S1T80000ZWDBC
S1T80000ZWDBC
    JYJE(晶友嘉)
    HC-49S/SMD
    无源晶振 8MHz 20pF ±20ppm 60Ω -40℃~+85℃ HC-49S/SMD
S1T80000ZWDBC 数据手册
深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD CRYSTAL RESONATOR SPECIFICATIONS 石英晶体谐振器承认书 客户 Customer: 型号 Product: 49SSMD 料号 Code No: S1T80000ZWDBC 频率 Frequency: 8.000MHz 数量 Sample Quantity: 日期 Date: 2019-8-20 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 深圳市龙华区东环二路 57 号杰美康创意园 B 栋 233 TEL: 86-755-32840201 32850080 FAX: 86-755-84269460 供应商确认栏: 制作 Handler 戴晓嘉 确认 Checked 李晨 核审 Approved 陈斌 客户承认栏: 承认 Checked 核审 Approved 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 1.Electrical Parameters No. Item Symb Electrical Specification Min. F0 Type Max. 8.000 Remark Units 1 Nominal Frequency MHz 2 Mode of Vibration 3 Frequency Tolerance ΔF/F0 -20 20 ppm 4 Operating Temperature Range TOPR -40 85 ℃ 5 Frequency Stability TC -20 20 ppm 6 Storage Temperature TSTG -40 85 ℃ 7 Load Capacitance CL 8 Equivalent Series Resistance ESR 60 Ω 9 Drive Level DL 100 μW 10 Insulation Resistance IR 11 Shunt Capacitance C0 PF 12 Motional Capacitance C1 PF 13 Aging Per Year Fa Fundamental 2. Equivalent Circuit: Page:2 20 PF MΩ 500 -3 At 25℃±3℃ 3 ppm At 100VDC First Year 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 3.实物 Product 4.外型尺寸 Outline Dimensions (unit:mm) H H1: 4.2mm Max H2: 3.0mm Max Page:3 ★ 深圳市晶友嘉电子有限公司 SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD 5.回流焊曲线 Reflow Profiles Profiles Feature Pb-Free Assembly Average Ramp-up Rate (Ts max to Tp) 3℃/second max. Preheat Temperature Min (Ts min) Temperature Max(Ts max) Time (ts min to ts max) 125℃ 200℃ 60~180 seconds Time maintained above Temperature (TL) Time (tL) 217℃ 60~150 seconds Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature(tp) 20~40 second Ramp-down rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Suggest reflow times 3 times max. Page:4 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 6.机械可靠/信赖性 Mechanical Performance Item 1. 2.. Drop characteristics Shake characteristics Condition Standard Free drop from 50cm height on a hard Frequency change: wooden board for 3 times. (Board is ≤5ppm thickness more than 30 mm.) Rr as specification Shake frequency 10~55Hz, cyc1~2 Frequency change: minutes, swing 1.5mm, direction x/y/z, ≤5ppm all 30 minutes, test after 1 hours. Rr as specification Put crystal into the pressure cabin with 3. Airproof alcohol, keep pressure 0.4~0.5mpa 10 characteristics minutes, then take out and blow for 5 IR≥500MΩ minutes 4. 5. 6. 7. 8. Weld characteristics Humidity characteristics 260℃ Max, 10 seconds 90% exhibit tin ok Frequency change: +40±2℃ & 90%~95% R.H. 250 hours ≤5ppm Rr as specification Low temperature -30±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. High temperature +85±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. Temperature -30±3℃/30±3 min~+85±2℃/30±3min, 5 cycling cycles Page:5 Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 7.Dimension of Inside Package 内包装尺寸图 Page:6 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 8.包装 PACKING 1. 每 盘 数 量 Capacity of a plastic reel : 1000 PCS ; 2. 每内箱数量 Capacity per inner box : 1000 PCS (A reel inner) ; 3. 每大箱数量 Capacity per outer carton : 10000 PCS (10×inner box) . Page:7
S1T80000ZWDBC 价格&库存
很抱歉,暂时无法提供与“S1T80000ZWDBC”相匹配的价格&库存,您可以联系我们找货
S1T80000ZWDBC
  • 1+0.39000
  • 100+0.36400
  • 300+0.33800
  • 500+0.31200
  • 2000+0.29900
  • 5000+0.29120
