PL-2303HX
PL-2303HX
    PROLIFIC(旺玖)
    SSOP28_10.2X5.3MM
    PL-2303 USB到RS-232桥接控制器 SSOP28 -0.3~6V 19mA
PL-2303HX 数据手册
PL-2303 USB to RS-232 Bridge Controller Product Datasheet Document Revision 1.4 Document Release: August, 2002 Prolific Technology Inc. Release Date: July, 2002 ds_pl2303_v14 Revision History Revision Description Date 1.4 • Add Windows CE .NET support feature August 29, 2002 1.3 • Buffer for upstream and downstream data flow – change from 96 to 256 bytes August 01, 2002 1.2 • For Chip Version H (date code 0206) July 03, 2002 • Add OS Support in Features Section • Correct default values in Table 5. Device Configuration Register • Add Suspend Current in DC Characteristics Section • Move Operating Temperature in DC Characteristics to new section PL-2303 Product Datasheet -2- Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 PL-2303 USB to Serial RS232 Bridge Controller Features  Full compliance with the USB Specification v1.1 and USB CDC v1.1  Support the RS232 Serial interface  Support automatic handshake mode  Support Remote wake-up and power management  256 bytes buffer each for upstream and downstream data flow  Support default ROM or external EEPROM for device configuration  On chip USB transceiver  On chip crystal oscillator running at 12M Hz  Supports Windows 98/SE, ME, 2000, XP, Windows CE3.0, CE .NET, Linux, and Mac OS  28 Pins SOIC package SSOP 28 PACKAGE (TOP VIEW) PL-2303 Product Datasheet TXD 1 28 OSC2 DTR_N 2 27 OSC1 RTS_N 3 26 VDD_232 4 25 GND_PLL RXD 5 24 VDD_PLL RI_N 6 23 LD_MODE GND 7 22 TRI_MODE VDD 8 21 GND DSR_N 9 20 VDD DCD_N 10 19 RESET PLL_TEST CTS_N 11 18 GND_3V3 SHTD_N 12 17 VDD_3V3 EE_CLK 13 16 DM EE_DATA 14 15 DP -3- Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Block Diagram USB Port USB Transceiver REGISTER/ Control USB CONFIG/ Unit SIE STATUS/ CONTROL DOWN UP STREAM STREAM BUFFER BUFFER CLOCK SYNTHESIZE RS-232 SERIAL INTERFACE EEPROM OSCILLATOR INTERFACE Serial Port PL-2303 Product Datasheet -4- I2C Bus Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Overview The PL-2303 operates as a bridge between one USB port and one standard RS232 Serial port. The two large on-chip buffers accommodate data flow from two different buses. The USB bulk-type data is adopted for maximum data transfer. Automatic handshake is supported at the Serial port. With these, a much higher baud rate can be achieved compared to the legacy UART controller. This device is also compliant with USB power management and remote wakeup scheme. Only minimum power is consumed from the host during Suspend. By integrating all the function in a SOIC-28 package, this chip is suitable for cable embedding. Users just simply hook the cable into PC or hub’s USB port, and then they can connect to any RS-232 devices. Pin Description Table 1. Pins Description Pin No. 1 2 3 4 Name TXD DTR_N RTS_N VDD_232 Type O O O P Description Data output to Serial port Data Terminal Ready, active low Request To Send, active low RS-232 VDD. The RS-232 output signals (Pin 1 ~ Pin 3) are designed for 5V, 3.3V or 3V operation. VDD_232 should be connected to the same power level of the RS-232 interface. (The RS-232 input signals are always 5V~3V tolerant.) Note: This document version only provides 5V DC characteristic information. Refer to future revisions for updates. 