X1011H-2*20-N0HF
X1011H-2*20-N0HF
    XKB(中国星坤)
    DIP
    胶壳 1.00mm 40pin
X1011H-2*20-N0HF 数据手册
广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: 1.00mm Pitch 1011 Series Connector Specification Date Revised This specification is referred to the 1.00mm series wire to board connector 索引【INDEX】 1. 适用范围 【Scope】 2. 规格与料号 【Spec and Part number】 3. 材质与表面处理 【Disposal of Material and surface】 4. 额定等级 【Ratings and applicable wires】 5. 性能 【 Performance 】 5-1. 电气的性能【Electrical Performance.】 5-2. 机械的性能【Mechanical Performance】 5-3. 环境性能及其它【Environmental Performance and Others】 6. 综合插入力及拔出力 【 Insertion/Withdrawal Force 】 7. SMT 红外线回流条件 【 SMT Infrared Reflow Condition 】 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: Date Revised 1.00mm Pitch 1011 Series Connector Specification 【1.适用范围 Scope】 此种规格包括 1.00mm Pitch 1011 Series 连接器规格说明. This Specification Covers the 1.00mm Pitch 1011 Series Connector Specification. 【2.规格与料号 Spec and Part number】 规格内容 产品料号 Specification Production No. 产品图示 Picture of Product 端子/Terminal X1011T-PSN NONE 胶壳/Housing X1011H-XX-N0HF X1011H-2*XX-XXXX NONE 针座/Wafer X1011WRS-XX-XXXX X1011WVS-2*XX-XXXX NONE 【3.材质与表面处理 Disposal of Material and surface】 规格内容 材 质 Specification Materials 表面处理 Disposal of Surface 端子/Terminal 磷铜/Phosphor Bronze 胶壳/Housing PA66 UL 94V-0 Base High Temperature Plastic UL 94V-0` PIN 磷铜/Phosphor Bronze Over Tin 70μ〞Plated Over 30μ〞Nickel Solder tab 磷铜/Phosphor Bronze Over Tin 70μ〞Plated Over 30μ〞Nickel 针座/Wafer Tin Plated: Over 70μ〞.Nickel: Over 30μ〞. (上述参数请以工程图为准/Please Refer to the Project drawing for the above Specification) 【4. 额定等级 Ratings and applicable wires】 项 目【Item】 额定电压 Rated Voltage (Max.) 额定电流 Rated Current (Max.) 规 格【Standard】 50V 1A [AC/DC] 使用温度范围 Ambient temperature Range -25℃~+85℃ 适用线径 Applicable wire insulation O.D AWG 28#、30#、32# Insulation O.D. 0.80mm(Max.) 【 *升温时含端子.Including terminal temperature rise. 】 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: 1.00mm Pitch 1011 Series Connector Specification Date Revised 【5.性能 PERFORMANCE】 5-1. 电气的性能 Electrical Performance. 项 目 【Item】 5-1-1 5-1-2 5-1-3 接触阻抗 Contact Resistance 条 件 【Test Condition】 公母配合,开放电压 20mV 以下,电流 10mA 检测 连接器 A~B 区. Mate connectors, measure by dry circuit, 20mV MAX, 10mA. (Based upon EIA-364-06A). 规 格 【Requirement】 Initial: 20 milliohms Max. After Test: 40 milliohms Max. 绝缘阻抗 Insulation Resistance 公母配合,在相邻端子,端子与地片之间,使用 250V 的直流电,检测连接器. Mate connectors, apply 250V DC between adjacent terminal or ground. (Based upon EIA-364-21B / MIL-STD-202 Method 302 Cond.B) 100 Megohms Min. 耐电压 Dielectric Strength 公母配合,在相邻端子,端子与地片之间,使用 500V 的交流电 1 分锺,检测连接器. Mate connectors, apply 500V AC for 1 minute between adjacent terminal or ground. (Based upon EIA-364-20A / MIL-STD-202 Method 301) 不出现中断等情况 No Breakdown and Flashover 铆线后之端子,开放电压 20mV 以下,电流 10mA 检测连接器. Crimp the applicable wire on to the terminal measure by dry circuit 20mV MAX, 10mA. 10 milliohms Max. 