P8S36CA
P8S36CA
    LEIDITECH(雷卯电子)
    AXIAL_D9.1X9.4MM_TM
    TVS二极管 VRWM=36V VBR(Min)=40V VC=58.1V IPP=137.7A Ppp=8000W
P8S36CA 数据手册
P8S Series 8000W Transient Voltage Suppressor DESCRIPTION: The P8S series of high current uni/bi-directional transient suppressors are designed for A.C. line protection and high power DC bus clamping applications. These devices offer uni/bi-directional port protection from 20 volts to 43 volts. They provide a clamping voltage lower than the avalanche voltage. Therefore, any voltage rise due to increased current conduction is contained to a minimum, providing the best possible protection level. They can also be connected in series and/or parallel to create very high capacity protection solutions. Symbol FEATURES:          Low zener impedance. Excellent clamping capability. JEDEC R-6/P-600 Molded Plastic. Repetition rate (duty cycle): 0.01%. Color band denoted cathode except bidirectional. High temperature soldering: 260℃/10s at terminals. Glass passivated chip junction in R-6/P600 package. 8000W Peak Pulse power capability at 10×1000μs waveform. Fast response time: typically less than 1.0ps from 0V to VBR min.  AEC-Q101 qualified. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit PPP 8000 W IPP See next table A PM(AV) 8 W TSTG, TJ -55 to +150 ℃ IFSM 500 A Peak pulse power dissipation on 10/1000μs waveform Peak pulse current of on 10/1000μs waveform Steady state power dissipation at TL=75℃ Operating junction and Storage temperature range Peak forward surge current, 8.3ms single half sine-wave Rev : 01.06.2014 1/4 www.leiditech.com P8S Series 8000W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A P8S20A P8S20CA 20 5 22.2 24.5 5 32.4 246.9 P8S22A P8S22CA 22 5 24.4 26.9 5 35.5 225.3 P8S24A P8S24CA 24 5 26.7 29.5 5 38.9 205.6 P8S26A P8S26CA 26 5 28.9 31.9 5 42.1 190.1 P8S28A P8S28CA 28 5 31.1 34.4 5 45.4 176.2 P8S30A P8S30CA 30 5 33.3 36.8 5 48.4 165.3 P8S33A P8S33CA 33 5 36.7 40.6 5 53.3 150.1 P8S36A P8S36CA 36 5 40.0 44.2 5 58.1 137.7 P8S40A P8S40CA 40 5 44.4 49.1 5 64.5 124.1 P8S43A P8S43CA 43 5 47.8 52.8 5 69.4 115.3 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR:Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR:Reverse Leakage Current RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) F IG .1:V - I cu rv e ch aracteristics (U n i-d ire ctio n al) F IG .2:V - I cu rv e ch aracteristics (B i-d irectio n al) IP P V V C V BR V R V C V BR V R VF V IR IT VR VBR VC I PP I PP Rev : 01.06.2014 IT IR 2/4 www.leiditech.com P8S Series 8000W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform P PP derating in percentage(%) 100 IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 50 T A (℃ ) 75 100 125 150 175 SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) tp Critical Zone TL to TP Ramp-up tL TS(max) -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Temperature Pre Heat Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time MARKING & ORDERING INFORMATION P8S XX C A (1) (2) (3) (4) (1)Series:8000 watts series (2)Reverse Stand-off Voltage (3)Bi-directional (4)5% VBR Voltage tolerance Cathode Band Logo P8SxxCA Rev : 01.06.2014 Product Type 3/4 www.leiditech.com P8S Series 8000W Transient Voltage Suppressor PACKAGE MECHANICAL DATA Dimensions A B A Ref. Min. C D Millimeters Inches Max. Min. Max. - 25.40 - A 1.000 B 0.339 0.370 8.60 9.40 C 0.048 0.052 1.20 1.40 D 0.340 0.360 8.60 9.10 Part Number Case Type Quantity Packing Option P8SXXCA/A R6/P600 300 Box Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
P8S36CA 价格&库存
很抱歉,暂时无法提供与“P8S36CA”相匹配的价格&库存,您可以联系我们找货
