BT0503BH3I106BN40
BT0503BH3I106BN40
    XTALTQ(恒晶科技)
    SMD5032_10P
    有源晶振 40MHz 15pF 3.3V - SMD5032_10P
BT0503BH3I106BN40 数据手册
BT0503B Temperature Compensated Crystal Oscillator Features Applications ● Ultra Stable ● Wide Temperature Range ● SMD Package (5.0×3.2mm) ● ● ● ● ● Base Stations Instrumentations Synthesizer SDH/SONET Medical Electronics BT0503B Specifications Min. Value Typ. Max. Supply Voltage – 3.3 – V Supply Current 1.5 – 2.5 mA Parameter Frequency Range Nominal Frequency Initial Frequency Tolerance Freq. Stability Vs. Temp. Clipped Sine Wave Output Level Unit Conditions 10~ 52 MHz 10, 19.2, 20, 25, 26, 30.72, 40 MHz - – ±1.0 ppm At shipment, nominal EFC, +25℃ ±0.5 – ±1.0 ppm -40℃~+85℃ 0.8 – – Vp-p 10kΩ//10pF Load VOH 0.8Vdd – – V LVCMOS Output, Load=15pf VOL – – 0.2Vdd V LVCMOS Output, Load=15pf Duty Cycle 45 – 55 % ( VOH - VOL)/2 Rise/Fall Edge – – 6 ns LVCMOS Output, Load=15pf Load – – 15 pf Supply Sensitivity – – ±0.2 Load Sensitivity – – ±0.2 – – ±1.0 - – ±1.0 Customized – – -80 Offset 10Hz – – -115 Offset 100Hz – – -135 – – -148 Offset 10kHz – – -148 Offset 100kHz LVCMOS Aging/ First Year SSB Phase Noise @10MHz Control Voltage Range Frequency Turning Range ppm dBc/Hz Load±10% Standard Offset 1kHz At +25℃ 1.5 ± 1.0V ±5 Tuning Slope Non-linearity Vcc±5% – ±10 ppm 10 % Positive – – 1/3 Release Date: Aug.30. 2016 BT0503B Temperature Compensated Crystal Oscillator Outline Dimension & Pin Connections Environmental Conditions Operating Temperature Range -40℃~+85℃ Storage Temperature Range -55℃ ~ +125℃ Maximum Ratings Parameter Symbol Rating Supply Voltage Vdd -0.5V / 6V Control Voltage Vcon 0V / 3V ESD, HBM/CDM/MM 4KV/ 2KV/ 200V Reliability Parameter Condition Temperature Stress Test IEC60068, GJB360B Mechanical Stress Test IEC60068, GJB360B EMC Test (ESD) IEC61000, JESD22 Solderability EIA/JESD22-B102-C Moisture Sensitive Level MSL3 Contact Pads Gold over Nickel RoHS RoHS Directive 2011/65/EU Annex II Recasting 2002/95/EC 2/3 Release Date: Aug.30. 2016 BT0503B Temperature Compensated Crystal Oscillator IR Reflow Profile Ordering Guide BT 0503 B X X X XXX X X XX.XX Product: TCXO Frequency: xx MHz Outline: 5.0mm x 3.2mm Tuning Range: N:No Tuning A: ±5ppm B: ±7ppm Package: B: package B Phase Noise: A: -120dBc/Hz@1kHz B: -125dBc/Hz@1kHz C: -130dBc/Hz@1kHz D: -135dBc/Hz@1kHz E: -140dBc/Hz@1kHz Output: H: CMOS C: Clipped Sine Wave Supply Voltage: 3: 3.3 Vdc 5: 5.0 Vdc Temp. Stability: 206: ±2.0ppm 106: ±1.0ppm 507: ±0.5ppm Temp. Range: C: -20℃~+70℃ I: -40℃~+85℃ F: Customized Example: BT0507BH3C106DN10 Disclaimer Xtaltq Technologies Co., Limited reserves the right to make changes to the product(s) and/or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. 3/3 Release Date: Aug.30. 2016
BT0503BH3I106BN40 价格&库存
很抱歉,暂时无法提供与“BT0503BH3I106BN40”相匹配的价格&库存,您可以联系我们找货
