A2010WV-8P
A2010WV-8P
    CJT(长江连接器)
    插件,P=2mm
    线对板针座 1x8P 直插 间距:2mm
A2010WV-8P 数据手册
A2010 SERIES 2.00mm pitch wire to board connector Specifications Current rating:2A AC,DC Voltage rating:100V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:800V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 4.00 1.60 1.60 4.20 6.30 REF 8.10 REF CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-251 A2010 SERIES A2010-T 2.00mm pitch wire to board connector 2.00mm Pitch Crimp Terminal Reference Informations: *Used in CJT A2010H ,HA-XP,A2010HA-2xXP,A2008HA-XP series Housing 2.30±0.25 2.30±0.25 1.30±0.25 2.00±0.20 SEC:B-B 1.30±0.25 B 1.20±0.10 B SEC:A-A 1.80 A 0.90 A 4.80±0.25 0.70 0.20 Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A2010-TP AWG#24-#30 1.40mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A2010-GP AWG#24-#30 1.40mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested A2010H-XP 2.00mm Pitch Housing Reference Informations: *Material:PBT+15%GF,UL94V-0 *Suitable CJT A2010-T series Terminal *Mates with CJT A2010WV,WR-XP,A2010WV-F-XP series Wafer *Color:White A±0.20 2.00±0.10 Circuit 1 3.45±0.20 5.80±0.25 B±0.25 Ordering Information: A2010H-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):PBT+15%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Color: (Blank):White BK:Black RD:Red YL:Yellow BL:Blue GN:Green 3.20±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 2.00 5.80 4.00 7.80 6.00 9.80 8.00 11.80 10.00 13.80 12.00 15.80 14.00 17.80 16.00 19.80 18.00 21.80 20.00 23.80 22.00 25.80 24.00 27.80 26.00 29.80 28.00 31.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-252 A2010 SERIES A2010HA-2xXP 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2010-T series Terminal *Mates with CJT A2010WVA-F-2xXP,A2012WVB-F-2xXP series Dual Row Wafer *Color:Gray 2.00±0.10 Ordering Information: A2010HA-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 2.00±0.10 6.20±0.20 A±0.20 B±0.30 6.90±0.20 8.20±0.20 2.00±0.10 2x5P~2x14P 2.00±0.10 A±0.20 Ordering Information & Dimensions: B±0.30 6.20±0.20 PART NO. 6.90±0.20 8.20±0.20 2x15P~2x30P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x20P 2x25P 2x30P Dimensions A B 13.50 8.00 10.00 15.50 12.00 17.50 14.00 19.50 16.00 21.50 18.00 23.50 20.00 25.50 22.00 27.50 24.00 29.50 26.00 31.50 28.00 33.50 30.00 35.50 32.00 37.50 38.00 43.50 48.00 53.50 58.00 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-254 A2010 SERIES A2010WV-XP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66+30%GF,UL94V-0 *Mates with CJT A2010H-XP series Housing *Color:White A±0.20 A±0.20 2.00±0.10 2.00±0.10 Ordering Information: A2010WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66+30%GF,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):White BK:Black RD:Red YL:Yellow BL:Blue GN:Green Ø0.80±0.05 Circuit 1 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 3.50±0.20 5.50±0.25 3.65±0.20 PIN 0.50 SQ Dimensions A B 2.00 6.00 4.00 8.00 6.00 10.00 8.00 12.00 10.00 14.00 12.00 16.00 14.00 18.00 16.00 20.00 18.00 22.00 20.00 24.00 22.00 26.00 24.00 28.00 26.00 30.00 28.00 32.00 Unit: mm A2010WR-XP 2.00mm Pitch 90° Wafer Ordering Information: A2010WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66+30%GF,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):White BK:Black RD:Red A±0.20 YL:Yellow BL:Blue 2.00±0.10 GN:Green Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66+30%GF,UL94V-0 *Mates with CJT A2010H-XP series Housing *Color:White Circuit 1 Ø0.80±0.05 PIN 0.50 SQ 2.00±0.10 P.C.B LAYOUT A±0.20 Ordering Information & Dimensions: PART NO. B±0.25 3.50±0.20 7.30±0.25 6.04±0.20 5.65±0.20 4.20±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 2.00 6.00 4.00 8.00 6.00 10.00 8.00 12.00 10.00 14.00 12.00 16.00 14.00 18.00 16.00 20.00 18.00 22.00 20.00 24.00 22.00 26.00 24.00 28.00 26.00 30.00 28.00 32.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-255 A2010 SERIES A2010WV-F-XP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66+30%GF,UL94V-0 *Mates with CJT A2010H-XP series Housing *Color:White Ordering Information: A2010WV-F-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66+30%GF,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):White BK:Black RD:Red YL:Yellow BL:Blue GN:Green A±0.20 2.00±0.10 A±0.20 1.40±0.05 2.00±0.10 1.50±0.05 Ø0.80±0.05 Circuit 1 Ø1.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. B±0.25 3.65±0.20 5.50±0.25 3.50±0.20 1.50 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P ∅0.80 1.50 PIN 0.50 SQ Dimensions A B 2.00 6.00 4.00 8.00 6.00 10.00 8.00 12.00 10.00 14.00 12.00 16.00 14.00 18.00 16.00 20.00 18.00 22.00 20.00 24.00 22.00 26.00 24.00 28.00 26.00 30.00 28.00 32.00 Unit: mm A2010WVA-F-2xXP 2.00mm Pitch 180° Dual Row Wafer 2.00±0.10 2.00±0.10 Ø1.50±0.05 Ø0.80±0.05 A±0.20 1.00±0.10 A±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2010HA-2xXP series Dual Row Housing *Color:Gray Ordering Information & Dimensions: Ordering Information: A2010WVA-F-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ Circuit 1 B±0.25 PIN 0.50 SQ 3.50±0.20 1.60 8.50±0.20 Ø1.18 6.50±0.25 2.00±0.10 P.C.B LAYOUT 2.00±0.10 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x20P 2x25P 2x30P Dimensions A B 2.00 9.40 4.00 11.40 6.00 13.40 8.00 15.40 10.00 17.40 12.00 19.40 14.00 21.40 16.00 23.40 18.00 25.40 20.00 27.40 22.00 29.40 24.00 31.40 26.00 33.40 28.00 35.40 30.00 37.40 32.00 39.40 38.00 45.40 48.00 55.40 58.00 65.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-256
A2010WV-8P 价格&库存
很抱歉,暂时无法提供与“A2010WV-8P”相匹配的价格&库存,您可以联系我们找货
A2010WV-8P
  • 1+0.71909
  • 30+0.69377
  • 100+0.64313
  • 500+0.59249
  • 1000+0.56717
库存:893
