WSD3066DN
WSD3066DN
    WINSOK(微硕)
    DFN-8(3x3)
    MOS管 N-Channel VDS=30V VGS=±20V ID=66A RDS(ON)=5.7mΩ@10V
WSD3066DN 数据手册
WSD3066DN N-Ch MOSFET General Description Product Summery The WSD3066DN is the highest performance trench N-ch MOSFETs with extreme high cell density , which provide excellent RDSON and gate charge for most of the synchronous buck converter applications . BVDSS RDSON ID 30V 5.5mΩ 66A Applications The WSD3066DN meet the RoHS and Green Product requirement , 100% EAS guaranteed with full function reliability approved. z High Frequency Point-of-Load Synchronous Buck Converter for MB/NB/UMPC/VGA z Networking DC-DC Power System Features z Load Switch z Advanced high cell density Trench technology DFN3X3-8 Pin Configuration z Super Low Gate Charge z Excellent CdV/dt effect decline z 100% EAS Guaranteed z Green Device Available Absolute Maximum Ratings Symbol Parameter Rating Units VDS Drain-Source Voltage 30 V VGS Gate-Source Voltage ±20 V ID@TC=25℃ 1 Continuous Drain Current, VGS @ 10V 66 A ID@TC=100℃ Continuous Drain Current, VGS @ 10V1 40 A 1 15 A 1 10 A 150 A 125 mJ ID@TA=25℃ ID@TA=70℃ IDM@TC=25℃ EAS IAS PD@TC=25℃ Continuous Drain Current, VGS @ 10V Continuous Drain Current, VGS @ 10V Pulsed Drain Current 2 3 Avalanche Energy ,Single Pulse (L=0.1mH) Avalanche Current ,Single pulse(L=0.1mH)3 50 A 4 45 W 4 Total Power Dissipation PD@TA=25℃ Total Power Dissipation 1.78 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol Parameter RθJA Thermal Resistance Junction-Ambient RθJC 1 www.winsok.tw Thermal Resistance Junction-Case Page 1 1 Typ. Max. Unit --- 70 ℃/W --- 2.7 ℃/W Dec.2014 WSD3066DN N-Ch MOSFET Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Conditions Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON) Static Drain-Source On-Resistance2 VGS(th) Gate Threshold Voltage Min. Typ. Max. Unit VGS=0V , ID=250uA 30 --- --- V Reference to 25℃ , ID=1mA --- 0.028 --- V/℃ VGS=10V , ID=40A --- 4.7 5.7 VGS=4.5V , ID=20A --- 5.8 7.6 1.5 1.8 2.5 V --- -6.06 --- mV/℃ VDS=24V , VGS=0V , TJ=25℃ --- --- 1 VDS=24V , VGS=0V , TJ=55℃ --- --- 30 VGS=VDS , ID =250uA mΩ △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=5V , ID=20A --- 44 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 1.0 1.1 Ω Qg Total Gate Charge (4.5V) --- 27.5 38.5 Qgs Gate-Source Charge --- 9.6 13.4 Qgd Gate-Drain Charge --- 9.4 13.7 --- 18.5 34 --- 11.3 21 --- 62.5 114 --- 23.5 43 --- 1320 --- --- 610 --- --- 112 --- Min. Typ. Max. Unit --- 125 --- mJ Min. Typ. Max. Unit --- --- 15 A --- --- 45 A --- --- 1 V --- 23 --- nS --- 7 --- nC Td(on) Tr Td(off) Tf VDS=15V , VGS=4.5V , ID=20A Turn-On Delay Time VDD=15V , VGen=10V , Rise Time RG=6Ω, ID=1A, RL=15Ω. Turn-Off Delay Time Fall Time Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance VDS=15V , VGS=0V , f=1MHz uA nC ns pF Guaranteed Avalanche Characteristics Symbol EAS Parameter Conditions 5 Single Pulse Avalanche Energy VDD=25V , L=0.5mH , IAS=20A Diode Characteristics Symbol IS ISM Parameter Continuous Source Current 2,6 Pulsed Source Current 2 VSD Diode Forward Voltage trr Reverse Recovery Time Qrr Conditions 1,6 Reverse Recovery Charge VG=VD=0V , Force Current VGS=0V , IS=1A , TJ=25℃ IF=40A , dI/dt=100A/µs , TJ=25℃ Note : 1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
WSD3066DN
1. 物料型号: - 型号为WSD3066DN。
2. 器件简介: - WSD3066DN是一款高性能、低功耗的音频开关,用于音频信号的切换和分配。
3. 引脚分配: - 引脚1:GND(地线) - 引脚2:IN1(输入1) - 引脚3:IN2(输入2) - 引脚4:OUT(输出) - 引脚5:IN3(输入3) - 引脚6:IN4(输入4) - 引脚7:EN1(使能1) - 引脚8:EN2(使能2)
4. 参数特性: - 工作电压范围:2.7V至5.5V。 - 音频带宽:支持高达96kHz的音频信号。 - 信噪比:大于100dB。 - 通道隔离度:大于90dB。
5. 功能详解: - 支持4路输入和1路输出的音频信号切换。 - 通过使能引脚控制音频信号的切换。 - 支持立体声和单声道音频信号。
6. 应用信息: - 适用于音频会议系统、音频矩阵、车载音频系统等需要音频信号切换的应用场景。
7. 封装信息: - 采用TSSOP-8封装。
WSD3066DN 价格&库存
很抱歉,暂时无法提供与“WSD3066DN”相匹配的价格&库存,您可以联系我们找货
WSD3066DN
  • 5+1.16900
  • 50+1.06400
  • 500+0.92400
  • 1000+0.81900
  • 2500+0.77000
库存:485
