P6SMB10
A
P6SMB11
A
P6SMB12
A
P6SMB13
A
P6SMB15
A
P6SMB16
A
P6SMB18
A
P6SMB20
A
P6SMB22
A
P6SMB24
A
P6SMB27
A
P6SMB30
A
P6SMB33
A
P6SMB36
A
P6SMB39
A
P6SMB43
A
P6SMB47
A
P6SMB51
A
P6SMB56
A
P6SMB62
A
P6SMB68
A
P6SMB75
A
P6SMB82
A
P6SMB6.8
CA
P6SMB7.5
CA
P6SMB8.2
CA
P6SMB9.1
CA
P6SMB10
CA
P6SMB11
CA
P6SMB12
CA
P6SMB13
CA
P6SMB15
CA
P6SMB16
CA
P6SMB18
CA
P6SMB20
CA
P6SMB22
CA
P6SMB24
CA
P6SMB27
CA
P6SMB30
CA
P6SMB33
CA
P6SMB36
CA
P6SMB39
CA
P6SMB43
CA
P6SMB47
CA
P6SMB51
CA
P6SMB56
CA
P6SMB62
CA
P6SMB68
CA
P6SMB75
CA
P6SMB82
CA
Rev : 01.06.2014
REVERSE
STANDOFF
VOLTAGE
VRWM(V)
BREAKDOWN
VOLTAGE
VBR(V) MIN. @IT
BREAKDOWN
VOLTAGE
VBR(V) MAX. @IT
TEST
CURRENT
IT (mA)
MAXIMUM
CLAMPING
VOLTAGE
@Ipp Vc(V)
PEAK
PULSE
CURRENT
Ipp (A)
REVERSE
LEAKAGE
@VRWM
IR(µA)
5.8
6.45
7.14
10
10.5
58.1
1000
6.4
7.13
7.88
10
11.3
54
500
7.02
7.79
8.61
10
12.1
50.4
200
7.78
8.65
9.55
1
13.4
45.5
50
8.55
9.5
10.5
1
14.5
42.1
10
9.4
10.5
11.6
1
15.6
39.1
5
10.2
11.4
12.6
1
16.7
36.5
5
11.1
12.4
13.7
1
18.2
33.5
5
12.8
14.3
15.8
1
21.2
28.8
5
13.6
15.2
16.8
1
22.5
27.1
5
15.3
17.1
18.9
1
25.5
24.2
5
17.1
19
21
1
27.7
22
5
18.8
20.9
23.1
1
30.6
19.9
5
20.5
22.8
25.2
1
33.2
18.4
5
23.1
25.7
28.4
1
37.5
16.3
5
25.6
28.5
31.5
1
41.4
14.7
5
28.2
31.4
34.7
1
45.7
13.3
5
30.8
34.2
37.8
1
49.9
12.2
5
33.3
37.1
41
1
53.9
11.3
5
36.8
40.9
45.2
1
59.3
10.3
5
40.2
44.7
49.4
1
64.8
9.4
5
43.6
48.5
53.6
1
70.1
8.7
5
47.8
53.2
58.8
1
77
7.9
5
53
58.9
65.1
1
85
7.2
5
58.1
64.6
71.4
1
92
6.6
5
64.1
71.3
78.8
1
103
5.9
5
70.1
77.9
86.1
1
113
5.4
5
3/6
www.leiditech.com
P6KE PART NUMBER
REVERSE
STANDOFF
VOLTAGE
VRWM(V)
BREAKDOWN
VOLTAGE
VBR(V) MIN.
@IT
BREAKDOWN
VOLTAGE
VBR(V) MAX.