5 6 7 8 9 10 11 12 13 RXD RI_N GND VDD DSR_N DCD_N CTS_N SHTD_N EE_CLK I I P P I I I O I/O 14 15 16 17 18 19 20 21 EE_DATA DP DM VDD_3V3 GND_3V3 RESET VDD GND I/O I/O I/O P P I P P PL-2303 Product Datasheet Data input from Serial Bus Ring Indicator, active low Ground Power Data Set Ready, active low Data Carrier Detect, active low Clear To Send, active low Shut Down RS232 Transceiver During Reset, this pin is input for simulation purpose. During normal operation, this pin is Serial ROM clock Serial ROM data signal USB DPLUS signal USB DMINUS signal 3.3V power for USB transceiver 3.3V ground System Reset Power Ground -5- Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Pin No. 22 TRI_STATE 23 LD_MD/ SHTD 24 25 26 27 28 Type: Name Type I I/O VDD_PLL GND_PLL PLL_TEST OSC1 OSC2 I – Input signal P P I I O Description Tri-State This pin is referred after reset. High: RS-232 output inactive during Suspend. Low: RS-232 output tri-state during Suspend. Load Mode/SHTD This pin is input during reset. Pull high with a 220K resistor to indicate the heavy load USB device (500mA). Pull down with a 220K resistor to indicate the light load USB device 100mA). After reset, this pin becomes output. It output the inverse of SHTD_N. 5V power for PLL Ground for PLL PLL test mode control Crystal oscillator input Crystal oscillator output O – Output signal I/O – Bi-directional signal P – Power/Ground Supported Data Formats and Programmable Baud Rate Generator The PL2303 USB-to-RS232 bridge controller supports versatile data formats and has a programmable baud rate generator. The supported data formats are shown on Table 2. The programmable baud rate generator supports baud rates up to 1.2M bps as shown in Table 3. Table 2. Supported Data Formats Description Stop bits Parity type Data bits PL-2303 Product Datasheet 1 1.5 2 None Odd Even Mark Space 5, 6, 7, 8, or 16 -6- Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Table 3. Baud Rate Setting dwDTERate 0012C000h 000E1000h 00096000h 00070800h 00038400h 0001C200h 0000E100h 00009600h 00007080h 00004B00h 00003840h 00002580h 00001C20h 000012C0h 00000E10h 00000960h 00000708h 000004B0h 00000258h 0000012Ch 00000096h 0000004Bh Baud Rate 1228800 921600 614400 460800 230400 115200 57600 38400 28800 19200 14400 9600 7200 4800 3600 2400 1800 1200 600 300 150 75 External EEPROM and Device Configuration PL-2303 allows storing the configuration data in an external EEPROM. After reset, the first two bytes of EEPROM are checked. If the value is 067Bh, the EEPROM is valid and the contents of the EEPROM are loaded as the chip’s default parameters. Otherwise, the chip’s default setting is used. The content of EEPROM is shown in Table 4 below. The Device Configuration Register is used to control some vendor-specific functions. The meaning of each bit in Device Configuration Register is shown in Table 5. Reserved and unused pins always set to the default value. Table 4. EEPROM Content Bytes 1:0 Name EECHK 3:2 5:4 7:6 10:8 VID PID RN DCR PL-2303 Product Datasheet Description When the EEPROM is programmed, these two bytes is configured as 067B. After reset, they will be checked for the value. If matched, the following information will be loaded as the default parameters. USB Vendor ID Product ID Release number (BCD) Device Configuration Register -7- Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Table 5. Device Configuration Register Name Bits 23 22 RESERVED TRI_OUT 21 RW_MODE 20 WURX 19 WUDSR 18 WURI 17 WUDCD 16 WUCTS 15 14 13 12 RESERVED RESERVED RESERVED RW_INH 11:6 5:4 RESERVED RTSM 3:1 0 RESERVED RSPDM Definition Default Reserved RS-232 Output Tri-state: 1: RS-232 output tri-state 0: RS-232 output in output mode Remote Wakeup Mode: 0: When engages remote wakeup, the device issues disconnect signal 1: When engages remote wakeup, the device issues resume signal Enable Wake Up Trigger on RXD: 0 – Disabled; 1 – Enable Wake Up Trigger on RXD state changes. Enable Wake Up Trigger on DSR: 0 – Disabled; 1 – Enable Wake Up Trigger on DSR state changes. Enable Wake Up Trigger on RI: 0 – Disabled; 1 – Enable Wake Up Trigger