LM350
3-Amp Adjustable Regulators
FEATURES
1
2
Adjustable Output Down to 1.2V
Guaranteed 3A output Current
Guaranteed Thermal Regulation
Output is Short Circuit Protected
Current Limit Constant with Temperature
P+ Product Enhancement Tested
86 dB Ripple Rejection
Ensured 1% Output Voltage Tolerance
(LM350A)
Ensured Max. 0.01%/V Line Regulation
(LM350A)
Ensured Max. 0.3% Load Regulation (LM350A)
In addition to higher performance than fixed
regulators, the LM350 series offers full overload
protection available only in IC's. Included on the chip
are current limit, thermal overload protection and safe
area protection. All overload protection circuitry
remains fully functional even if the adjustment
terminal is accidentally disconnected.
Normally, no capacitors are needed unless the device
is situated more than 6 inches from the input filter
capacitors in which case an input bypass is needed.
An output capacitor can be added to improve
transient response, while bypassing the adjustment
pin will increase the regulator's ripple rejection.
Besides replacing fixed regulators or discrete
designs, the LM350 is useful in a wide variety of
other applications. Since the regulator is “floating”
and sees only the input-to-output differential voltage,
supplies of several hundred volts can be regulated as
long as the maximum input to output differential is not
exceeded, i.e., avoid short-circuiting the output.
APPLICATIONS
Adjustable Power supplies
Constant Current Regulators
Battery Chargers
By connecting a fixed resistor between the
adjustment pin and output, the LM350 can be used
as a precision current regulator. Supplies with
electronic shutdown can be achieved by clamping the
adjustment terminal to ground which programs the
output to 1.2V where most loads draw little current.
DESCRIPTION
The LM350 series of adjustable 3-terminal positive
voltage regulators is capable of supplying in excess
of 3A over a 1.2V to 33V output range. They are
exceptionally easy to use and require only 2 external
resistors to set the output voltage. Further, both line
and load regulation are comparable to discrete
designs. Also, the LM350 is packaged in standard
transistor packages which are easily mounted and
handled.
Connection Diagram
Case is Output
Figure 1. (TO-3 STEEL) Metal Can Package
Bottom View
http://www.hgsemi.com.cn
Figure 2. (TO-220) Plastic Package
Front View
1
2019 NOV
LM350
Absolute Maximum Ratings
Power Dissipation
Internally Limited
Input-Output Voltage Differential
+35V
−65°C to +150°C
Storage Temperature
Lead Temperature
Metal Package (Soldering, 10 sec.)
300°C
Plastic Package (Soldering, 4 sec.)
260°C
ESD Tolerance
TBD
−40°C ≤ TJ ≤ +125°C
LM350A
Operating Temperature Range
LM350
0°C ≤ TJ ≤ +125°C
Electrical Characteristics
Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating
Temperature Range. Unless otherwise specified, VIN − VOUT = 5V, and IOUT = 10 mA.
Parameter
LM350A
Conditions
Reference Voltage
IOUT = 10 mA, TJ = 25°C
3V ≤ (VIN − VOUT) ≤ 35V,
10 mA ≤ IOUT ≤ 3A, P ≤ 30W
Line Regulation
Load Regulation
10 mA ≤ IOUT ≤ 3A
Thermal Regulation
20 ms Pulse
Typ
Max
1.238
1.250
1.262
1.225
1.250
1.270
0.005
0.02
Adjustment Pin Current
Adjustment Pin Current Change
10 mA ≤ IOUT ≤ 3A, 3V ≤ (VIN − VOUT) ≤ 35V
0.005
0.03
%/V
0.05
0.02
0.07
%/V
0.1
0.3
0.1
0.5
0.3
1
0.3
1.5
0.002
0.01
0.002
0.03
%/W
50
100
50
100
μA
0.2
5
0.2
5
μA
10
3.5
10
mA
1
3.5
1.20
1
VIN − VOUT ≤ 10V
3.0
4.5
3.0
4.5
VIN − VOUT = 30V
0.3
1
0.25
1
A
0.001
10 Hz ≤ f ≤ 10 kHz
0.001
VOUT = 10V, f = 120 Hz, CADJ = 0 μF
VOUT = 10V, f = 120 Hz, CADJ = 10 μF
TJ = 125°C, 1000 hrs
Thermal Resistance, Junction to NDS Package
Case
NDE Package
Ambient (No Heat Sink)
NDE Package
V
0.01
TMIN ≤ TJ ≤ TMAX
Long-Term Stability
Units
Max
V
VIN − VOUT = 35V
Ripple Rejection Ratio
Typ
1.30
Temperature Stability
RMS Output Noise, % of VOUT
Min
1.25
Minimum Load Current
Current Limit
LM350
Min
65
66
86
0.25
1
3
4
50
2
66
A
65
dB
86
dB
0.25
1
1.2
1.5
°C/W
3
4
°C/W
35
°C/W
50
°C/W
2019 NOV
LM350
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
3
2019 NOV
很抱歉,暂时无法提供与“LM350T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.61000
- 30+2.52000
- 100+2.34000
- 500+2.16000
- 1000+2.07000
- 国内价格
- 1+4.13640
- 10+3.31560
- 50+2.86200
- 100+2.41920
- 500+2.22480
- 1000+2.10600
