SMCJ Series 1500W Transient Voltage Suppressor
DESCRIPTION
TVS diodes can be used in a wide range of applications
which like consumer electronic products, automotive
industries, munitions, telecommunications, aerospace
industries, and intelligent control systems.
SMC
FEATURES
Low profile package.
Low inductance.
Excellent clamping capability.
1500W peak pulse power capability at 10×1000μs waveform
Typical IR less than 1μA above 10V.
Fast response time: typically less than 1.0ps from 0V to VBR min.
High temperature to reflow soldering: 260℃/40s at terminals.
Plastic package has underwriters laboratory flammability 94V-0.
Meets MSL level 1, per J-STD020, LF maximum peak of 260℃.
For surface mounted applications in order to optimize board space.
AEC-Q101 qualified.
Symbol
ABSOLUTE MAXIMUM RATINGS (TA=25℃, RH=45%-75%, unless otherwise noted)
Parameter
Storage temperature range
Operating junction temperature range
Steady state power dissipation at TL=50℃
Peak pulse power dissipation on 10/1000μs
waveform
Maximum instantaneous forward voltage at
100A for unidirectional
Rev : 01.06.2015
1/6
Symbol
Value
Unit
Tstg
-60 to +150
Tj
-40 to +150
PM(AV)
6.5
W
PPP
1500
W
VF
5.0
V
www.leiditech.com
ELECTRICAL CHARACTERISTICS (TA=25℃)
Part Number
VR
IR@VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
SMCJ5.0A
SMCJ5.0CA
5.0
300
6.40
7.00
10
9.2
163.0
SMCJ6.0A
SMCJ6.0CA
6.0
250
6.67
7.37
10
10.3
145.6
SMCJ6.5A
SMCJ6.5CA
6.5
150
7.22
7.98
10
11.2
134.0
SMCJ7.0A
SMCJ7.0CA
7.0
100
7.78
8.60
10
12.0
125.0
SMCJ7.5A
SMCJ7.5CA
7.5
50
8.33
9.21
1
12.9
116.3
SMCJ8.0A
SMCJ8.0CA
8.0
30
8.89
9.83
1
13.6
110.3
SMCJ8.5A
SMCJ8.5CA
8.5
10.40
1
14.4
104.2
SMCJ9.0A
SMCJ9.0CA
9.0
10
10.00
11.10
1
15.4
97.4
SMCJ10A
SMCJ10CA
10
5
11.10
12.30
1
17.0
88.2
SMCJ11A
SMCJ11CA
11
2
12.20
13.50
1
18.2
82.4
SMCJ12A
SMCJ12CA
12
1
13.30
14.70
1
19.9
75.4
SMCJ13A
SMCJ13CA
13
1
14.40
15.90
1
21.5
69.8
SMCJ14A
SMCJ14CA
14
1
15.60
17.20
1
23.2
64.7
SMCJ15A
SMCJ15CA
15
1
16.70
18.50
1
24.4
61.5
SMCJ16A
SMCJ16CA
16
1
17.80
19.70
1
26.0
57.7
SMCJ17A
SMCJ17CA
17
1
18.90
20.90
1
27.6
54.4
SMCJ18A
SMCJ18CA
18
1
20.00
22.10
1
29.2
51.4
SMCJ20A
SMCJ20CA
22.20
24.50
1
32.4
46.3
SMCJ22A
SMCJ22CA
22
1
24.40
26.90
1
35.5
42.3
SMCJ24A
SMCJ24CA
24
1
26.70
29.50
1
38.9
38.6
SMCJ26A
SMCJ26CA
26
1
28.90
31.90
1
42.1
35.6
SMCJ28A
SMCJ28CA
28
1
31.10
34.40
1
45.4
33.1
SMCJ30A
SMCJ30CA
30
1
33.30
36.80
1
48.4
31.0
SMCJ33A
SMCJ33CA
33
1
36.70
40.60
1
53.3
28.2
SMCJ36A
SMCJ36CA
36
1
40.00
44.20
1
58.1
25.8
SMCJ40A
SMCJ40CA
40
1
44.40
49.10
1
64.5
23.3
SMCJ43A
SMCJ43CA
43
1
47.80
52.80
1
69.4
21.6
SMCJ45A
SMCJ45CA
45
1
50.00
55.30
1
72.7
20.6
SMCJ48A
SMCJ48CA
48
1
53.30
58.90
1
77.4
19.4
SMCJ51A
SMCJ51CA
51
1
56.70
62.70
1
82.4
18.2
Rev : 01.06.2015
2/6
www.leiditech.com
ELECTRICAL CHARACTERISTICS (TA=25℃,continued)
Part Number
VR
IR@VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
SMCJ54A
SMCJ54CA
54
1
60.00
66.30
1
87.1
17.2
SMCJ58A
SMCJ58CA
58
1
64.40
71.20
1
93.6
16.1
SMCJ60A
SMCJ60CA
60
1
66.70
73.70
1
96.8
15.5
SMCJ64A
SMCJ64CA
64
1
71.10
78.60
1
103.0
14.6
SMCJ70A
SMCJ70CA
70
1
77.80
86.00
1
113.0
13.3
SMCJ75A
SMCJ75CA
75
1
83.30
92.10
1
121.0
12.4
SMCJ78A
SMCJ78CA
78
1
86.70
95.80
1
126.0
11.9
SMCJ85A
SMCJ85CA
85
1
94.40
104.0
1
137.0
11.0
SMCJ90A
