KF2EDGKB-7.62-12
KF2EDGKB-7.62-12
    KEFA(科发)
    P=7.62mm
    插拔式接线端子 P=7.62mm 12Pin(1x12) 绿色
KF2EDGKB-7.62-12 数据手册
0B 5.08mm Pitch - Plug-in PCB Terminal Block Set 5.08mm Pitch: Direction: Screw cage Clamp: Direction: Vertical Mounting: KF2EDGK 5.08 0.00g Electrical Pluggable KF2EDGV 5.08 0.00g N.W.: Electrical Current IEC 15A UL 10A Voltage Wire Range Withstanding 300V 28-12AWG AC1500V Installation Current IEC 15A UL 10A Voltage Withstanding 300V AC1500V Installation Screw size Torque Strip Lgth Max Solder Hole Size Max Solder M2.5 0.50mm 8.00mm +250deg 1.40mm +250deg 4.4lb.in 0.31in Material 0.06in Material Screw: Galvanized Steel Screw: Contact: Nickled brass Pin: Clamp: Nickled brass,Galvanized Steel Clamp: Housing: PA66.UL94-0 Housing: Temp limit: -40deg-+105deg Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 2P Poles: Mounting: Pluggable N.W.: 5.08mm Clamp: 2P Poles: Pitch: N.W. Color: Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g PA66.UL94-0 Temp limit: -40deg-+105deg Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Tin-plate brass No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS A $29.50 /2P*1000 B MOQ: 2P*1000,000 Price: KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com 5.08mm Pitch - Plug-in PCB Terminal Block Female 5.08mm Pitch: Pitch: Direction: 5.08mm Direction: Screw cage Clamp: Clamp: 2P Poles: 2P Poles: Mounting: Pluggable Mounting: KF2EDGKA 5.08 3.49g N.W.: Screw cage Electrical N.W.: Pluggable KF2EDGKB 5.08 3.49g Electrical IEC UL Installation Current 15A 10A Screw size M2.5 Voltage Wire Range Withstanding 300V 28-12AWG AC1500V Torque 0.50mm 4.4lb.in Strip Lgth 8.00mm 0.31in IEC UL Installation Max Solder +250deg Material Current 15A 10A Voltage 300V Flang M2.5 Hole Size 1.40mm 0.06in Wire Range Withstanding 28-12AWG AC1500V Max Solder +250deg Material Galvanized Steel Screw: Contact: Nickled brass Nickled brass Clamp: Housing: PA66.UL94-0 Temp limit: -40deg-+105deg Green Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. 3.49g 5.23g 6.97g 8.72g 10.46g 12.20g 13.95g 15.69g 17.43g 19.18g Price: A Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs MOQ: 2P*1000,000 Total 3486.60g 3137.94g 3486.60g 4358.25g 4183.92g 4881.24g 4183.92g 4706.91g 5229.90g 3835.26g /2P*1000 ROHS Screw: Contact: Clamp: Housing: Temp limit: Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. 3.49g 5.23g 6.97g 8.72g 10.46g 12.20g 13.95g 15.69g 17.43g 19.18g Price: A Galvanized Steel Nickled brass Nickled brass PA66.UL94-0 -40deg-+105deg Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Total 3486.60g 3137.94g 3486.60g 4358.25g 4183.92g 4881.24g 4183.92g 4706.91g 5229.90g 3835.26g /2P*1000 ROHS MOQ: 2P*1000,000 KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com 5.08mm Pitch - Plug-in PCB Terminal Block Set 5.08mm Pitch: Direction: Screw cage Clamp: Direction: Vertical 2P Poles: Mounting: Pluggable Mounting: KF2EDGKM 5.08 0.00g N.W.: 5.08mm Clamp: 2P Poles: Pitch: Electrical Pluggable KF2EDGVM 5.08 0.00g N.W.: Electrical Current IEC 15A UL 10A Voltage Wire Range Withstanding 300V 28-12AWG AC1500V Installation Current IEC 15A UL 10A Voltage Withstanding 300V AC1500V Installation Screw size Torque Strip Lgth Max Solder Flang Hole Size Max Solder M2.5 0.50mm 8.00mm +250deg M2.5 1.40mm +250deg 4.4lb.in 0.31in Material 0.06in Material Screw: Galvanized Steel Flang: Nickled brass Contact: Nickled brass Pin: Tin-plate brass Clamp: Nickled brass,Galvanized Steel Clamp: Housing: PA66.UL94-0 Housing: Temp limit: -40deg-+105deg Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Temp