铆线后端子接 触阻抗 Contact 5-1-4 resistance on crimped portion 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: 1.00mm Pitch 1011 Series Connector Specification Date Revised 5-2. 机械的性能 Mechanical Performance. 项 目 【Item】 5-2-1 插拔力 Insertion & Retention Force 条 件 【Test Condition】 以每分锺 25.4±3mm 的速率插入和拔出. Insert and withdraw Connectors at the speed rate of 25.4±3mm/minute. 规 格 【Requirement】 参照第 6 项 Refer to paragraph 6 PULL PUSH 5-2-2 以 每 分 25.4±3mm 的 速 率 , 将 端 子 从 Housing 内轴向拔出的力量. Apply axial pull out force at the speed 端子保持力 rate of 25.4±3mm/minute on the Terminal/ terminal assembled in the housing. Housing Retention Force 4.90N {0.5kgf} Min. PULL 5-2-3 端子插入力 铆线后之端子插入 Housing 所需最大力量. Terminal Insert the crimped terminal into the Insertion housing. Force Pin 针保持力 5-2-4 Pin Retention Force 4.9N {0.5kgf} Max. 以每分 25.4±3mm 的速率,将 PIN 针从 Wafer 内轴向拔出的力量. Apply axial push force at the speed rate of 25.4±3mm/minute. PUSH 2.94N {0.30kgf} min. 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: 1.00mm Pitch 1011 Series Connector Specification Date Revised 项 目 【Item】 条 件 规 格 【Test Condition】 【Requirement】 固定铆线后的端子,使电线与端子分离时所 #28 #30 #32 AWG# 需的最小力量. Fix the crimped terminal, apply axial pull out Spec.kgf. 1.0 0.5 0.3 端子压着强度 force on the wire. (Do not crimp insulation Min. Tensile strength part). 5-2-5 (Crimped connections) Note> As for unspecified wire sizes in this specification define values with clients 5-3. 环境性能及其它 Environmental Performance and Others. 项 目 条 件 规 格 【Item】 【Test Condition】 【Requirement】 5-3-1 5-3-2 5-3-3 重复插拔 Repeated Insertion/ Withdrawal 以每分锺不超过 10 次的速率,将公母插拔 50 次. When mated up to 50 cycles repeatedly by the rate of 10 cycles per minute. 温升测试 公母对插后,在通过额定电流下,所测定的 温升测试 Temperature Temperature 温度. rise Carrying rated current load. (UL 1977) Rise 耐振动性 Vibration 2 耐冲击性 Shock 40 milliohms Max. 30℃ Max. 无异状 外观 振幅: 1.5mm P-P No Damage Appearance 时间: 10~55~10 HZ in 1 minute 持续时间: 每轴向 2 小时 接触阻抗 40 milliohms Amplitude: 1.5mm P-P Contact Max. Sweep time: 10~55~10 HZ in 1 minute Resistance Duration: 2 hours in each X.Y.Z axials. (Based upon EIA-364-28B/MIL-STD-202 瞬断 1 microMethod 213B Cond.A) Discontinuity second Max. 在 X.Y.Z 上 6 个方向上,以 490m/s (50g 的 5-3-4 接触阻抗 Contact Resistance 力 量 ) 冲 击 下 各 3 回 .490m/s2{50G}, 3 外观 Appearance 无异状 No Damage 接触阻抗 Contact Resistance 40 milliohms Max. strokes in each X.Y.Z. axes. (Based upon EIA-364-27B/MIL-STD-202 瞬断 Method 213B Cond.A) Discontinuity 1 microsecond Max. 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: 1.00mm Pitch 1011 Series Connector Specification 85±2℃,96 hours. 耐热性 5-3-5 (Based upon MIL-STD-202 Method 108A Heat Resistance Cond.A) 5-3-7 耐寒性 -25±5℃,96 hours. Cold Resistance ( Based upon EIA-364-105) 耐湿性 Humidity 温度: 40±2℃ 湿度: 90~95%(RH) 持续时间: 96 hours Temperature: 40±2℃ Relative Humidity: 90~95% Duration: 96 hours (Based upon EIA-364-31A/MIL-STD-202 Method 103B Cond.B) 5-3-8 从-55℃持续 30 分锺升至+85℃持续 30 分锺, 温度变化 循环 5 次. Temperature 5 cycles of: a) -55℃ 30 minutes. b) +85℃ 30 minutes. Cycling (Based upon EIA-364-32B) 5-3-9 在温度 35±2℃,盐水浓度 5±1%下,盐水喷雾 24±1 小时. 24±1 hours exposure to a salt spray from the 5±1% solution at 35±2℃. (Based upon EIA-364-26A/MIL-STD-202 Method 101D Cond.B). 