on RI state changes. Enable Wake Up Trigger on DCD: 0 – Disabled; 1 – Enable Wake Up Trigger on DCD state changes. Enable Wake Up Trigger on CTS: 0 – Disabled; 1 – Enable Wake Up Trigger on CTS state changes. Always set to one Always set to zero Always set to zero Remote Wake Inhibit: 1 – Inhibit the USB Remote Wakeup function 0 – Enable the USB Remote Wakeup function Always set to zero RTS Control Method: 00b – RTS is controlled by ControlBitMap. Signal is active low; 01 – RTS is controlled by ControlBitMap. Signal is active high; 10 – Drive RTS active when Downstream Data Buffer is NOT EMPTY; otherwise Drive RTS inactive. 11 – Drive RTS inactive when Downstream Data Buffer is NOT EMPTY; otherwise Drive RTS active. Always set to zero RS-232 Transceiver Shut-Down Mode: 1: Shut down the transceiver when USB SUSPEND is engaged 0: Do not shut down the transceiver even when USB SUSPEND is engaged PL-2303 Product Datasheet -8- 0 0 1 0 0 1 0 0 1 0 0 0 0 0 0 1 Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Electrical Characteristics Absolute Maximum Ratings Item Power Supply Voltage Input Voltage Output Voltage Storage Temperature Ratings -0.3 to 6.0 V -0.3 to VDD+0.3 V -0.3 to VDD+0.3 V o -55 to 150 C DC Characteristics Parameter Symbol Min Typ Max Units Power Supply Current Input Voltage Low High Output Voltage Low High 1 Schmitt Trigger Threshold Voltage* Negative going Positive going 2 Output Voltage, 3.3V* Low High Input Leakage Current Tri-state Leakage Current Input Capacitance Output Capacitance Bi-directional Buffer Capacitance Operating Voltage Range Suspend Current IDD 0.5 19 24 mA VIL VIH -0.7* VDD --- 0.3* VDD -- V V VOL VOH -3.5 --- 0.4 -- V V VtVt+ --- 1.10 1.87 --- V V VOL VOH IL Ioz CIN COUT CBID -ISUS -2.4 -1 -10 ---4.75 -- ----3 3 3 5 400 0.4 -1 10 ---5.25 490 V V uA uA Pf Pf Pf V uA Units *1. RS232 pins RXD_I, RI_I, DSR_I, DCD_I, CTS_I are 5V TTL Schmitt Trigger inputs. *2. RS232 pins TXD, DTR_N, RTS_N are 3.3V tri-state outputs. Temperature Characteristics Parameter Operating Temperature Junction Operation Temperature PL-2303 Product Datasheet Symbol Min Typ Max -TJ -40 0 -25 85 115 -9- o C C o Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 USB Transceiver Characteristics Parameter Symbol Min Typ Max Units TR TF 4 4 8 8 15 15 ns ns Cross Point VCR 1.3 -- 2.0 V Output Impedance RD 23 28 33 ohm High Level Output VOH 2.8 -- -- V Low Level Output VOL -- -- 0.7 V High Level Input VIH 2.0 -- -- V Low Level Input VIL -- -- 0.8 V Min Typ Max Units 11.976 12.000 12.024 MHz 83.1 83.3 83.5 ns 45 50 55 % Rise and Fall Times: (10%―90%) (90%―10%) • CL: 50pf Clock Characteristics Parameter Frequency of Operation Clock Period Duty Cycle Package Dimensions (28-Pin SSOP) Symbol Min b E E1 L R1 D A e L1 A1 A2 Millimeters Nom Max Min 7.80 5.30 0.75 0.38 8.20 5.60 0.95 0.009 0.291 0.197 0.021 0.004 0.390 0.22 7.40 5.00 0.55 0.09 9.9 10.2 10.5 2.0 0.65 1.25 0.05 1.65 PL-2303 Product Datasheet 1.75 Inch Nom Max 0.307 0.209 0.030 0.015 0.323 0.220 0.037 0.402 0.413 0.079 0.0256 0.050 1.85 - 10 - 0.020 0.065 0.069 0.073 Document Revision 1.3 Release Date: July, 2002 ds_pl2303_v14 Outline Diagram D 28 DETAIL A E E1 1 DETAIL A A2 A R1 e b A1 0.25 L R1 PL-2303 Product Datasheet - 11 - L1 Document Revision 1.3
PL-2303HX
1. 物料型号:PL-2303HX 2. 器件简介:PL-2303HX是一款USB转串口桥接芯片,支持USB 2.0标准,向下兼容USB 1.1。它能够实现USB接口与RS-232串行接口之间的数据转换。 3. 引脚分配:该芯片具有28个引脚,包括电源引脚、地引脚、USB数据线引脚、RS-232数据引脚、控制引脚等。 4. 参数特性:支持最高波特率可达1Mbps,工作电压范围为3.3V至5V,工作温度范围为-40°C至85°C。 5. 功能详解:PL-2303HX支持全速USB数据传输,内置了必要的USB协议栈,能够实现即插即用和远程唤醒功能。 6. 应用信息:广泛应用于工业控制、医疗设备、POS机、税控设备等领域,需要USB接口与串行设备进行数据通信的场景。 7. 封装信息:通常采用QFN或SOIC封装形式,具体封装形式取决于制造商。
PL-2303HX 价格&库存
很抱歉,暂时无法提供与“PL-2303HX”相匹配的价格&库存,您可以联系我们找货