limit: -40deg-+105deg Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Color: Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g PA66.UL94-0 No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g $94.87 /2P*1000 ROHS MOQ: 2P*1000,000 KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com 5.08mm Pitch - Pluggable Terminal Block Male Dual-Pin Pitch: 5.08mm Pitch: 5.08mm Direction: Parallel Direction: Parallel Clamp: Clamp: 2P Poles: Mounting: Pluggable Mounting: KF2EDGRT 5.08 0.00g N.W.: 2P Poles: Electrical N.W.: Pluggable KF2EDGRTC 5.08 0.00g Electrical IEC UL Installation Current 15A 10A Voltage Withstanding 300V AC1500V IEC UL Installation Current 15A 10A Hole Size Max Solder 1.60mm +250deg 0.06in Material Voltage Withstanding 300V AC1500V Hole Size 1.60mm 0.06in Max Solder +250deg Material Screw: Tin-plate brass Pin : Clamp: Housing: PA66.UL94-0 Temp limit: -40deg-+105deg Green Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs MOQ: 2P*1000,000 Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS Screw: Pin : Clamp: Housing: Temp limit: Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Tin-plate brass PA66.UL94-0 -40deg-+105deg Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS MOQ: 2P*1000,000 KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com 5.08mm Pitch - Pluggable Terminal Block Male Dual-Pin Pitch: 5.08mm Pitch: 5.08mm Direction: Vertical Direction: Vertical Clamp: Clamp: 2P Poles: Mounting: Pluggable Mounting: KF2EDGVT 5.08 0.00g N.W.: 2P Poles: Electrical N.W.: Pluggable KF2EDGVTC 5.08 0.00g Electrical IEC UL Installation Current 15A 10A Voltage Withstanding 300V AC1500V IEC UL Installation Current 15A 10A Hole Size Max Solder 1.60mm +250deg 0.06in Material Voltage Withstanding 300V AC1500V Hole Size 1.60mm 0.06in Max Solder +250deg Material Screw: Tin-plate brass Pin : Clamp: Housing: PA66.UL94-0 Temp limit: -40deg-+105deg Green Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs MOQ: 2P*1000,000 Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS Screw: Pin : Clamp: Housing: Temp limit: Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Tin-plate brass PA66.UL94-0 -40deg-+105deg Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS MOQ: 2P*1000,000 KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com 5.08mm Pitch - Pluggable Terminal Block Male Dual-Pin Pitch: 5.08mm Pitch: 5.08mm Direction: Parallel Direction: Vertical Clamp: Clamp: 2P Poles: Mounting: Pluggable Mounting: KF2EDGRH 5.08 0.00g N.W.: 2P Poles: Electrical N.W.: Pluggable KF2EDGVH 5.08 0.00g Electrical IEC UL Installation Current 15A 10A Voltage Withstanding 300V AC1500V IEC UL Installation Current 15A 10A Hole Size Max Solder 1.60mm +250deg 0.06in Material Voltage Withstanding 300V AC1500V Hole Size 1.60mm 0.06in Max Solder +250deg Material Screw: Tin-plate brass Pin : Clamp: Housing: PA66.UL94-0 Temp limit: -40deg-+105deg Green Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs MOQ: 2P*1000,000 Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS Screw: Pin : Clamp: Housing: Temp limit: Color: No. Poles 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P N.W. Price: A Tin-plate brass PA66.UL94-0 -40deg-+105deg Green Box 1000pcs 600pcs 500pcs 500pcs 400pcs 400pcs 300pcs 300pcs 300pcs 200pcs Total .00g .00g .00g .00g .00g .00g .00g .00g .00g .00g /2P*1000 ROHS MOQ: 2P*1000,000 KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com
KF2EDGKB-7.62-12 价格&库存
很抱歉,暂时无法提供与“KF2EDGKB-7.62-12”相匹配的价格&库存,您可以联系我们找货
KF2EDGKB-7.62-12
  • 1+3.74219
库存:3
