NZQA6V8AXV5
ESD Protection Array
RoHS Device
Halogen Free
Features
- Solid-state silicon-avalanche technology
- 30 Watts Peak Pulse Power per Line (tp =8/20μs)
- Low operating and clamping voltages
- Up to Four (4) Lines of Protection
- Working Voltages: 5 V
- Low Leakage Current
SOT-553
- ESD protection >20 kV
- IEC 61000-4-2; level 4 (ESD); 15 kV (air) or
8 kV (contact).
5
4
Mechanical Characteristics
- SOT-553 package
- Molding compound flammability rating:
1
2
3
UL 94V-0
- Marking: Marking Code
- Packaging: Tape and Reel
Applications
PINNING
- Cellular Handsets & Accessories
- Personal Digital Assistants (PDAs)
- Notebooks & Handhelds
- Portable Instrumentation
- Digital Cameras
- MP3 Player
PIN
DESCRIPTION
1
2
3
cathode 1
common anode
cathode 2
4
5
cathode 3
cathode 4
Absolute Maximum Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
30
Watts
Peak Forward Voltage ( IF =1A, t p =8/20μs )
VFP
1.5
V
Operating Temperature
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Rating
Storage Temperature
1
NZQA6V8AXV5
Electrical Parameters (T=25℃)
Symbol
Parameter
I
I PP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ I PP
VRWM
IR
VBR
IF
Working Peak Reverse Voltage
VC VBR VRWM
Maximum Reverse Leakage Current @ VRWM
Breakdown Voltage @ I T
IT
Test Current
IF
Forward Current
VF
Forward Voltage @
V
I R VF
IT
I PP
IF
Electrical Characteristics
Parameter
Symbol
Reverse Stand Off Voltage
Conditions
Minimum
Typical
VRWM
Maximum
Units
5.0
V
6.0
VBR
I T =1mA
IR
VRWM=5V,T=25°C
1
μA
Peak Pulse Current
II P P
t p =8/20μs
2
A
Clamping Voltage
VC
IPP= 2A, tp =8/20μs
11
V
Junction Capacitance
Cj
Between I/O pins and
Ground
VR = 0V, f = 1MHz
6.5
pF
Reverse Breakdown Voltage
2
V
NZQA6V8AXV5
Typical Characteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
0.1
0.01
0 .1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
50
75
100
125
150
Ambient Temperature - TA (℃)
Figure 3: NZQA6V8AXV5 Insertion Loss
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
C H S21 L O G 6 dB / R E F 0 dB
1.1
1.0
F=1MHz
Cj(VR)/Cj(VR=0)
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
S T A R T .0 3 0 M H z
S T O P 3 0 0 0 .0 0 0 0 0 0 M H z
00
1
2
3
Reverse Voltage -VR(V)
Figure 5: ESD Clamping( 8kV Contact per
IEC 61000-4-2)
Tek Run: 2.50GS/s
Sample
CH1 10.0 VΩ
M 30.0ns Ch1
7.0V
3
4
5
NZQA6V8AXV5
Outline Drawing –SOT -553
PACKAGE OUTLINE
DIMENSIONS
SYMBOL
D
b
E1 E
1
e
INCHES
MILLIMETER
MIN
MAX
MIN
MAX
A
0.021
0.024
0.525
0.600
b
0.007
0.011
0.170
0.270
C
0.004
0.006
0.090
0.160
D
0.059
0.067
1.500
1.700
E
0.059
0.067
1.500
1.700
E1
0.043
0.051
1.100
1.300
e
0.018
0.022
0.450
0.550
L
0.004
0.012
0.100
0.300
A
C
L
X
Notes
DIMENSIONS
G Z
Y
P
DIM
INCHES
MILLIMETERS
Z
0.0708
1.80
G
0.0354
0.90
P
0.0197 TYP
0.50 TYP
X
0.0118
0.3
Y
0.0177
0.45
4
1. Dimensioning and tolerances per ANSI Y14.5M, 1985.
2. Controlling Dimension: Inches
3. Dimensions are exclusive of mold flash and metal burrs.
很抱歉,暂时无法提供与“NZQA6V8AXV5”相匹配的价格&库存,您可以联系我们找货
