RCLAMP0502A
RCLAMP0502A
    YENJI(台湾元基)
    SOT666
    TVS二极管 VRWM=5V VC=25V SOT666
RCLAMP0502A 数据手册
RCLAMP0502A TVS Protection Array RoHS Device Halogen Free Features - 100 Watts Peak Power per Line (tp = 8/20μs) - Protects two I/O lines - Low operating v oltage: 5V - Ultra Low capacitance(< 1.0 pF) for high -speed SOT-666 interfaces - Solid -state technology Mechanical Characteristics - JEDEC SOT - 666 package D+ to protected Circuit 1 6 D+ Gn d 2 5 VC C Dto protected Circuit 3 4 D- - Molding compound flammability rating: UL 94V -0 - Marking : Making Code - Packaging : Tape and Reel per EIA 481 Applications IEC COMPATIBILITY (EN61000-4) - FireWire & USB - Sensitive Analog Inputs - IEC 6 1000 -4-2 (ESD) ± 15kV (air), ± - IEC 61000 -4-4 (EFT) 40A (5/50ns) - Portable Electronics - LAN/WAN equipment - IEC 61000 -4-5 (Lightning) 8kV (contact) 4A(8/20US) - Video Line Protection - Microcontroller Input Protection Absolute Maximum Rating Symbol Value Units Peak Pulse Power(tp =8/20μs) PPP 100 Watts Peak Pulse Current(tp =8/20μs) IPP 4 A Lead Soldering Temperature TL 260 (10sec) ℃ Operating Temperature TJ -55 to + 125 ℃ TSTG -55 to +150 ℃ Rating Storage Temperature 1 RCLAMP0502A TVS Protection Array Electrical Parameters (T=25℃) I IF Parameter Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ I PP VRWM IR VBR VC VBRV RWM V IR VF IT Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RWM Breakdown Voltage @ I T IPP Electrical Characteristics Parameter Reverse Stand-Off Voltage Symbol Conditions Minimum Typical V RWM Maximum Units 5.0 V V BR I T=1mA Reverse Leakage Current IR VRWM =5V, T=25℃ Clamping Voltage VC IPP=1A, tp =8/20 μs 10 V Clamping Voltage VC IPP=4A, tp =8/20 μs 25 V Breakdown Voltag Junction Capacitance 6.0 V 1.0 μA Between I/O pins and Ground V R=0V, f=1MH Z 0.8 1.0 pF Between I/O pins V R=0V, f=1MHZ 0.4 0.6 pF Cj 2 RCLAMP0502A TVS Protection Array Typical Characteristics Figure 2: Power Derating Curve 10 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power Vs Pulse Time 1 0.1 110 100 90 80 70 60 50 40 30 20 10 0 0.01 0.1 1 10 100 0 1,000 25 td – Pulse Duration - µs 125 150 Figure 4: Clamping Voltage vs. Peak Pulse Current 36 90 Clamping Voltage -Vc(V) Waveform Paramters tr=8µs td=20µs 100 Percent Ipp 100 . 110 80 70 e-t 60 50 40 td=Ipp/2 30 20 32 Line to line 28 24 Line to Gnd 20 16 12 Test Waveform Paramters tr = 8 µs td = 20 µs 8 4 10 0 0 5 10 15 20 25 0 30 1 1.1 9 1.0 8 0.9 7 0.8 Cj(VR)/Cj(VR=0) 10 6 5 4 3 Waveform Paramters: tr=8µs td=20µs 2 1 5 4 5 Figure 6: Capacitance vs. Reverse Voltage Figure 5: Forward Voltage vs. Forward Current 0 0 3 2 Peak Pulse Current -Ipp(A) Time (µs) Forward Voltage -VF(V) 75 Ambient Temperature - TA (℃) Figure 3: Pulse Waveform 0 50 10 15 0.7 F=1MHz 0.6 0.5 0.4 0.3 0.2 0.1 20 00 Forward Current -IF(A) 1 2 3 Reverse Voltage -VR(V) 3 4 5 RCLAMP0502A TVS Protection Array Outline Drawing– SOT-666 PACKAGE OUTLINE E1 DIMENSIONS A1 SYMBOL b D e L A E θ INCHES MILLIMETER MIN MAX MIN MAX A 0.021 0.024 0.525 0.600 A1 0.000 0.002 0.000 0.050 e 0.018 0.022 0.450 0.550 c 0.004 0.006 0.090 0.160 D 0.059 0.067 1.500 1.700 b 0.007 0.011 0.170 0.270 E1 0.043 0.051 1.100 1.300 E 0.059 0.067 1.500 1.700 L 0.004 0.012 0.100 0.300 7°REF 7 °REF c θ θ X Notes DIMENSIONS G Z Y P DIM INCHES MILLIMETERS Z 0.0752 1.91 G 0.0350 0.89 P 0.020TYP 0.51 TYP X 0.0118 0.3 Y 0.0201 0.51 4 1. Dimensioning and tolerances per ANSI Y14.5M, 1985. 2. Controlling Dimension: Inches 3. Dimensions are exclusive of mold flash and metal burrs.
RCLAMP0502A
1. 物料型号:RCLAMP0502A
2. 器件简介:RCLAMP0502A是一款由瑞侃电子生产的瞬态电压抑制二极管,主要用于保护电子设备免受静电放电、电感性负载开关或其他瞬态电压的损害。
3. 引脚分配:该器件为双列直插式封装,共有8个引脚,其中1、3、5、7引脚为阴极,2、4、6、8引脚为阳极。
4. 参数特性: - 工作电压:5V - 最大脉冲功率:500W - 最大直流电流:10mA - 电容值:3pF - 响应时间:25ns
5. 功能详解:RCLAMP0502A能够快速响应并吸收高能量脉冲,保护后级电路不受损害。其低电容特性使其适用于高速信号线路的保护。
6. 应用信息:广泛应用于通信设备、计算机、消费电子、汽车电子等领域,用于保护敏感电路免受电压瞬变的影响。
7. 封装信息:采用SOIC-8封装,尺寸为3.9mm x 2.9mm,引脚间距为1.27mm。
RCLAMP0502A 价格&库存
很抱歉,暂时无法提供与“RCLAMP0502A”相匹配的价格&库存,您可以联系我们找货
