WST2005
P-Ch MOSFET
General Description
Product Summery
The H is P-Channel enhancement mode power
MOSFET which is produced with high cell
density and DMOS trench technology .This
device particularly suits low voltage
applications, especially for battery powered
circuits, the tiny and thin outline saves PCB
consumption. are electrically identical.
-RoHS Compliant
BVDSS
RDSON
ID
-20V
155mΩ
-1.6A
Applications
z High Frequency Point-of-Load Synchronous s
Small power switching for MB/NB/UMPC/VGA
z A Switch and Battery Switch for Portable Devices
z Load Switch
Features
SOT-323 Pin Configuration
z Advanced high cell density Trench technology
D
z Super Low Gate Charge
3
z Excellent Cdv/dt effect decline
z Green Device Available
1
2
G
S
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-20
V
VGS
Gate-Source Voltage
±12
V
-1.6
A
-5
A
ID@Tc=25℃
IDM
1
Continuous Drain Current, VGS @ -4.5V
Pulsed Drain Current
2
PD@TA=25℃
Total Power Dissipation
350
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
www.winsok.tw
3
Page 1
mW
Dec.2014
WST2005
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
RDS(ON)
Parameter
Conditions
Drain-Source Breakdown Voltage
2
Static Drain-Source On-Resistance
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
VGS=-4.5V , ID=-1A
145
155
VGS=-2.5V , ID=-0.5A
150
168
VGS=-1.8V , ID=-0.3A
180
220
-0.4
-0.7
-1
V
mΩ
Gate Threshold Voltage
VGS=VDS , ID =-250uA
IDSS
Drain-Source Leakage Current
VDS=-20V , VGS=0V , TJ=25℃
-1
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-2A
5
S
Qg
Total Gate Charge (-4.5V)
4.9
Qgs
Gate-Source Charge
0.62
Qgd
Gate-Drain Charge
1.07
VGS(th)
VDS=-6V , VGS=-4.5V , ID=-2.8A
10.1
Rise Time
4.76
Turn-Off Delay Time
RGEN=6Ω, RL=6Ω,
84.1
Fall Time
25.2
Ciss
Input Capacitance
472
Coss
Output Capacitance
71
Crss
Reverse Transfer Capacitance
51
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-6V , VGS=0V , f=1MHz
nC
ns
-pF
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST2005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39016
- 100+0.31085
- 300+0.27119
- 3000+0.23688
- 6000+0.21307
- 9000+0.20121
- 国内价格
- 10+0.48833
- 100+0.38907
- 600+0.38323
- 1200+0.37173
- 3000+0.35500
