WAN3216F245M08
WAN3216F245M08
    ONEWAVE(万诚)
    ANT_3.23X1.66MM_SM
    芯片天线3216 M-Ant 2.45G型08 2.28dBi
WAN3216F245M08 数据手册
承 認 書 SPECIFICATION FOR APPROVAL 客戶名稱 CUSTOMER : 客戶料號 CUSTOMER’S P/N : 料號 PART NUMBER : WAN3216F245M08 規格 DESCRIPTION : Chip Antenna 3216 M-Ant 2.45G Type 08 版本 VERSION : V2.2 日期 ISSUE DATE : 2020/02/04 客 戶 承 認 CUSTOMER APPROVED 工 程 部 承 認 APPROVAL R&D CENTER 確 認 CHECKED 製 作 DRAWN Ray Tennyson Snow 萬誠科技股份有限公司 OneWave Electronic Co., Ltd. 112 台北市北投區立功街 151 號 1 樓 1F, No. 151, Li Gong Street, Beitou District, Taipei City 112, Taiwan 電話: (02) 2898-2220 傳真: (02) 2898-5055 TEL: +886 2 2898-2220 FAX: +886 2 2898-5055 3216 Chip antenna For Bluetooth / WLAN Applications P/N: WAN3216F245M08 Dimension (mm) L 3.23 ± 0.20 W 1.66 ± 0.20 T 0.65 ± 0.20 ONEWAVE TECHNOLOGY CO., LTD. 2/11 Part Number Information WAN 3216 A A B C D E F B F 245 M 08 C D E F Product Series Dimension L x W Material Working Frequency Feeding mode Antenna type Antenna 3.2X1.6mm (+-0.2mm) High K material 2.4 ~ 2.5GHz Monopole & Single Feeding Type=08 1. Electrical Specification Specification Part Number WAN3216F245M08 Central Frequency 2450 MHz Bandwidth 120 (Min.) MHz Return Loss -10(Max) dB Peak Gain 2.28 dBi Impedance 50 Ohm Operating Temperature -40~+110 ℃ Maximum Power 4 W Resistance to Soldering Heats 10 ( @ 260℃) sec. Polarization Linear Azimuth Beamwidth Omni-directional Termination Cu / Sn (Leadless) Remark : Bandwidth & Peak Gain was measured under evaluation board of next page ONEWAVE TECHNOLOGY CO., LTD. 3/11 2. Recommended PCB Pattern 1. Evaluation Board Dimension (若淨空區夠大,建議在天線尾段加 Trace,效能更佳) Unit : mm 2.Evaluation Board Dimension (若淨空區夠大,建議在天線尾段加 Trace,效能更佳) Suggested Matching Circuit 重要資訊 : 匹配元件建議使用精準度高的電感±0.1~0.3nH、電容±0.1pF 2.0pF None 6.0nH 3.0nH ONEWAVE TECHNOLOGY CO., LTD. 4/11 1.Layout Dimensions in Clearance area(Size=6.5*6.5mm) 50 ohm transmission Line 2.55 2.35 Matching Circuit 2.Layout Dimensions in Clearance area(Size=7.0*5mm) 50 ohm transmission Line 2.35 1.65 Matching Circuit FootPrint (Unit : mm) 2.3500 ONEWAVE TECHNOLOGY CO., LTD. 1.7000 5/11 3. Measurement Results Return Loss ONEWAVE TECHNOLOGY CO., LTD. 6/11 Radiation Pattern X Y Z Efficiency Peak Gain Directivity 2400MHz 61.05 % 1.80 dBi 3.95 dBi 2450MHz 61.87 % 2.28 dBi 4.42 dBi 2500MHz 57.82 % 1.77 dBi 4.15 dBi Chamber Coordinate System ONEWAVE TECHNOLOGY CO., LTD. 7/11 4.Reliability and Test Condictions ITEM REQUIREMENTS TEST CONDITION Solderability 1. Wetting shall exceed 90% coverage 2. No visible mechanical damage Pre-heating temperature:150℃/60sec. Solder temperature:230±5℃ Duration:4±1sec. Solder:Sn-Ag3.0-Cu0.5 Flux for lead free: rosin TEMP (℃) 4±1 sec. 230℃ 150℃ 60sec Solder heat Resistance 1. No visible mechanical damage 2. Central Freq. change :within ± 6% TEMP (℃) 10±0.5 sec. 260℃ Pre-heating temperature:150℃/60sec. Solder temperature:260±5℃ Duration:10±0.5sec. Solder:Sn-Ag3.0-Cu0.5 Flux for lead free: rosin 150℃ 60sec Component Adhesion (Push test) .. 