X32258MOB4SI
X32258MOB4SI
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 8MHz ±10ppm 12pF 150Ω -40℃~+85℃
X32258MOB4SI 数据手册
【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX321SL Features . External dimensions: 3.2 x 2.5 x 0.8 mm. . Frequency range: 11.0592MHz ~ 54MHz. C Y X X X X 0 . 12 .High precision and high frequency stability. .Extremely good for reducing EMI effect. .RoHS Compliant / Pb Free. . The best choice of Bluetooth, wireless communication set, DSC, PDA and mobile phone. Electrical Specifications YSX321SL Nominal Frequency Range 11.0592 ~ 54 MHz Vibration Mode AT Fundamental Load Capacitance 12 pF, 20 pF, or specify Remark : Speci mark : Speci Item / Type Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 7 pF Max. Level Of Drive 1 ~100 μW Max. (10 uW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Insulation Resistance More Than 500MΩ at DC 100V Equivalent Series Resistance(ESR) Fundamental 11.0592 ~ 16 MHz 80 Ω Max. 16 ~ 20 MHz 60 Ω Max. 20 ~ 54 MHz 40 Ω Max. Dimensions YXC 12.0XXX Units: mm come visit our site http://www.yxc.hk 1/2 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX321SL ★ PART NUMBER GUIDE 部件号示例 e.g. X322512MSB4 SC Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 3225 Frequency Stability Pin Overall (ppm) S ★ TAPING SPECIFICATION (Unit: mm) 4.0 YSX321SL =3.2×2..5 SMD SEAM TYPE 4 B Material Operating Temp. Range S C 编带规格 φ1.95 1.1 12 0° φ13 5.1 C B D SMD3225 G A F E A B C 178±2.0 8.03±0.3 D 3.81±0.10 3.04±0.10 E F G 3.84±0.1 1.54±0.10 62.0±1.0 3000 pcs per reel ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ come visit our site http://www.yxc.hk 2/2 120sec. max
X32258MOB4SI 价格&库存
很抱歉,暂时无法提供与“X32258MOB4SI”相匹配的价格&库存,您可以联系我们找货
X32258MOB4SI
库存:7300
X32258MOB4SI
  • 1+0.91809
  • 200+0.70498
  • 1500+0.61408
  • 3000+0.57065
X32258MOB4SI
  • 5+1.18482
  • 50+0.91944
  • 600+0.91025
  • 1200+0.89204
  • 3000+0.86528
库存:6686
X32258MOB4SI
库存:2254