@IT
TEST
CURRENT
IT (mA)
MAXIMUM
CLAMPING
VOLTAGE @Ipp
Vc(V)
PEAK
PULSE
CURRENT
Ipp (A)
REVERSE
LEAKAGE
@VRWM
IR(µA)
UNI-POLAR
BI-POLAR
P6SMB91A
P6SMB91CA
77.8
86.5
95.5
1
125
4.9
5
P6SMB100A
P6SMB100CA
85.5
95
105
1
137
4.5
5
P6SMB110A
P6SMB110CA
94
105
116
1
152
4
5
P6SMB120A
P6SMB120CA
102
114
126
1
165
3.7
5
P6SMB130A
P6SMB130CA
111
124
137
1
179
3.4
5
P6SMB150A
P6SMB150CA
128
143
158
1
207
2.9
5
P6SMB160A
P6SMB160CA
136
152
168
1
219
2.8
5
P6SMB170A
P6SMB170CA
145
162
179
1
234
2.6
5
P6SMB180A
P6SMB180CA
154
171
189
1
246
2.5
5
P6SMB200A
P6SMB200CA
171
190
210
1
274
2.2
5
P6SMB220A
P6SMB220CA
185
209
231
1
328
1.9
5
P6SMB250A
P6SMB250CA
214
237
263
1
344
1.8
5
P6SMB300A
P6SMB300CA
256
285
315
1
414
1.5
5
P6SMB350A
P6SMB350CA
300
332
368
1
482
1.3
5
P6SMB400A
P6SMB400CA
342
380
420
1
548
1.1
5
P6SMB440A
P6SMB440CA
376
418
462
1
602
1
5
P6SMB480A
P6SMB480CA
408
456
504
1
658
0.9
5
P6SMB510A
P6SMB510CA
434
485
535
1
698
0.9
5
P6SMB530A
P6SMB530CA
477
503.5
556.5
1
725
0.8
5
P6SMB540A
P6SMB540CA
459
513
567
1
740
0.8
5
P6SMB550A
P6SMB550CA
495
522.5
577.5
1
760
0.8
5
For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
For parts without A (VBR is ± 10% and VC is 5% higher than with A parts).
Rev : 01.06.2014
4/6
www.leiditech.com
Soldering Parameters
-Temperature Min(Ts(min))
-Temperature Max(Ts(min))
-Time(min to max)(ts)
Average ramp up rate liquidus
Temp (TL) to peak
TS(max)to TL-ramp-up Rate
-Temperature
L)(Liquidus)
(T
Reflow
Peak Temperature(TP)
Pre
Heat
Time within 5℃ of actual peak
Temperature(tp)
Ramp-down Rate
Time 25℃ to peak Temperature
(TP)
Do not exceed
150℃
200℃
60-180 secs
3℃/second max
3℃/second max
217℃
60-150 seconds
260+0/-5℃
20-40 seconds
Flow/Wave Soldering(Solder Dipping)
6℃/second max
260℃
10 seconds
1 time
Peak Temperature:
8minutes Max.
Dipping Time:
280℃
Soldering:
Dimensions
B
Inches
MIN
MAX
Millimeters
MIN
MAX
A
0.134
0.155
3.40
3.94
B
0.205
0.22
5.21
5.59
C
0.075
0.083
1.90
2.11
D
0.166
0.185
4.22
4.70
E
0.036
0.056
0.91
1.42
F
0.073
0.087
1.85
2.2
G
0.002
0.008
0.05
0.20
Dimension
H
0.077
0.094
1.95
2.40
J
0.043
0.053
1.09
1.35
K
0.008
0.014
0.20
0.35
L
0.039
0.049
0.99
1.24
Rev : 01.06.2014
D
C
A
H
F
L
E
J
K
G
.079
(2.0)
0.110
(2.8)
.079
(2.0)
5/6
www.leiditech.com
Part Numbering System
Part Marking System
Cathode Band
5%Voltage Tolerance
Bidirectional
Voltage
Product Type
Series
Summary of Packing Options
Package Type
Description
Packing
Quantity
Industry
Standard
Embossed Carrier Reel Pack
3000PCS
EIA-481-D
DO-214AA(SMB)
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
6/6
www.leiditech.com
很抱歉,暂时无法提供与“P6SMB18CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.48180
- 50+0.38600
- 150+0.33720
- 500+0.29530
- 3000+0.27000
