YNR2510-1R5M
YNR2510-1R5M
    YJYCOIN(益嘉源)
    SMD,2.5x2mm
    功率电感 1.5µH ±20% IND_2.5X2MM_SM 1.00mm 2.50 x 2.00mm 182mΩ 1.3A
YNR2510-1R5M 数据手册
SMD Power Inductors -YNR2510 Series ■ Features ● Low profile construction and miniature size. ● Magnetic shielded construction. ● High current saturation. ● Operating temperature:-40℃ ~ +125℃. ● RoHS compliant ■ Applications ● For small DC/DC converter(HDD,DVC,DSC,PDA,LCD display etc.). ● Car navigation systems,telecom base stations. ● VR,AR,LED lighting. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance value ⑷ :Inductance Tolerance;N=±30%,M=±20%,K=±10% ■ Shapes and Dimensions (Unit:mm) TYPE A B C Max. D E Ref. F Ref. G Ref. YNR2510 2.5±0.1 2.0±0.1 1.00 0.80±0.2 2.00 0.85 0.80 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -1- SMD Power Inductors -YNR2510 Series ■ YNR2510 Series Part Number Inductance DC Resistance (Ω) Heat Rating Saturation (uH) @100KHz Typ. Max. Current (A) Current (A) YNR2510-R22□ 0.22 0.030 0.036 3.00 2.70 YNR2510-R47□ 0.47 0.047 0.056 2.35 2.50 YNR2510-R68□ 0.68 0.062 0.074 2.00 2.20 YNR2510-1R0□ 1.00 0.090 0.108 1.65 1.85 YNR2510-1R5□ 1.50 0.152 0.182 1.30 1.80 YNR2510-2R2□ 2.20 0.174 0.209 1.20 1.20 YNR2510-3R3□ 3.30 0.273 0.328 0.90 1.05 YNR2510-4R7□ 4.70 0.469 0.563 0.70 0.95 YNR2510-5R6□ 5.60 0.469 0.563 0.73 0.80 YNR2510-6R8□ 6.80 0.747 0.896 0.59 0.78 YNR2510-100□ 10.0 0.910 1.092 0.50 0.65 YNR2510-150□ 15.0 1.160 1.508 0.50 0.40 YNR2510-220□ 22.0 1.250 1.625 0.45 0.40 ※ The saturation current value is the DC current value having inductance decrease down to 30%.(at 20℃) ※ The temperature rise current value is the DC current value having temperature increase up to 40℃. (at 20℃) ※ The rated current is the DC current value that satisfies both of current value saturation current value and temperature rise current value. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -2- SMD Power Inductors -YNR2510 Series ■ Taping Dimensions(Unit:mm) TYPE Chip Thickness W A B D P K Max T Max MPQ YNR2510 1.00 8.00 2.35 2.65 3.50 4.00 1.20 0.25 2000 ■ Reel Dimensions(Unit:mm) TYPE W W1 A B C D YNR2510 178±2.0 8.40±1.50 4.3±0.20 5.0±0.10 3.0±0.10 58±2.0 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -3- SMD Power Inductors -YNR2510 Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -4-
YNR2510-1R5M 价格&库存
很抱歉,暂时无法提供与“YNR2510-1R5M”相匹配的价格&库存,您可以联系我们找货
YNR2510-1R5M
  • 20+0.26040
  • 200+0.24360
  • 500+0.22680
  • 1000+0.21000
  • 3000+0.20160
  • 6000+0.18984