SMCJ90CA
90
1
100.0
111.0
1
146.0
10.3
SMCJ100A SMCJ100CA
100
1
111.0
123.0
1
162.0
9.3
SMCJ110A
SMCJ110CA
110
1
122.0
135.0
1
177.0
8.5
SMCJ120A SMCJ120CA
120
1
133.0
147.0
1
193.0
7.8
SMCJ130A SMCJ130CA
130
1
144.0
159.0
1
209.0
7.2
SMCJ150A SMCJ150CA
150
1
167.0
185.0
1
243.0
6.2
SMCJ160A SMCJ160CA
160
1
178.0
197.0
1
259.0
5.8
SMCJ170A SMCJ170CA
170
1
189.0
209.0
1
275.0
5.5
SMCJ180A SMCJ180CA
180
1
201.0
222.0
1
292.0
5.2
SMCJ190A SMCJ190CA
190
1
211.0
234.0
1
307.0
4.9
SMCJ200A SMCJ200CA
200
1
224.0
247.0
1
324.0
4.7
SMCJ210A SMCJ210CA
210
1
233.0
258.0
1
337.0
4.5
SMCJ220A SMCJ220CA
220
1
246.0
272.0
1
356.0
4.2
SMCJ250A SMCJ250CA
250
1
279.0
309.0
1
405.0
3.7
SMCJ300A SMCJ300CA
300
1
335.0
371.0
1
486.0
3.1
SMCJ350A SMCJ350CA
350
1
391.0
432.0
1
567.0
2.7
SMCJ400A SMCJ400CA
400
1
447.0
494.0
1
648.0
2.3
SMCJ440A SMCJ440CA
440
1
492.0
543.0
1
713.0
2.1
① Surge waveform: 10/1000μs
VR: Stand-off voltage -- maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
Rev : 01.06.2015
3/6
www.leiditech.com
ORDERING INFORMATION
SMCJ
xx
C
A
5% VBR Voltage tolerance
1500W SMC Series
C: Bi-directional
VR Voltage
RATINGS AND V-I CHARACTERISTICS CURVES (TA=25℃, unless otherwise noted)
FIG.1:V- I curve characteristics
(Uni-directional)
FIG.2:V- I curve characteristics
(Bi-directional)
IPP
V
VC VBR VR
VC VBR VR
VF
V
IR
IT
VR VBR VC
IPP
IPP
FIG.4: Pulse derating curve
FIG.3: Pulse waveform
PPP derating in percentage(%)
100
IPPM(%IRSM)
150
tr = rise time to peak value
td = decay time to half value
tr=10μs
100
IT
IR
80
Peak value
60
Half value
40
50
td
Rev : 01.06.2015
1.0
t(ms)
2.0
3.0
4/6
25
50
TA (℃ )
75
100
125
150
175
www.leiditech.com
SOLDERING PARAMETERS
Pb-Free assembly
(see figure at right)
Pre
Heat
-Temperature Min (Ts(min))
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
tp
TP
Average ramp up rate (Liquidus Temp
(TL)to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
Reflow condition
Critical Zone
TL to TP
Ramp-up
TL
-Temperature(TL)(Liquidus)
+217℃
-Temperature(tL)
60-150 secs.
tL
TS(max)
Temperature
Reflow Condition
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃of actual Peak Temp (tp)
20-40secs.
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Ramp-down
Preheat
TS(min)
25
ts
time to peak temperatue
(t 25℃ to peak)
Time
PACKAGE MECHANICAL DATA
B
Dimensions
H
F
A
C
Ref.
D
K
J
L
J
G
E
Millimeters
Min.
Max.
Min.
Max.
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
L
Rev : 01.06.2015
5/6
0.094
4.20
K
DO-214AB (SMC)
Inches
3.30
0.165
0.130
www.leiditech.com
TAPE AND REEL SPECIFICATION-SMC
P0 P1
Cathode
F E
d
Dimensions
B
W
Ref.
A
P
Millimeters
Inches
A
6.05 ± 0.3
0.238 ± 0.012
B
8.31 ± 0.3
0.327 ± 0.012
d
1.55 ± 0.1
0.061 ± 0.004
D
330.0
13.0
D2
13.3 ± 0.3
0.524 ± 0.012
E
1.75 ± 0.2
0.069 ± 0.008
F
7.50 ± 0.2
0.295 ± 0.008
P
8.00 ± 0.2
0.3145 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
2.00 ± 0.2
0.079 ± 0.008
W
16.0 ± 0.2
0.630 ± 0.008
W1
19.7 ± 2.0
0.776 ± 0.079
PART No.
PACKAGE
QUANTITY
TAPE & REEL
SMCJxxCA/A
SMC(DO-214AB)
3,000
13inch
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2015
6/6
www.leiditech.com
很抱歉,暂时无法提供与“SMCJ36CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.36400
- 100+1.05380
- 750+0.87890
- 1500+0.79750
- 3000+0.74030
