X49SM16MSD2SC
X49SM16MSD2SC
    YXC(扬兴科技)
    HC-49S/SMD
    无源晶振 16MHz ±20ppm 20pF -20℃~+70℃
X49SM16MSD2SC 数据手册
HC-49SMD Features . External dimensions: 11.4 x 4.8 x 3.8 mm. . Frequency range: 3.579545MHz ~ 64MHz. C YX XX X 12.0 . Surface mount type crystal units. . A great number of standard frequencies. . High frequency pullability and low equivalent series resistance. . Highly mass production capability. . Applications: PC, STB, LCDM and Cable Modem. Electrical Specifications Item / Type HC-49SMD Nominal Frequency Range 3.579545 ~ 64 MHz Vibration Mode AT Fundamental Load Capacitance 12 pF, 20 pF, or specify Frequency Tolerance (at 25 ℃) ±1 0 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 7 pF Max. Level Of Drive 1 ~ 500 μW (100 μW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) 3rd Overtone Fundamental 3.579545 ~ 4 MHz 150 Ω Max. 20 ~ 25 MHz 100 Ω Max. 4 ~ 5 MHz 120 Ω Max. 25 ~ 64 MHz 80 Ω Max. 5 ~ 6 MHz 100 Ω Max. 6 ~ 7 MHz 80 Ω Max. 7 ~ 10 MHz 60 Ω Max. 10 ~ 27 MHz 40 Ω Max. Dimensions Units: mm 1/2 HC-49SMD ★ PART NUMBER GUIDE 部件号示例 Frequency Stability Overall (ppm) Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 49SM H C -4 9 SMD=11.4 × 4 .35 SMD SEAM TYPE e.g. X4 9 SM12MSD2SC S Pin Material Operating Temp. Range 2 S C D Frequency tolerance B ±10PPM D ±20PPM Load Capacitance (Pf) X 7.4pF G 12.5pF L 9pF 10pF M 12pF O P 15pF Operating temperature C -20~ +70 ℃ -40~ +85 ℃ I -40~ +125℃ A -40~ +105℃ F ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ 2/2 120sec. max
X49SM16MSD2SC
PDF文档中的物料型号为HC-49SMD,符合ROHS标准。
该器件是一种表面贴装型晶体单元,具有多种标准频率,高频率拉力和低等效串联电阻。
它广泛应用于PC、STB、LCDM和有线调制解调器。
电气规格包括: - 标称频率范围:3.579545-64MHz - 振动模式:AT基础 - 负载电容:12pF, 20pF或指定 - 频率容差(25°C时):±10ppm, ±20ppm或指定 - 频率与温度特性:±20ppm或指定 - 工作温度:-20°C至+70°C, -40°C至+85°C或指定 - 存储温度:-40°C至+85°C或指定 - 并联电容:最大7pF - 驱动水平:1-500mW(典型100mW) - 频率老化(25°C时):最大±3ppm/年
等效串联电阻(ESR)在不同频率下有不同的最大值。
尺寸信息提供了不同类型的HC-49SMD的尺寸数据。
部件号指南提供了如何根据频率、负载电容、频率稳定性、引脚材料和工作温度范围来识别不同型号的晶体谐振器。
回流焊特性包括最高260℃的温度和不同阶段的时间设置。
如需进一步详细信息或特定部分的翻译,请告知。
X49SM16MSD2SC 价格&库存
很抱歉,暂时无法提供与“X49SM16MSD2SC”相匹配的价格&库存,您可以联系我们找货
X49SM16MSD2SC
  • 5+0.59506
  • 50+0.47510
  • 200+0.41513
  • 400+0.40890
  • 1000+0.33604
库存:1047
X49SM16MSD2SC
  • 5+0.64580
  • 50+0.51360
  • 150+0.44850
  • 1000+0.36310
  • 2000+0.32410
  • 5000+0.30470
库存:2952
X49SM16MSD2SC
X49SM16MSD2SC
    • 20+0.90200
    • 50+0.57200
    • 100+0.46200
    • 150+0.42900
    库存:480
    X49SM16MSD2SC
    • 1+0.32120
    库存:169
    X49SM16MSD2SC
    • 5+0.65567
    • 50+0.52348
    • 150+0.45738
    • 1000+0.37034
    • 2000+0.33059
    • 5000+0.31083
    库存:24864
    X49SM16MSD2SC
    • 1+0.57989
    • 50+0.34093
    • 1000+0.30694
    库存:4119
