X252012MMB4SI-24
X252012MMB4SI-24
    YXC(扬兴科技)
    SMD2520_4P
    无源晶振 12MHz ±10ppm 10pF -40℃~+85℃
X252012MMB4SI-24 数据手册
【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX221SL Features . External dimensions: 2.55 x 2.05 x 0.55 mm. C Y X A . Frequency range: 12MHz ~ 54MHz. C AQ . High precision and high frequency stability. .Excellent heat resistance and environmental characteristics. .Applications: mobile phone, Bluetooth, Bluetooth, W-LAN ISM band radio, clock for MPU GPS, smart phone. Electrical Specifications Item / Type YSX221SL Nominal Frequency Range 12 ~ 54 MHz Vibration Mode AT Fundamental Load Capacitance 12 pF, 20 pF, or specify Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 3 pF Max. Level Of Drive 1 ~200 μW Max. (100uW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) Fundamental 12 ~ 14 MHz 150 Ω Max. 14 ~ 30 MHz 100 Ω Max. 30 ~ 48 MHz 60 Ω Max. 48 ~ 54 MHz 50 Ω Max. Dimensions YXC AAQC Units: mm come visit our site http://www.yxc.hk 1/2 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX221SL ★ PART NUMBER GUIDE 部件号示例 e.g. X252012MSB4 SC Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 2520 Frequency Stability Pin Overall (ppm) S ★ TAPING SPECIFICATION (Unit: mm) 4.0 YSX221SL =2.55×2.05 SMD SEAM TYPE 4 B Material Operating Temp. Range S C 编带规格 φ1.5 1.75 12 0° φ13 2.0 C B D SMD2520 G A F E A B C 178±2.0 8.0 ±0.3 D 2.70±0.05 2.25±0.05 E F G 4.0±0.1 1.05±0.05 60.5±1.0 3000 pcs per reel ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ come visit our site http://www.yxc.hk 2/2 120sec. max
X252012MMB4SI-24 价格&库存
很抱歉,暂时无法提供与“X252012MMB4SI-24”相匹配的价格&库存,您可以联系我们找货
X252012MMB4SI-24
  • 1+0.59489
  • 200+0.41006
  • 1500+0.37370
  • 3000+0.34845
库存:6027
X252012MMB4SI-24
  • 10+1.51830
  • 100+0.90570
  • 800+0.63400
  • 3000+0.45290
  • 6000+0.43020
  • 30000+0.39850
X252012MMB4SI-24
  • 5+0.96610
  • 50+0.79190
  • 150+0.70480
  • 500+0.64030
  • 3000+0.49650
  • 6000+0.47080
库存:7070
X252012MMB4SI-24
  • 1+0.61990
库存:863
X252012MMB4SI-24
  • 5+0.98108
  • 50+0.80622
  • 150+0.71874
  • 500+0.65319
  • 3000+0.50663
  • 6000+0.48039
库存:18033
X252012MMB4SI-24
  • 3+0.89023
库存:3
