RS1M-SMA
RS1M-SMA
    MDD(辰达半导体)
    SMA(DO-214AC)
    VR=1000V IF=1A 15pF trr=500ns
RS1M-SMA 数据手册
RS1A THRU RS1M SURFACE MOUNT FAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere FEATURES DO-214AC/SMA The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds at terminals Glass passivated chip junction 0.110(2.80) 0.100(2.54) 0.067 (1.70) 0.051 (1.30) 0.177(4.50) 0.157(3.99) 0.012(0.305) 0.006(0.152) 0.096(2.42) 0.078(1.98) MECHANICAL DATA 0.060(1.52) 0.030(0.76) Case : JEDEC DO-214AC molded plastic body over passivated chip Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 Polarity : Color band denotes cathode end Mounting Position : Any Weight :0.002 ounce, 0.07 grams 0.008(0.203)MAX. 0.208(5.28) 0.188(4.80) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=90 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range SYMBOLS VRRM VRMS VDC RS1A RS1B RS1D RS1G RS1J 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 RS1K RS1M UNITS 800 560 800 VOLTS VOLTS VOLTS 1000 700 1000 I(AV) 1.0 Amp IFSM 30.0 Amps VF 1.3 Volts IR 5.0 50.0 µA trr CJ RθJA TJ,TSTG 150 250 15.0 50.0 -50 to +150 500 ns pF C/W C Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 2014-03 01版 http://www.microdiode.com FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES RS1A THRU RS1M FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 25 20 15 10 175 5.0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C 10 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.01 0.6 0.8 1.0 1.2 1.4 1.5 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 0.1 1,000 100 10 TJ=100 C 1 0.1 TJ=25 C 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TJ=25 C 10 TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 200 100 100 NUMBER OF CYCLES AT 60 Hz FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 2014-03 01版 100 t,PULSE DURATION,sec. http://www.microdiode.com
RS1M-SMA
1. 物料型号:RS1A至RS1M 2. 器件简介:这些是表面安装的快速恢复整流器,具有不同的反向电压等级(50至1000伏)和1.0安培的正向电流。 3. 引脚分配:文档中没有明确说明引脚分配,但提到了极性,其中色带表示阴极端。 4. 参数特性: - 反向电压:50至1000伏 - 正向电流:1.0安培 - 峰值正向浪涌电流:某些型号可达30.0安培 - 最大瞬时正向电压:某些型号为1.3伏 - 最大直流反向电流:在25°C时,某些型号为5.0至50.0微安 - 最大反向恢复时间:某些型号为150至500纳秒 - 典型结电容:某些型号为15.0皮法 - 典型热阻:某些型号为50.0摄氏度/瓦 5. 功能详解:包括低反向漏电、内置应变消除(适合自动化放置)、高正向浪涌电流能力、高温焊接保证(250°C/10秒在端子上)、玻璃钝化芯片结。 6. 应用信息:适用于表面安装应用。 7. 封装信息:JEDEC DO-214AC塑封体,覆盖钝化芯片,端子为可焊接的,符合MIL-STD-750标准。
RS1M-SMA 价格&库存
很抱歉,暂时无法提供与“RS1M-SMA”相匹配的价格&库存,您可以联系我们找货
