WSF6012
N&P-Channel MOSFET
Product Summery
General Description
The WSF6012 is the highest performance
trench N-ch and P-ch MOSFET with extreme
high cell density , which provide excellent
RDSON and gate charge for most of the
synchronous buck converter applications .
The WSF6012 meet the RoHS and Green
Product requirement , 100% EAS
guaranteed with full function reliability
approved.
BVDSS
RDSON
ID
60V
28mΩ
20A
-60V
46mΩ
-15A
Applications
z High Frequency Point-of-Load Synchronous
Buck Converter.
z Networking DC-DC Power System
z Load Switch
Features
TO-252-4L Pin Configuration
z Advanced high cell density Trench technology
D1/D2
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
G1
S1
Absolute Maximum Ratings
S2
G2
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
1
1
ID@TC=25℃
ID@TC=70℃
IDM
P-Channel
Units
60
-60
V
±20
±20
V
A
15
-10
A
46
-36
A
N-Channel
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
EAS
Single Pulse Avalanche Energy
200
180
mJ
IAS
Avalanche Current
59
-50
A
Total Power Dissipation
34.7
34.7
W
TSTG
Storage Temperature Range
-55 to 150
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
-55 to 150
Max.
Unit
85
℃/W
50
℃/W
PD@TC=25℃
3
4
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.winsok.tw
1
Thermal Resistance Junction-Case
Page 1
Dec.2014
WSF6012
N&P-Channel MOSFET
N-Channel Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
60
V
Reference to 25℃ , ID=1mA
0.063
V/℃
VGS=10V , ID=8A
28
37
VGS=4.5V , ID=5A
37
45
1
-5.24
VDS=48V , VGS=0V , TJ=25℃
1
VDS=48V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
VGS(th) Temperature Coefficient
2.5
mΩ
V
mV/℃
uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=8A
21
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
3.0
4.5
Ω
Qg
Total Gate Charge (4.5V)
12.6
Qgs
Gate-Source Charge
3.5
Qgd
Gate-Drain Charge
6.3
VDS=48V , VGS=4.5V , ID=8A
nC
8
Rise Time
VDD=30V , VGS=4.5V ,
14.2
Turn-Off Delay Time
RG=3.3Ω, ID=1A
24.6
Fall Time
4.6
Ciss
Input Capacitance
670
Coss
Output Capacitance
70
Crss
Reverse Transfer Capacitance
35
Min.
Typ.
Max.
Unit
100
mJ
Min.
Typ.
Max.
Unit
A
60
A
1.4
V
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=16A
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Conditions
1,6
Continuous Source Current
2,6
Pulsed Source Current
2
Diode Forward Voltage
VG=VD=0V , Force Current
VGS=0V , IS=1.7A,TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSF6012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.61584
- 10+2.90628
- 30+2.59524
- 100+2.21616
- 500+1.74960
- 1000+1.64268
- 国内价格
- 1+2.89270
- 10+2.69980
- 30+2.50690
- 100+2.31410
- 500+2.12130
- 1000+1.92850
- 国内价格
- 1+2.47677
- 10+2.33177
- 30+2.04177
- 100+1.82427
- 500+1.67927
- 1000+1.57777