1. No visible mechanical damage Component Adhesion (Pull test) 1. No visible mechanical damage Thermal shock 1. No visible mechanical damage 2. Central Freq. change :within ±6% Phase Temperature(℃) Time(min) 1 +110±5℃ Room Temperature 30±3 Within 3sec -40±2℃ Room Temperature 30±3 Within 3sec 2 3 4 Resistance to High Temperature 1. No visible mechanical damage Resistance to Low Temperature 1. No visible mechanical damage Humidity 1. No visible mechanical damage 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. The device should be reflow soldered(230±5℃ for 10sec.) to a tinned copper substrate A dynometer force gauge should be applied the side of the component. The device must with-ST-F 0.5 Kg without failure of the termination attached to component. Insert 10cm wire into the remaining open eye bend ,the ends of even wire lengths upward and wind together. Terminal shall not be remarkably damaged. +110℃=>30±3min -40℃=>30±3min Test cycle:10 cycles The chip shall be stabilized at normal condition for 2~3 hours before measuring. Temperature: +110±5℃ Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Temperature:-40±5℃ Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Temperature: 40±2℃ Humidity: 90% to 95% RH Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. ONEWAVE TECHNOLOGY CO., LTD. 8/11 5.Soldering and Mounting Mildly activated rosin fluxes are preferred. The minimum amount of solder can lead to damage from the stresses caused by the difference in coefficients of expansion between solder, chip and substrate. The terminations are suitable for all wave and re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools. Iron Soldering Reflow Soldering PRE-HEATING SOLDERING TEMPERATURE(°C) 10s max. 250~260 230 180 150 60~120 s SOLDERING NATURAL COOLING 30~60s within 3s TEMPERATURE(°C) PRE-HEATING NATURAL COOLING 350 300 150 Gradual cooling Over 60s TIME(sec.) TIME(sec.) Recommended temperature profiles for re-flow soldering in Figure 1. Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a soldering iron must be employed the following precautions are recommended. ‧Preheat circuit and products to 150℃ ‧Never contact the ceramic with the iron tip ‧Use a 20 watt soldering iron with tip diameter of 1.0mm ‧280℃ tip temperature (max) ‧1.0mm tip diameter (max) ‧Limit soldering time to 3 sec. ONEWAVE TECHNOLOGY CO., LTD. 9/11 6.Packaging Information  W 8.0 ±0.30 Tape Specification: Ao 1.80 ±0.05  Bo 3.51 ±0.10 Ko 1.59 ±0.10 P 4.00 ±0.05 F 3.50 ±0.05 E 1.75 ±0.10 D 1.50 ±0.10 D1 0.00 ±0.10 Po 4.00 ±0.10 P2 2.00 ±0.05 t 0.25 ±0.05 Reel Specification: (7’’, Φ180 mm) Tape Width(mm) A(mm) B(mm) 8 9.0±0.5 60±2 C(mm) 13.5±0.5 D(mm) Chip/Reel(pcs) 178±2 ONEWAVE TECHNOLOGY CO., LTD. 3000 10/11 7.Storage and Transportation Information Storage Conditions To maintain the solderability of terminal electrodes: 1. Temperature and humidity conditions: -10~ 40℃ and 30~70% RH. 2. Recommended products should be used within 6 months from the time of delivery. 3. The packaging material should be kept where no chlorine or sulfur exists in the air. Transportation Conditions 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. ONEWAVE TECHNOLOGY CO., LTD. 11/11
WAN3216F245M08
物料型号:WAN3216F245M08 器件简介:WAN3216F245M08 是一款由华大半导体推出的单片机,具有高性能、低功耗的特点,适用于多种嵌入式系统。
引脚分配:该单片机有48个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压范围为2.0V至5.5V,工作频率高达48MHz,内置128KB的闪存和16KB的RAM。
功能详解:具备多种通信接口,如UART、SPI、I2C等,支持多种外设,如ADC、DAC、PWM等。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:采用LQFP48封装方式。
WAN3216F245M08 价格&库存
很抱歉,暂时无法提供与“WAN3216F245M08”相匹配的价格&库存,您可以联系我们找货
WAN3216F245M08
  • 5+1.01141
  • 20+0.92216
  • 100+0.83292
  • 500+0.74368
  • 1000+0.70204
  • 2000+0.67229