5-3-10 盐水喷雾 Salt Spray 焊锡附着性 Solderability Engineering Dept Date Issued Subject [主题]: 5-3-6 ISSUED BY: 焊接时间: 3±0.5 秒. 焊接温度: 245±5℃. Soldering Time: 3±0.5second. Solder Temperature: 245±5℃. (Based upon EIA-364-52) Date Revised 外观 Appearance 接触阻抗 Contact Resistance 外观 Appearance 接触阻抗 Contact Resistance 外观 Appearance 无异状 No Damage 40 milliohms Max. 无异状 No Damage 40 milliohms Max. 无异状 No Damage 接触阻抗 Contact Resistance 耐电压 Dielectric Strength 绝缘阻抗 Insulation Resistance 100 Megohms Min. 外观 Appearance 无异状 No Damage 接触阻抗 Contact Resistance 外观 Appearance 接触阻抗 Contact Resistance 40 milliohms Max. Must meet 5-1-3 40 milliohms Max. 无异状 No Damage 40 milliohms Max. 浸渍面积需 95%以上 95% of Solder Wetting immersed area must show no voids, pin holes. 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: Date Revised 1.00mm Pitch 1011 Series Connector Specification 项 目 【Item】 条 件 【Test Condition】 焊接时间: 5~10 秒. 焊锡耐热性 焊接温度: 255+5/-5℃. Soldering time:5~10 sec solder. 5-3-11 SolderResistance Temperature:255+5/-5℃. (Based upon EIA-364-56A) 规 格 【Requirement】 外观 Appearance 无异状 No Damage 【6.综合插入力及拔出力 INSERTION/WITHDRAWAL FORCE】 PIN PIN 初次插入力(最大值) 30 次拔出力(最小值) 初次插入力(最大值) 30 次拔出力(最小值) 数 数 th First Insertion 30 Withdrawal First Insertion 30th Withdrawal No. of No. of (kgf Max.) (kgf Min.) (kgf Max.) (kgf Min.) CKT CKT 单排系列(Single row Series) Single 0.2 0.03 16 3.60 0.80 02 0.8 0.10 17 3.80 0.85 03 1.00 0.15 18 4.00 0.90 04 1.20 0.20 19 4.20 0.95 05 1.40 0.25 20 4.40 1.00 06 1.60 0.30 21 4.60 1.05 07 1.80 0.35 22 4.80 1.10 08 2.00 0.40 23 5.00 1.15 09 2.20 0.45 24 5.20 1.20 10 2.40 0.50 25 5.40 1.25 11 2.60 0.55 26 5.60 1.30 12 2.80 0.60 27 5.80 1.35 13 3.00 0.65 28 6.00 1.40 14 3.20 0.70 29 6.20 1.45 15 3.40 0.75 30 6.40 1.50 双排系列(Double row Series) 2*10 5.00 0.50 2*15 6.00 0.60 2*20 7.00 0.70 2*25 8.00 0.80 注:以上插拔次数为 30 次 Note:Insertion and Withdrawal for 30Cycles 【7. SMT 红外线回流条件 SMT INFRARED REFLOW CONDITION】 广东星坤科技股份有限公司 XKB INDUSTRIAL PRECISION CO.,LIMITED Product Specification [产品规格书]: ISSUED BY: Engineering Dept Date Issued Subject [主题]: 1.00mm Pitch 1011 Series Connector Specification Date Revised 5~10 秒(250+5/-0℃ 最高溫度) 5~10 Sec( 250+5/-0℃ PEAK 20~40 秒 (230℃ 最 90~120 秒 90~120 30 秒 小) 30 sec. (预熱 150~200℃) (Pre-heat 150~200℃ (Reflow) 温度条件曲线图/ 基板上温度 TEMPERATURE CONDITION GRAPH/ (TEMPERATURE ON BOARD PATTERN SIDE) 注记: 由于 P.C 板等焊接装置改变条件,所以请预先用自己的装置检查回流焊的条件. Notes: Please check the reflow soldering condition by your own devices beforehand. Because the condition changes by the soldering devices, P.C. boards, and so on.
X1011H-2*20-N0HF 价格&库存
很抱歉,暂时无法提供与“X1011H-2*20-N0HF”相匹配的价格&库存,您可以联系我们找货
