BT0507A/B
Temperature Compensated Crystal Oscillator
Features
Applications
Ultra Stable
Wide Temperature Range
SMD Package (7.0×5.0mm)
Provide Stratum Ⅲ Level Frequency Stability
Base Stations
Instrumentations
Synthesizer
SDH/SONET
Medical Electronics
BT0507A/B Specifications
Parameter
Supply Voltage
Supply Current
Min.
Value
Typ.
Max.
3.3
V
5
V
5
15
mA
Frequency Range
Nominal Frequency
Initial Frequency Tolerance
Freq. Stability Vs. Temp.
Clipped Sine
Wave
Output Level
10 ~ 52
Unit
Conditions
MHz
10, 12.8, 16.384, 19.2, 19.44, 20,
24.576, 25, 26, 30.72, 40, 50
MHz
±0.05
±0.5
ppm
At shipment, nominal EFC, +25℃
±0.05
±0.5
ppm
-20℃~+70℃
±0.05
±0.5
ppm
-40℃~+85℃
±0.2
±1.0
ppm
-50℃~+90℃
±0.5
±1.0
ppm
-55℃~+95℃
0.8
Vp-p
10kΩ//10pF
Load
VOH
2.4
V
LVCMOS Output, Load=15pf
VOL
0.4
V
Duty Cycle
45
55
( VOH - VOL)/2
Rise/Fall Edge
6
ns
Load
15
pf
0.4
1.3
ps
Supply Sensitivity
±0.1
Load Sensitivity
±0.2
±1.0
±0.3
±0.8
Customized
-95
Offset 10Hz
-120
Offset 100Hz
-140
-145
Offset 10kHz
-150
Offset 100kHz
LVCMOS
RMS Jitter(By E5052B)
Aging/ First Year
SSB Phase Noise
@10MHz
Control Voltage Range
Frequency Turning Range
1.5 ± 1.0
±5
Tuning Slope
Non-linearity
12KHz~5MHz
Vcc±5%
ppm
dBc/Hz
Load±5%
Standard
Offset 1kHz
At +25℃
V
±12
ppm
10
Positive
1/4
Release Date: Aug.30. 2016
BT0507A/B
Phase Noise @1KHz
Freq. Range
很抱歉,暂时无法提供与“BT0507BH3I106DN20B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+49.14000
- 10+47.04000
- 国内价格
- 1+63.24280
- 10+57.49340
- 国内价格
- 1+65.65320
- 10+60.32880
