YPRH1205-103M
YPRH1205-103M
    YJYCOIN(益嘉源)
    SMD,12x12mm
    功率电感 10mH ±20% 18Ω IND_12X12MM_SM
YPRH1205-103M 数据手册
SMD Power Inductors -YPRH1205 Series ■ Features ● High current type. ● Ferrite bobbin core and compact size. ● Low core loss for high frequency power application. ● Large terminal surface for good PCB bonding. ● Operating temperature:-40℃ ~ +125℃. ■ Applications ● Portable communication equipment. ● Notebook PC,digital camera,LCD television set. ● Power supply for VTR,OA equipment. ● DC/DC converters. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance value ⑷ :Inductance Tolerance;N=±30%,M=±20%,K=±10% 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -1- SMD Power Inductors -YPRH1205 Series ■ Shapes and Dimensions (Unit:mm) TYPE A B C max D E F Ref. G Ref. H Ref. YPRH1205 12.0±0.5 12.0±0.5 6.0 7.60±0.2 5.0 2.8 7.0 5.4 ■ YPRH1205 Series Part Number Inductance (uH) L Test Frequency Max.DC Resistance MAX.Rated Current (KHz) (Ω) (A) YPRH1205-1R0□ 1.00 100 0.012 8.00 YPRH1205-1R3□ 1.30 100 0.012 8.00 YPRH1205-1R5□ 1.50 100 0.013 7.70 YPRH1205-1R8□ 1.80 100 0.014 7.40 YPRH1205-2R1□ 2.10 100 0.014 7.00 YPRH1205-2R2□ 2.20 100 0.015 7.00 YPRH1205-2R5□ 2.50 100 0.017 6.40 YPRH1205-3R0□ 3.00 100 0.018 5.80 YPRH1205-3R3□ 3.30 100 0.019 5.40 YPRH1205-4R4□ 4.40 100 0.020 5.00 YPRH1205-4R7□ 4.70 100 0.020 4.80 YPRH1205-5R6□ 5.60 100 0.021 4.40 YPRH1205-6R8□ 6.80 100 0.022 4.30 YPRH1205-7R5□ 7.50 100 0.024 4.20 YPRH1205-7R7□ 7.70 100 0.024 4.20 YPRH1205-8R2□ 8.20 100 0.025 4.10 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -2- SMD Power Inductors -YPRH1205 Series Part Number Inductance (uH) L Test Frequency Max.DC Resistance MAX.Rated Current (KHz) (Ω) (A) YPRH1205-100□ 10.0 100 0.025 4.00 YPRH1205-120□ 12.0 100 0.027 3.50 YPRH1205-150□ 15.0 100 0.030 3.30 YPRH1205-180□ 18.0 100 0.034 3.00 YPRH1205-220□ 22.0 100 0.036 2.80 YPRH1205-270□ 27.0 100 0.051 2.30 YPRH1205-330□ 33.0 100 0.060 2.10 YPRH1205-390□ 39.0 100 0.068 2.00 YPRH1205-470□ 47.0 100 0.075 1.80 YPRH1205-560□ 56.0 100 0.110 1.70 YPRH1205-680□ 68.0 100 0.120 1.50 YPRH1205-820□ 82.0 100 0.140 1.40 YPRH1205-101□ 100 100 0.160 1.30 YPRH1205-121□ 120 100 0.170 1.10 YPRH1205-151□ 150 100 0.230 1.00 YPRH1205-181□ 180 100 0.290 0.90 YPRH1205-221□ 220 100 0.400 0.80 YPRH1205-271□ 270 100 0.460 0.75 YPRH1205-331□ 330 100 0.510 0.68 YPRH1205-391□ 390 100 0.690 0.65 YPRH1205-471□ 470 100 0.770 0.58 YPRH1205-561□ 560 100 0.860 0.54 YPRH1205-681□ 680 100 1.200 0.48 YPRH1205-821□ 820 100 1.340 0.43 YPRH1205-102□ 1000 100 1.530 0.40 YPRH1205-103□ 10000 100 18.000 0.06 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -3- SMD Power Inductors -YPRH1205 Series ※ The saturation current value is the DC current value having inductance decrease down to 30%.(at 20℃) ※ The temperature rise current value is the DC current value having temperature increase up to 40℃. (at 20℃) ※ The rated current is the DC current value that satisfies both of current value saturation current value and temperature rise current value. ■ Taping Dimensions(Unit:mm) TYPE MPQ W A B C D E P K T YPRH1205 500 24±0.3 12.6±0.1 12.6±0.1 10.75 11.5±0.1 6.1±0.1 16±0.1 6.3 Ref 0.4±0.05 ■ Reel Dimensions(Unit:mm) TYPE W W1 W2 W3 A B C D YPRH1205 330±2.00 24.4±1.50 30.40 Max 23.90 Min 13.0±0.50 21.0±0.80 2.0±0.50 100 Min 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -4- SMD Power Inductors -YPRH1205 Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -5-
YPRH1205-103M
物料型号:YPRH1205系列
器件简介:这是一系列SMD功率电感器,具有高电流型、铁氧体骨架核心和紧凑尺寸。它们适用于高频电源应用,具有低核心损耗和大端子表面,便于PCB粘接。工作温度范围为-40℃至+125℃。
引脚分配:文档中未明确提供引脚分配信息,但通常SMD电感器的端子位于组件的两侧。
参数特性: - 尺寸:12.0±0.5mm x 12.0±0.5mm x 6.0mm - 额定电流:根据电感值不同,从0.4A至8.00A不等 - 最大直流电阻:从0.012Ω至18.000Ω不等 - 电感值:从1.00μH至10000μH不等 - 电感公差:N=±30%, M=±20%, K=±10%
功能详解: - 饱和电流值:在20℃下,电感值下降到30%的直流电流值。 - 温升电流值:在20℃下,温度上升达到40℃的直流电流值。 - 额定电流:同时满足饱和电流值和温升电流值的直流电流值。
应用信息:适用于便携式通信设备、笔记本电脑、数码相机、液晶电视、VTR、OA设备电源、DC/DC转换器等。
封装信息: - 胶带尺寸:宽度24±0.3mm,厚度12.6±0.1mm - 卷轴尺寸:宽度330±2.00mm,内孔直径13.0±0.50mm,外孔直径21.0±0.80mm
YPRH1205-103M 价格&库存
很抱歉,暂时无法提供与“YPRH1205-103M”相匹配的价格&库存,您可以联系我们找货
