BT0503H3I507EN10A
BT0503H3I507EN10A
    XTALTQ(恒晶科技)
    SMD5032_4P
    温度补偿晶体振荡器(TCXO) 3.3V 10MHz SMD5032_4P ±0.5ppm SMT 4Pin
BT0503H3I507EN10A 数据手册
BT0503 Temperature Compensated Crystal Oscillator Features Applications ● Ultra Stable ● Wide Temperature Range ● SMD Package (5.0×3.2mm) ● ● ● ● ● Base Stations Instrumentations Synthesizer SDH/SONET Medical Electronics BT0503 Specifications Parameter Supply Voltage Supply Current Min. Value Typ. Max. – 3.3 – V – 5 – V 3 – 6 mA Frequency Range Nominal Frequency Initial Frequency Tolerance Freq. Stability Vs. Temp. Clipped Sine Wave Output Level 10 ~ 52 Unit Conditions MHz 10, 12.8, 16.384, 19.2, 20, 24.576, 25, 26, 30.72, 40, 50 MHz ±0.05 – ±0.5 ppm At shipment, nominal EFC, +25℃ ±0.05 – ±0.5 ppm -20℃~+70℃ ±0.1 – ±0.5 ppm -40℃~+85℃ ±0.2 – ±1.0 ppm -50℃~+90℃ ±0.5 – ±1.0 ppm -55℃~+95℃ 0.8 – – Vp-p 10kΩ//10pF Load VOH 2.4 – – V LVCMOS Output, Load=15pf VOL – – 0.4 V LVCMOS Output, Load=15pf Duty Cycle 45 – 55 % ( VOH - VOL)/2 Rise/Fall Edge – – 6 ns LVCMOS Output, Load=15pf Load – – 15 pf RMS Jitter(By E5052B) – – 1.3 ps Supply Sensitivity – – ±0.1 Load Sensitivity – – ±0.2 – – ±1.0 ±0.3 – ±0.8 Customized – – -95 Offset 10Hz – – -120 Offset 100Hz – – -140 – – -145 Offset 10kHz – – -150 Offset 100kHz LVCMOS Aging/ First Year SSB Phase Noise @10MHz Control Voltage Range Frequency Turning Range 1.5 ± 1.0 ±5 Tuning Slope Non-linearity 12KHz~5MHz Vcc±5% ppm dBc/Hz Load±5% Standard Offset 1kHz At +25℃ V – ±12 ppm 10 % Positive – – 1/4 Release Date: Aug.30. 2016 BT0503 Temperature Compensated Crystal Oscillator Phase Noise @1KHz Freq. Range
BT0503H3I507EN10A
物料型号:BT0503
器件简介:这是由Xtaltq Technologies生产的BT0503,一款温度补偿晶体振荡器(TCXO),提供超稳定宽温度范围的SMD封装,尺寸为5.0×3.2mm。
引脚分配: - Pin1:Vcon. 控制电压 - Pin2:Gnd, 地 - Pin3:Fo. 输出 - Pin4:Vdd, 供电电压
参数特性: - 供电电压:3.3V至5V - 供电电流:典型值为3mA至6mA - 频率范围:10MHz至52MHz - 温度频率稳定性:在-20°C~+70°C范围内为±0.5ppm - 输出形式包括LVCMOS和裁剪正弦波 - 负载电容:10kΩ//10pF(裁剪正弦波)或15pF(LVCMOS) - 工作温度范围:-55°C~+95°C - 存储温度范围:-55°C~+125°C
功能详解: - 该振荡器提供了优秀的温度稳定性和频率精度,适用于基站、仪器、合成器、SDH/SONET、医疗电子等领域。 - 具有低功耗、小尺寸和高可靠性的特点。
应用信息: - 主要应用于需要高精度时钟信号的场合,如通信设备和医疗设备。
封装信息: - 封装尺寸为5.0mm x 3.2mm,适用于SMD贴装。
BT0503H3I507EN10A 价格&库存
很抱歉,暂时无法提供与“BT0503H3I507EN10A”相匹配的价格&库存,您可以联系我们找货
BT0503H3I507EN10A
  • 1+84.50000
  • 10+78.00000
  • 30+76.70000
