LM311N
LM311N
    HGSEMI(华冠)
    DIP-8
    高性能电压比较器
LM311N 数据手册
LM311 High Performance Voltage Comparators LOGIC DIAGRAM Input polarity is reversed when GND pin is used as an output. ORDERING INFORMATION LM311N Plastic LM311D SOIC TA = -45°C to 85°C for all packages PIN ASSIGNMENT MAXIMUM RATINGS Symbol Value Unit Total Supply Voltage 36 V VO - VEE Output to Negative Supply Voltage 40 V VEE Ground to Negative Supply Voltage 30 V VID Input Differential Voltage ± 30 V VIN Input Voltage (Note) ± 15 V - Voltage at Strobe Pin VCC to VCC - 5 V VCC + ⏐VEE⏐ Parameter PD 1/θJA Power Dissipation and Thermal Characteristics Plastic Dual In-Line Packages Derate above TA =+25°C 625 5.0 mW mW/°C TJ(max) Operating Junction Temperature +150 °C -60 to +150 °C Tstg Storage Temperature Range Note: This rating applies for ±15 volt supplies. The positive input voltage limit is 30 volts above the negative supply. The negative input voltage limit is equal to the negative supply voltage or 30 volts below the positive supply, whichever is less. http://www.hgsemi.com.cn 1 2018 AUG LM311 RECOMMENDED OPERATING CONDITIONS Symbol VCC + ⏐VEE⏐ TA Parameter Min Total Supply Voltage Operating Temperature, All Package Types - 45 Max Unit 30 V +85 °C ELECTRICAL CHARACTERISTICS (VCC=+15 V, VEE= -15 V, TA =+25°C unless otherwise noted [Note 1]) Symbol Parameter Test Conditions Guaranteed Limits Min Unit Max VIO Input Offset Voltage (Note 2) RS ≤ 50 kΩ, TA = +25°C RS ≤ 50 kΩ, -45°C ≤ TA ≤ 85°C 7.5 10 mV IIO Input Offset Current (Note 2) TA = +25°C -45°C ≤ TA ≤ 85°C 50 100 nA IIB Input Bias Current TA = +25°C TA = -45°C TA = +85°C 250 375 500 nA AV Voltage Gain tDLH Propagation Delay Time 300 ns VDS Saturation Voltage 1.5 V VIR Input Voltage Range 13.0 V ICC Positive Supply Current +7.5 mA IEE Negative Supply Current -5.0 mA 150000 TA = +25°C VID ≤ -10 mV, IO=50 mA -14.5 NOTES: 1. Offset voltage, offset current and bias current specifications apply for a supply voltage range from a single 5.0 volt supply up to ±15 volt supplies. 2. The offset voltages and offset currents given are the maximum values required to drive the output within a volt of either supply with a 1.0 mA load. Thus, these parameters define an error band and take into account the “worst case” effects of voltage gain and input impedance. http://www.hgsemi.com.cn 2 2018 AUG
LM311N
物料型号为LM311,由华冠半导体(HGSEMi)生产。
这是一种高性能电压比较器,具有以下特点:
- 引脚分配:8个引脚,包括GND(8号引脚)、Vcc(1号引脚)、输入2(7号引脚)、输出(2号引脚)、输入3(6号引脚)、平衡/触发(3号引脚)、VEE(4号引脚)。
- 参数特性:工作温度范围为-45°C至85°C,总电源电压最高36V,输出到负电源电压最高40V,地到负电源电压最高30V。
- 功能详解:正输入电压限制为负电源电压以上30V,负输入电压限制为负电源电压或正电源以下30V(以较小者为准)。
- 应用信息:适用于需要高性能电压比较的场合。
- 封装信息:提供塑料双列直插式(Plastic Dual In-Line)和SOIC两种封装方式。
电气特性包括输入偏置电压、输入偏置电流、输入偏置电流、电压增益、传播延迟时间、饱和电压、输入电压范围、正电源电流和负电源电流等。
具体数值请参考数据手册。
LM311N 价格&库存
很抱歉,暂时无法提供与“LM311N”相匹配的价格&库存,您可以联系我们找货
