WST3052
N-Ch MOSFET
Product Summery
General Description
The WST3052 is the highest performance
trench N-Ch MOSFET with extreme high cell
density , which provide excellent RDSON
and gate charge for most of the small power
switching and load switch applications.
BVDSS
RDSON
ID
30V
60mΩ
2.5A
Applications
The WST3052 meet the RoHS and Green
Product requirement with full function
reliability approved.
z Power Management in Notebook Computer
Portable Equipment and Battery Powered
Systems.
Features
z Advanced high cell density Trench technology
SOT-323 Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±12
V
1
2.5
A
1
2.0
A
ID@Tc=25℃
ID@Tc=70℃
IDM
PD@TA=25℃
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
13
A
3
0.7
W
3
2
Total Power Dissipation
PD@TA=70℃
0.45
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
RθJA
RθJA
RθJC
www.winsok.tw
Parameter
Typ.
Thermal Resistance Junction-ambient
1
1
Thermal Resistance Junction-Ambient (t ≤10s)
1
Thermal Resistance Junction-Case
Page 1
Max.
180
Unit
℃/W
120
℃/W
100
℃/W
Oct.2018
WST3052
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
△VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
VGS(th) Temperature Coefficient
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.025
V/℃
50
60
60
70
0.5
0.7
1.0
V
-4.8
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
30
VGS=4.5V , ID=2.5A
VGS=2.5V , ID=2A
VGS=VDS , ID =250uA
mΩ
uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=2A
7
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.5
5
Ω
Qg
Total Gate Charge (4.5V)
4.0
8.4
Qgs
Gate-Source Charge
0.3
3.5
Qgd
Gate-Drain Charge
1.5
2.9
VDS=10V , VGS=4.5V , ID=1A
nC
3.5
5.2
Rise Time
VDD=10V , VGS=10V , RG=6Ω,
13.3
21
Turn-Off Delay Time
ID=1A, RL=10Ω.
13.2
Fall Time
2
5
Ciss
Input Capacitance
286
Coss
Output Capacitance
60
Crss
Reverse Transfer Capacitance
50
Min.
Typ.
Max.
Unit
2.5
A
13
A
1.0
V
15
nS
3.7
nC
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=10V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=5A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST3052”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.36500
- 20+0.36000
- 100+0.35000
- 国内价格
- 1+0.59950
- 200+0.38610
- 1500+0.33660
- 3000+0.29700
- 国内价格
- 5+0.59400
- 50+0.54530
- 150+0.47402
- 500+0.42056
- 3000+0.37779
- 6000+0.35640
